dave123456789 Posted June 18, 2014 Share Posted June 18, 2014 Is it all good to run 5 instead of 6 cause one snapped? They are in groups of 2. Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted June 18, 2014 Share Posted June 18, 2014 Lol ideally no. Remove the snapped one. Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted June 18, 2014 Share Posted June 18, 2014 nope. Quote Link to comment Share on other sites More sharing options...
dave123456789 Posted June 18, 2014 Author Share Posted June 18, 2014 Balls. I tried all day to get it out, one more attempt tomorrow otherwise ill rip flywheel out and go engineers Quote Link to comment Share on other sites More sharing options...
sidewaysickness Posted June 18, 2014 Share Posted June 18, 2014 What methods did you use to attempt to get it out? Quote Link to comment Share on other sites More sharing options...
dave123456789 Posted June 18, 2014 Author Share Posted June 18, 2014 Drilled it and tried a easy out. Then a hammer and a screw driver. Then bigger easy outs. Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted June 18, 2014 Share Posted June 18, 2014 Lol engineers are gonna love you! All these attempts have just made it twice as hard for them. 1 Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted June 18, 2014 Share Posted June 18, 2014 Lol you know how they say there are no stupid questions.............. Quote Link to comment Share on other sites More sharing options...
dave123456789 Posted June 18, 2014 Author Share Posted June 18, 2014 Lol engineers are gonna love you! All these attempts have just made it twice as hard for them. Well it didnt look that hard so thought could be myself. Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted June 18, 2014 Share Posted June 18, 2014 Nah it will be sweet mate. Just take it to a machine shop not a general engineer. Quote Link to comment Share on other sites More sharing options...
ajg193 Posted June 18, 2014 Share Posted June 18, 2014 Just weld the top half of the bolt onto the new pressure plate. Insta-balance. [ThumbUp] I'm sure they will be able to get it out using some sort of ultrasonic machine or something. 1 Quote Link to comment Share on other sites More sharing options...
dave123456789 Posted June 18, 2014 Author Share Posted June 18, 2014 Is there anywhere near pakuranga? Or should I just ringing around tomorrow morning? Quote Link to comment Share on other sites More sharing options...
Rookie Posted June 18, 2014 Share Posted June 18, 2014 FYI, easyouts have a very limited use, unless you snapped the bolt by over torqing it when you were putting it in then that are many other options for getting it out. 1 Quote Link to comment Share on other sites More sharing options...
dave123456789 Posted June 18, 2014 Author Share Posted June 18, 2014 Yea so far easy outs haven't done shit. I didnt over torque it was suppose to be 15lbs but it snapped not long after it was snug. I have got all new bolts to replace them all just got to get this out. Quote Link to comment Share on other sites More sharing options...
Bling Posted June 18, 2014 Share Posted June 18, 2014 Is it flush with the flywheel? Could try using a nail punch to turn it to undo it. Get some CRC spray in there and lube it up a bit. Just make sure you give it a really good clean if you do so. Wouldn't want anything on it to affect the clutch material. Lol you know how they say there are no stupid questions.............. Considering the other option would have been to just run 5 bolts. Asking turned out to be a good idea. 1 Quote Link to comment Share on other sites More sharing options...
dave123456789 Posted June 18, 2014 Author Share Posted June 18, 2014 Na it's about 5mm deep. I have already drilled it and messed with it so its coming off to go engineer so they can do their thing. Quote Link to comment Share on other sites More sharing options...
Nominal Posted June 18, 2014 Share Posted June 18, 2014 Got a MIG? weld a nut onto the end of the broken bit (easy enough if the flywheel is cast). Quote Link to comment Share on other sites More sharing options...
SOHC Posted June 18, 2014 Share Posted June 18, 2014 its about $2.00 to get a broken bolt spark eroded Quote Link to comment Share on other sites More sharing options...
Ridal Posted June 18, 2014 Share Posted June 18, 2014 If its easy to get a drill square on it you should be able to drill it out enough to start a tap to get the last of the thread. Well that's what I did when a bolt seized and snapped in my bonnet and it worked. Quote Link to comment Share on other sites More sharing options...
dave123456789 Posted June 18, 2014 Author Share Posted June 18, 2014 Got a MIG? weld a nut onto the end of the broken bit (easy enough if the flywheel is cast). I should done that first but cause I was feeling lazy I thought it could be drilled out and use an easy out while it was still attached to engine. Mig is at my place not where the car is so would have had to pull it apart. Anyway, It's at an engineers now, they going to mill it out and helicoil it and also give the face a clean up since it been sitting for a year or so and has a bit of surface rusty shit on it. Said an hour work max so here's hoping its half that. Expensive fuck up Quote Link to comment Share on other sites More sharing options...
