dozydesmond Posted October 24, 2014 Author Share Posted October 24, 2014 found this if anyone is interested. its all about rebuilding and tuning kent crossflowshttps://www.dropbox.com/s/cvtdf7q59chez2a/Ford-s-Kent-Crossflow-Engine.pdf?dl=0 1 Quote Link to comment Share on other sites More sharing options...
BDA780 Posted October 24, 2014 Share Posted October 24, 2014 Currently my favorite project on here. Gonna watch this intently. I purchased a 1600cc block of Trademe from a guy who claimed it would most likely run. After removing the head it was in a similar state to this full of water but with early combustion chamber heads. Needless to say, we are still proceeding with the rebuild using the same block. Keep the update flowing! Quote Link to comment Share on other sites More sharing options...
dozydesmond Posted October 24, 2014 Author Share Posted October 24, 2014 Hahahaha glad to hear it if you have any tips or ideas please share them  You might also find the book i found helpful if you're rebuilding a crossflow (see link above)  (I'm only 18 and still kinda guessing/googling/asking about this kinda thing ae ) 1 Quote Link to comment Share on other sites More sharing options...
pusherman Posted October 24, 2014 Share Posted October 24, 2014 This motor will live. Strip it and clean the bollocks out of it and it will purr like a smoky old wreck but it will run Quote Link to comment Share on other sites More sharing options...
dozydesmond Posted October 24, 2014 Author Share Posted October 24, 2014 Gunna stick a sidedraft on it with two Weber 45 DCOE's or two Weber 42 DCOE's, stick a 3/4 race cam or a 244k rally cam in it, port and polish the crud out of it, oversize the pistons, stick a 1.3 head on it, and stick it in a custom-built rally car (although, i might stick it in my '94 laser wagon to run it in first so look out chch) Quote Link to comment Share on other sites More sharing options...
crustywhip Posted October 24, 2014 Share Posted October 24, 2014 i agree, it will run. they arent the most complicated of engines so as long as every thing moves it will be fine. im lucky enough to have grown up with old fords and we used to trash the shit out of them and loved every minute of it. Quote Link to comment Share on other sites More sharing options...
dozydesmond Posted October 24, 2014 Author Share Posted October 24, 2014 well felix, looks like you and the chch lot WILL owe me fish n chips with coke after all ;) 1 Quote Link to comment Share on other sites More sharing options...
kyteler Posted October 24, 2014 Share Posted October 24, 2014 FYI, this motor was locked solid when I got it. Hadn't been run in over 20 years. I didn't even put fresh petrol in.. Quote Link to comment Share on other sites More sharing options...
dozydesmond Posted October 24, 2014 Author Share Posted October 24, 2014 Anyway, progress as of yesterday:  Engine is fully stripped now apart from the block plugs,the pistons (which need some, shall we say, 'persuasion' *grins evilly and cackles maniacally), and the valves. bores are soaking in a 50/50 mix of diesel/crc to loosen the rust and, consequently, free the pistons  The #1 cylinder, which had a valve open evidently The near-new timing-chain Big-Ends and Crank Bearings SLUDGE GALORE (Weighed it all, came in at approx 2 kg of sludge, not all of is shown here tho) 1 Quote Link to comment Share on other sites More sharing options...
Raizer Posted October 24, 2014 Share Posted October 24, 2014 stick a 1.3 head on it I'm assuming your after higher compression? You would want to use 1.3 pistons and stick with your 1.6 head. A 1300 head will just result in the same compression with smaller valves. Oh and why not a â…” race cam? Quote Link to comment Share on other sites More sharing options...
dozydesmond Posted October 24, 2014 Author Share Posted October 24, 2014 either a 244k rally cam or a 3/4 race cam, 2/3 wont really be much use on gravel i don't think 1 Quote Link to comment Share on other sites More sharing options...
dozydesmond Posted October 24, 2014 Author Share Posted October 24, 2014 and i wont fit eh 1.3 pistons is, as it is i have to bore the cylinders out to get rid of the rust pits Quote Link to comment Share on other sites More sharing options...
ajg193 Posted October 24, 2014 Share Posted October 24, 2014 Looks like the water almost protected the bottom end by pushing the oil up. Quote Link to comment Share on other sites More sharing options...
dozydesmond Posted October 24, 2014 Author Share Posted October 24, 2014 That it did, which makes my life eaiser Quote Link to comment Share on other sites More sharing options...
Rookie Posted October 24, 2014 Share Posted October 24, 2014 You will need to buy new pistons when you bore it, so buy 1300 pistons or it will be a slug. Quote Link to comment Share on other sites More sharing options...
dozydesmond Posted October 25, 2014 Author Share Posted October 25, 2014 anyone feel like donating towards re-sleeving this thing... Quote Link to comment Share on other sites More sharing options...
punkoutnz Posted October 25, 2014 Share Posted October 25, 2014 anyone feel like donating towards re-sleeving this thing... Â You can get pistons all the way up to 90 thou for these things. Measure the bore you have, chances are you wont need to go more than one, maaaaybe two sizes up (you'll probably be fine with 20 thou, but may have to go 40 thou). Â Unless you're bored out to 90 thou already you wont need to resleeve that block. Quote Link to comment Share on other sites More sharing options...
dozydesmond Posted October 25, 2014 Author Share Posted October 25, 2014 its on 80.5 but its already been sleeved, those sleeves are screwed Quote Link to comment Share on other sites More sharing options...
ajg193 Posted October 25, 2014 Share Posted October 25, 2014 Let's see some pictures Quote Link to comment Share on other sites More sharing options...
dozydesmond Posted October 25, 2014 Author Share Posted October 25, 2014 I'll take pics tomorrow after work Quote Link to comment Share on other sites More sharing options...
