bmxnz11
bmxnz11's mk2 escort van
Luckily its still got the ID tag but hasn't come up trumps.
It's 1st gear that's different. It's to help take off with 3.54 diff escorts.
You don't want to sell box do you? :)
Not this one sorry, will need all the help to push my heavy van around! If you are keen i could ask a mate of mine. Hes getting rid of a lot of escort gear at the moment.
Share this post
Link to post
I've lined up a type 9 5spd for the van but I won't be getting that until the current owner sorts out his new gearbox. It's currently in an escort and has had the shifter moved to line up with the original shifter hole in the tunnel. I know it requires a bit of massaging around the bell housing area to make it fit, but I don't know where exactly. Does someone have a spare 5spd or or even the bell housing to borrow so I can make the adjustments before I spray colour. Or even if it's just a few photos with the areas that need touching. Cheers
Share this post
Link to post
Vans have the big "auto" spec tunnel from factory, from memory you should be able to get a T9 in there without massaging.
Share this post
Link to post
Ha I new about the auto tunnels but didn't realize the Vans had them. Cheers for that. Good to know.
Share this post
Link to post
I still had to knock mine out a bit though, only a little bit. And the shifter is further back so you need to move the shifter hole back and modify the brace underneath
Share this post
Link to post
Was it just around the bell housing area you had to knock? Yeah the 5spd I'm getting is currently running in an escort and has had the shifter moved forward to use the original shifter hole.
Share this post
Link to post
1/3 back from the bellhousing flange left side from memory. It was only a few love taps with a solid rubber mallet, didn't even damage the paint. My engine mounts are very soft though and it touched when they flexed.
Share this post
Link to post
That colour suits it perfectly. The orange and black will be amazing. It also looks like a sweet finish too. Kudos for those skills.
Share this post
Link to post
