tortron Posted October 11, 2020 Posted October 11, 2020 I think the Webber might be a bit over jetted? 2 2 3 Quote
chris r Posted October 11, 2020 Author Posted October 11, 2020 Might explain why it was a bit quieter than usual Quote
tortron Posted October 13, 2020 Posted October 13, 2020 windscreen man has a lot of imps and a too low hunter wags and had a minor just like mine, except not 1 Quote
chris r Posted October 13, 2020 Author Posted October 13, 2020 4 minutes ago, tortron said: windscreen man has a lot of imps and a too low hunter wags and had a minor just like mine, except not His minor runs? Quote
tortron Posted January 27, 2021 Posted January 27, 2021 https://www.trademe.co.nz/a/motors/car-parts-accessories/holden/exterior/listing/2951475689?bof=mmlx2Oxd 1 Quote
flyingbrick Posted April 18, 2021 Posted April 18, 2021 Oh man, I had a catch up. Saw the rust and was like omg... And then super happy to see you fix it and get it all back together ASAP. Well done! 1 Quote
tortron Posted April 26, 2021 Posted April 26, 2021 nother webber if yours is still no good https://www.trademe.co.nz/a/motors/car-parts-accessories/performance/carburation-induction/listing/3070038990?bof=i6Ca9FvP 1 Quote
chris r Posted April 26, 2021 Author Posted April 26, 2021 Probably should get around to putting the other weber back on Quote
Raizer Posted June 6, 2023 Posted June 6, 2023 @chris r had a fancy Weber adapter CNC machined, but somewhere along the way it gained an extra 10mm in the base. So I made it a lot less fancy but a lot more functional. I haven't welded alloy in way too long/needed to preheat more, but it's solid! 8 1 Quote
Popular Post Raizer Posted June 10, 2023 Popular Post Posted June 10, 2023 Even less pretty, but still hopefully functional. TBI to Holley adapter made from a couple scrap bits of 12mm alloy plate. 10 Quote
chris r Posted June 28, 2023 Author Posted June 28, 2023 Rough idea I have for idle control is a inline style motor off a bmw/euro thing. Should be able to hide a hole in the manifold and air cleaner base fairly easy. I know port injection is much better overall but for learning/playing around with tuning the single point/throttle body will be good enough to get started Quote
vk327 Posted June 29, 2023 Posted June 29, 2023 2002 ford mustang idle valve is easy to fit and works well https://www.rockauto.com/en/catalog/ford,2002,mustang,4.6l+v8,1385670,fuel+&+air,idle+air+control+(iac)+valve,6072 3 Quote
chris r Posted June 30, 2023 Author Posted June 30, 2023 4 hours ago, vk327 said: 2002 ford mustang idle valve is easy to fit and works well https://www.rockauto.com/en/catalog/ford,2002,mustang,4.6l+v8,1385670,fuel+&+air,idle+air+control+(iac)+valve,6072 Thanks! I was hoping something like that existed Quote
JustHarry Posted June 29, 2025 Posted June 29, 2025 @chris r high compression and built for boost arnt often used in the same sentence Quote
chris r Posted June 29, 2025 Author Posted June 29, 2025 I know, it does depend on which fuel is being run though Quote
Raizer Posted June 29, 2025 Posted June 29, 2025 Ooh is that what the blower is for? Water meth might be a good idea. 1 Quote
