mlracing.co.nz Posted November 10, 2015 Posted November 10, 2015 OK, my suggestion based of my frozen environment and many choke affixed vehicles would be first thing in the morning/after it sitting over-night, several hours what-ever. Pull the choke all the way out. Stab the gas three times. Turn the key with an eager foot to give it a little solid gas at about quarter throttle (only IF it catches) then push the choke in slowly whilst holding a little throttle, maybe sit the choke at half for a little bit until it's running a bit better then eventually put it all the way in using your throttle to modulate the idle. If you can get that first catch, the motor will have spun fast enough to let the mechanical fuel pump fill the bowl to continue running or at the very least allow you to attempt to start it a second time with fuel actually there. If however the carb is draining completely due to sitting then none of this matters and your easiest option is simply one of the fuel pumps like Beaver or Snoozin got for their cars, that way you turn the key, it primes the carb, spin it to starter and you're golden. Cool I'll have a look today and see if I can determine if there is fuel in the float bowl still or if it's been drunk by aliens. One wonders if this was an issue right from manufacture and people just dealt with it because it was how it was at the time? Quote
kyteler Posted November 10, 2015 Author Posted November 10, 2015 Look for an signs of leaking around the carb, if it's a minor enough leak from a seal then it'll evaporate fairly fast but likely leave a stain if it's been doing it for a while. Some of the 2BBL Hitachi's have a glass window in the front for checking your float level so you might be lucky if that's the case. If its not it's usually only three screws to remove said cover. The air cleaner assembly will likely be bolted in at least one place to the intake manifold as well as the lid being wingnutted down onto the carb itself. Quote
mlracing.co.nz Posted November 11, 2015 Posted November 11, 2015 Great news everyone, I'm an idiot! Full user error with regard to choke usage. Had a look just now, float has fuel in it so all good. Did the method kyteler suggested and boom fired up without any problem whatsoever. Thanks heaps! Full on manual choke noob here but learning! Yeah this Hitachi has a window I could check the level. Quote
kyteler Posted November 11, 2015 Author Posted November 11, 2015 Glad I could help. Now get the rust sorted and get it legal! 1 Quote
dave123456789 Posted November 11, 2015 Posted November 11, 2015 I fucken hate cold starts after sitting for days... Â My choke is also connected via a speaker wire which isn't helping. different choke setting everyday! Quote
kyteler Posted November 11, 2015 Author Posted November 11, 2015 Hahaha whut?! Sort that shit man, jesus, speakerwire, I don't even.. Quote
dave123456789 Posted November 11, 2015 Posted November 11, 2015 Hahaha whut?! Sort that shit man, jesus, speakerwire, I don't even..  Wait till you see how I set that bad boy, I have a perfectly calibrated bit of no8 wire which is attached to the end of the speaker wire. I pull the choke out till the wire can just catch on the top heater slider line for full choke, other lower slider options on the dash for less choke.  Shes not on the road yet so its just temp... honest!   back on topic, I get fuzzy feeling in my pants over this car. top notch man. your living my dream Quote
mlracing.co.nz Posted November 11, 2015 Posted November 11, 2015 Hahah that choke sounds amazing/terrible 1 Quote
mlracing.co.nz Posted November 20, 2015 Posted November 20, 2015 So I noticed something while test driving it yesterday (I had noticed before but didn't think much of it). When turning to the right at low speed or maybe off throttle/from a stand still it seems to bog or feel like it's being starved of gas for a short bit. Would it be something like the gas in the float bowl is just being pushed to one side where there isn't a jet? Quote
tortron Posted November 20, 2015 Posted November 20, 2015 send me your choke knob and il solder in some new wire  aint no body got time for that/I spent years manually holding my choke open under the bonnet Quote
mlracing.co.nz Posted November 21, 2015 Posted November 21, 2015 send me your choke knob and il solder in some new wire  aint no body got time for that/I spent years manually holding my choke open under the bonnet You talking to me or other guy with choke issue? Pretty sure my choke is working ok Quote
lownslow Posted December 4, 2015 Posted December 4, 2015 Looking sharp! Sometimes I use a smear of grease to mask things when I paint fiddley bits. Then just paint and wipe the grease off after. Quote
mlracing.co.nz Posted December 4, 2015 Posted December 4, 2015 Looking sharp! Sometimes I use a smear of grease to mask things when I paint fiddley bits. Then just paint and wipe the grease off after. That's not a bad idea. Initially I was thinking of something like vasoline or similar then I got lazy/thought I was better than I actually turned out to be haha Quote
flyingbrick Posted December 13, 2015 Posted December 13, 2015 Nah just fill it in with heaps of layers of paint / nail polish /whatever and then when dry use a v fine abrasive on a flat block to clean off anything higher than the sides Quote
mlracing.co.nz Posted December 13, 2015 Posted December 13, 2015 Nah just fill it in with heaps of layers of paint / nail polish /whatever and then when dry use a v fine abrasive on a flat block to clean off anything higher than the sides I reckon I'll just leave it as is until I eventually maybe get around to refurbing the whole grille area. Actually when I was showing someone the car earlier today it looks fine from about a foot away and chances of looking super close are slim.. there are much more important things to get onto first haha 1 Quote
Willdat? Posted January 3, 2016 Posted January 3, 2016 Your Civic isn't an ex-Nelson car is it? A mate owned something similar around 2001. Quote
mlracing.co.nz Posted January 3, 2016 Posted January 3, 2016 Your Civic isn't an ex-Nelson car is it? A mate owned something similar around 2001. Maybe, I got it from somewhere like Taranaki, can't recall exactly where now. Was in a sad state when I got it.. manage to get it back on the road. Still not flash haha but it's a hoot to drive as well Quote
Willdat? Posted January 4, 2016 Posted January 4, 2016 Maybe, I got it from somewhere like Taranaki, can't recall exactly where now. Was in a sad state when I got it.. manage to get it back on the road. Still not flash haha but it's a hoot to drive as well I'll see if I can dig up some photos of it and we'll see if it's the same - had a pretty hard life. Was the fastest car I'd driven until a friend got a WRX STi Type RA. Quote
Swampo Posted January 4, 2016 Posted January 4, 2016 How'd you get to Rocky Auto? Very nice. Good to see those mats in that Rocky Auto car Quote
