dozydesmond Posted October 21, 2014 Author Share Posted October 21, 2014 Day One, 21st October, 2014: Removed plugs and fired CRC down the bores, removed the pushrods and rockers, removed the intake and exhaust manifolds, removed the water pump, removed the oil filter, removed the vacuum system(?). Drained the oil, and got 4l of water out, 1l of oil and quite a bit of sludge Also, discovered the #1 cylinder was choc full with water ^Build Loggy enough for you? ^ 7 Quote Link to comment Share on other sites More sharing options...
dozydesmond Posted October 22, 2014 Author Share Posted October 22, 2014 all stripped out now, pics to come soon Quote Link to comment Share on other sites More sharing options...
Big Louie Posted October 23, 2014 Share Posted October 23, 2014 Might have some leftover parts you can use from my rebuild if you need anything. Quote Link to comment Share on other sites More sharing options...
dozydesmond Posted October 23, 2014 Author Share Posted October 23, 2014 What have you got??? and how much do you want for them???(sorry, you just made me a little excited there...) Quote Link to comment Share on other sites More sharing options...
dozydesmond Posted October 24, 2014 Author Share Posted October 24, 2014 filled the bores with half a can of crc/diesel mix. now just to wait for a week or two 2 Quote Link to comment Share on other sites More sharing options...
felixx Posted October 24, 2014 Share Posted October 24, 2014 good work, I have a grease gun and some grease you could use, if you made an adaptor out of a spark plug (involves replacing head) Josh Helm did this and it worked Quote Link to comment Share on other sites More sharing options...
dozydesmond Posted October 24, 2014 Author Share Posted October 24, 2014 grease gun and grease for? (your link doesn't appear to be showing) Quote Link to comment Share on other sites More sharing options...
ajg193 Posted October 24, 2014 Share Posted October 24, 2014 Pump it into the cylinder when you have the head on, it will force the piston down. Quote Link to comment Share on other sites More sharing options...
dozydesmond Posted October 24, 2014 Author Share Posted October 24, 2014 ohhh thats a good idea. ill have to try that Quote Link to comment Share on other sites More sharing options...
dozydesmond Posted October 24, 2014 Author Share Posted October 24, 2014 has anyone got an engine stand i can borrow? or at least some RHS steel or pipe so i can make one? Quote Link to comment Share on other sites More sharing options...
Benno Posted October 24, 2014 Share Posted October 24, 2014 To be honest, it looks to me a lot like all of the bores will be pitted from rust anyway, needing bored out and new oversize pistons. You might still need to soak it to help to get them out, but I would not have any problems with just bashing the shit out of the pistons with a hammer or something until they come free Quote Link to comment Share on other sites More sharing options...
dozydesmond Posted October 24, 2014 Author Share Posted October 24, 2014 Im doing exactly that. except using a piece of wood between said hammer and said piston Quote Link to comment Share on other sites More sharing options...
kyteler Posted October 24, 2014 Share Posted October 24, 2014 Smash the piston with the hammer, who cares, you'll likely need to replace them anyway. Or, put a powerbar on the crank and try turn it instead of smashing pistons. Quote Link to comment Share on other sites More sharing options...
Benno Posted October 24, 2014 Share Posted October 24, 2014 If you haven't already taken the crank out, I would do so before hammering away on the pistons, it will be a lot easier to free one up then 4 together. Or try kytelers strategy first perhaps Quote Link to comment Share on other sites More sharing options...
dozydesmond Posted October 24, 2014 Author Share Posted October 24, 2014 Cranks already out. my plan of attack is 50/50 diesel/crc and fill the bores from the bottom, leave for a couple of day (currently only been 1-2). flip over and fill the tops with the same mixture then leave for similar period of time. after that, smash them out with a block and hammer (might be able to get something for pistons u see ) Quote Link to comment Share on other sites More sharing options...
dozydesmond Posted October 24, 2014 Author Share Posted October 24, 2014 and the only pitted bore would be #1 cylinder Quote Link to comment Share on other sites More sharing options...
felixx Posted October 24, 2014 Share Posted October 24, 2014 how about lighting the diesel to get it to heat up and expand and break any corrosion joints 1 Quote Link to comment Share on other sites More sharing options...
dozydesmond Posted October 24, 2014 Author Share Posted October 24, 2014 not sure if i should take you seriously, or if you just want me to ruin my block so u get free food... 1 Quote Link to comment Share on other sites More sharing options...
felixx Posted October 24, 2014 Share Posted October 24, 2014 Im serious Quote Link to comment Share on other sites More sharing options...
dozydesmond Posted October 24, 2014 Author Share Posted October 24, 2014 ok... ill try it on one cylinder first... Quote Link to comment Share on other sites More sharing options...
