shizzl Posted December 28, 2018 Author Posted December 28, 2018 10 hours ago, kyteler said: Tuned the carbs, goes really well. Nek minit Rod through block. Haters gonna hate I guess Quote
kyteler Posted December 28, 2018 Posted December 28, 2018 It's not a slight on you my dude. Just that's how shit typically operates. Also, British. 1 Quote
shizzl Posted December 28, 2018 Author Posted December 28, 2018 I try my best not to over rev it. Which is why I got a rev counter for it Quote
shizzl Posted December 28, 2018 Author Posted December 28, 2018 By piss tune I mean with no special tools.. Sync by air, adjust mixtures, use the air piston test, get it to a rich over condition.. Nice and ready to go to some old Barry with a colourtune/gunson set/actual sync meter stuff It could be worse, I could've used the twin 175s over the stock single 150, I think the twin 150s are enough, hell the gls/gt hunters came out with twin 40 sidedraughts. Almost time to drop the 40 over pistons into it and get the cam done, shave the head a few thou, chuck in a fresh rod set Quote
tortron Posted December 29, 2018 Posted December 29, 2018 22 hours ago, shizzl said: I try my best not to over rev it. Which is why I got a rev counter for it Standard Valve springs will stop you from over reving it anyways Quote
shizzl Posted December 29, 2018 Author Posted December 29, 2018 Nah I think the dizzy will fall apart first Quote
d.p.n.s Posted January 25, 2019 Posted January 25, 2019 mate I learnt agers ago fucking around with blocks .....just order long ubolts and make blocks to fit the drop you want.. Quote
shizzl Posted January 27, 2019 Author Posted January 27, 2019 the kit I got worked out to way cheaper than just sourcing the bolts. ill run it as it for now and make 50mm blocks later. need to get hold of some early ford front springs for the front first. 1 Quote
a.craw4d Posted February 2, 2019 Posted February 2, 2019 Shit that looks good @shizzl. The back looks like it could come down a little more but it doesn't stand out as obvious either. Might settle down a bit yet. I love how tough a car can look with some wide steelies and decent low. 1 Quote
shizzl Posted February 2, 2019 Author Posted February 2, 2019 Cheers.. I'm going to change the front springs anyway which will probably lift it about 10mm from its current height.. It was parked in a slight dip which tipped it forward.. It handles pretty good as it is, would lots better with new shocks. Quote
shizzl Posted April 7, 2019 Author Posted April 7, 2019 zero updates, and currently has zero wof.. Need to replace both front shock inserts, but thats where Im stuck... no one has been helpful in sourcing anything that will fit, or even provide something that could be adapted to fit. or atleast the info I need to pick the best option.. Im 99% sure that a 80/90s 318 BMW E30 front insert will drop straight into the leg.. the only difference being the size of the bearing shoulder and thread size. BUT, I cannot confirm due to incompetent parts monkeys not being able to give me accurate measurements.. If I can source a pair of E30 shocks I can crack into getting this on the road again for a couple of drives before winter. Ive also got something else cooking in the engine bay, but require another airfilter box for that to be completed, will be pretty sweet for what it is. also still trying to nut out how to do the twin choke cable for the carbs Quote
cletus Posted April 7, 2019 Posted April 7, 2019 try Iain at autolign, mt wellington he is a GC of the highest order 1 Quote
shizzl Posted April 7, 2019 Author Posted April 7, 2019 9 minutes ago, cletus said: try Iain at autolign, mt wellington he is a GC of the highest order Will do, I tried Stocks, and was on the phone for 45min and still couldnt get the info I needed, painful Quote
kyteler Posted April 7, 2019 Posted April 7, 2019 You tried these guys? http://www.southernhemimedia.com/hillman_hunters_23.html They list that they have shocks but the page could be old. Also, as I think I've mentioned before. If you're willing to try second hand head to Parkside Panels and ask for Ewan. Take the Hunter with to engage his interest. He might have something in his stash or his father, Peter, might. Quote
shizzl Posted April 7, 2019 Author Posted April 7, 2019 1 hour ago, kyteler said: You tried these guys? http://www.southernhemimedia.com/hillman_hunters_23.html They list that they have shocks but the page could be old. Also, as I think I've mentioned before. If you're willing to try second hand head to Parkside Panels and ask for Ewan. Take the Hunter with to engage his interest. He might have something in his stash or his father, Peter, might. Cheers Will try them on Wednesday when I'm back home. Quote
shizzl Posted April 25, 2019 Author Posted April 25, 2019 So while the family is away up north ive been bored shitless and trolling FB marketplace.. stumbled across a local who is trying to offload some shit from his old ladies house.. turned out he has a hunter motor.. contacted him, went round to check it out, looked like a pile (standard british OEM spec).. looks to be either from a 68 hunter or a gazelle or one of the other many Rootes powered contraptions.. Asked what he wanted for it, he said "just want it gone".... choice free motor for spares. got it home and started pulling it apart...plans are to bore it out and put in my +40 pistons, bike carbs and get the cam reground, and port match the head etc... then..... got the head off, scraped off some of the carbon build up (stromberg lube) off the pistons to see what they were.. they all look relatively fresh, and have 1.50 mm stamped on them fucking score!!! Bores look mint, valves dont look too bad either.. and another carb to add to the collection 2 Quote
shizzl Posted April 25, 2019 Author Posted April 25, 2019 so according to an internet barry specialist what I have here is a 69 MKII engine with oversize pistons pushing it out to 1789cc, this block is a 5 bearing crank so is the better block to work. need a socket to get the crank bolt off, so I can access the cam to see if that is stock, and then send it away.. Free is good 3 1 Quote
shizzl Posted April 26, 2019 Author Posted April 26, 2019 20 hours ago, kyteler said: What size socket do you need? sorted...turns out it is a 32mm which I actually have.. block is completely stripped, the bores have very recent looking cross hatching in them/very low kms since the build.. cam looks brand new with no lobe wear, lifters have no marks on them.. the piston skirts look new although with some minor running marks as expected.. Im picking that this was fully rebuilt, run for a bit then pulled out.. I will most likely just get the block super clean and paint it, then clean and reassemble the bottom end. work out what the cam is if its stock or slightly tickled. then I will move onto the head, open up the combustion chamber similar to a Holbay or Marathon spec, then work out how much I will need to take off the head to get the comp ratio where it needs to be. will set the bike carbs up on this motor, and if it all goes to poop then not much loss at all 4 1 Quote
