Nominal Posted February 10, 2018 Posted February 10, 2018 That's what I thought. Weird location though. Maybe take it to a cam man for look see? Quote
chris r Posted February 10, 2018 Author Posted February 10, 2018 it only seems to be on the corner/edges and not on the "flat" of the cam Quote
Kiwibirdman Posted February 12, 2018 Posted February 12, 2018 Remember that the lifter is off set against the cam so the lifter spins. Looks like the hardening is going, not unusual on holden motors, especially with modern oil that has bugger all zinc additive. How many miles on the engine? Quote
chris r Posted February 12, 2018 Author Posted February 12, 2018 That cam came with the collection of stuff so no idea. It was part of a deceased Estate Quote
Kiwibirdman Posted February 12, 2018 Posted February 12, 2018 Deceased is the right description for that cam. Quote
chris r Posted February 17, 2018 Author Posted February 17, 2018 29 minutes ago, nzed said: Bin it. And the rest of the motor. Jam a 3fiddy in it and never look back. Give me a three fiddy and trans/cert then and I will Quote
chris r Posted February 17, 2018 Author Posted February 17, 2018 The roller rockers aren't for the 202. There are too many to fit on the head... Quote
chris r Posted February 23, 2018 Author Posted February 23, 2018 I r noob Retainers go on before the seals.... Its obvious now hah Quote
Shakotom Posted February 23, 2018 Posted February 23, 2018 Still after a waterneck? i think I’ve got a good one in the shed you can have for some koha will have a hunt Quote
chris r Posted February 23, 2018 Author Posted February 23, 2018 39 minutes ago, Shakotom said: Still after a waterneck? i think I’ve got a good one in the shed you can have for some koha will have a hunt Yeah if you find it in your travels that'd be be great Quote
chris r Posted February 26, 2018 Author Posted February 26, 2018 On 13/02/2018 at 08:22, Kiwibirdman said: Deceased is the right description for that cam. You called it. Its gone in for a regrind and I should have it back this week Quote
Kiwibirdman Posted February 26, 2018 Posted February 26, 2018 16 hours ago, chris r said: You called it. Its gone in for a regrind and I should have it back this week Is it getting a standard grind or something a little better. Also do you need longer pushrods with a reground cam? Quote
chris r Posted February 26, 2018 Author Posted February 26, 2018 11 minutes ago, Kiwibirdman said: Is it getting a standard grind or something a little better. Also do you need longer pushrods with a reground cam? Something better of course! Just valve springs for this profile. I need to measure mine and drop them off to test Quote
tortron Posted February 26, 2018 Posted February 26, 2018 I hear there was a special on race cams, buy 3 lobes and they give you the 4th one free Quote
Kiwibirdman Posted February 27, 2018 Posted February 27, 2018 7 hours ago, chris r said: Something better of course! Just valve springs for this profile. I need to measure mine and drop them off to test You are on the slippery slope. Next is carby then extractors. Followed by some head work, then................ Quote
chris r Posted February 27, 2018 Author Posted February 27, 2018 6 minutes ago, Kiwibirdman said: You are on the slippery slope. Next is carby then extractors. Followed by some head work, then................ Heads are already ported and came with roller rockers etc. I've got a 4barrel that came with the rest of the stuff Quote
nzstato Posted April 25, 2020 Posted April 25, 2020 Yes M20s are now moonbeams.... A cheap trick is to get a 6cyl box and swap out the 1st gear/pinion for a v8 one (you can buy them new). The gearing isnt quite the same but it can be a cheaper route. Quote
nzstato Posted April 25, 2020 Posted April 25, 2020 Also, I may have a 1ton gearshift somewhere in the shed. Will let you know if I find it? Quote
chris r Posted April 25, 2020 Author Posted April 25, 2020 Just now, nzstato said: Yes M20s are now moonbeams.... A cheap trick is to get a 6cyl box and swap out the 1st gear/pinion for a v8 one (you can buy them new). The gearing isnt quite the same but it can be a cheaper route. thats what I have being investigating, however the v8 input shaft is now moonbeams too and I'm not 100% sure they are compatible with the m22 tonner gearbag. Edit - just had another look on ebay and they are around 350 aud for the shaft. less than the last time I looked The 253 doesnt owe me much so I might just hoard for another project one day. Will see how it goes. Quote
Bearded Baldy Posted April 26, 2020 Posted April 26, 2020 On 27/02/2018 at 18:24, Kiwibirdman said: You are on the slippery slope. Next is carby then extractors. Followed by some head work, then................ He is right you know, then comes lightweight billett flywheels and 4pinion lsds.... Quote
