avjoe Posted August 5, 2013 Share Posted August 5, 2013 just incase anyone has any questions ? haha //oldschool.co.nz/index.php?/topic/39649-joes-84-honda-city-churbo/#entry1139015 Quote Link to comment Share on other sites More sharing options...
Hachi-ichi Posted August 5, 2013 Share Posted August 5, 2013 MK III + huge low down. best T2 Quote Link to comment Share on other sites More sharing options...
4age Posted August 5, 2013 Share Posted August 5, 2013 oh hi dere. Buy my crashed one and tube frame plz. Does your digital boost gauge work? Apparently these poo themselves most of the time. Mine still works, i love that bar graph going up and down haha Quote Link to comment Share on other sites More sharing options...
avjoe Posted August 5, 2013 Author Share Posted August 5, 2013 i has mk3's! and i need moar low! ha yes sean FTW boost gauge is working give me your city and you wont be sorry Quote Link to comment Share on other sites More sharing options...
avjoe Posted August 5, 2013 Author Share Posted August 5, 2013 does anyone know the specific type of mk3's these are? 13" with curved spokes. Quote Link to comment Share on other sites More sharing options...
Testament Posted August 5, 2013 Share Posted August 5, 2013 Nice, I like these why ported throttle body? probably expensive and not going to change much? also why rodeo turbo? bolt on? how much bigger are they? I'm trying to remember what they have, super tiny ihi if I remember right? will probably need to start thinking about bigger injectors also? Quote Link to comment Share on other sites More sharing options...
phatt20 Posted August 5, 2013 Share Posted August 5, 2013 done a series one city turbo up for the ex mrs bout 14 years ago, s4 rx7 intercooler front mounted, bov off the same car, 2.5' stainless exhaust front to back, screamer pipe, 13psi. (fuel cut at 15) thing was a fucking animal, used to peel out crxs and fxgts back in the day. was ultra reliable too , had a brutal hiding and all i ever broke was the clutch, and it was just worn out. was great fun blowing the doors off stuff while keeping that 'ethel and mavis off to bingo night' feel. . Quote Link to comment Share on other sites More sharing options...
avjoe Posted August 5, 2013 Author Share Posted August 5, 2013 Port the tb because the factory one is tiny and when I set it up to 20psi itll help alot Holden rodeo because its pretty straight forward pretty much just need to mod the actuator and its still small because its only a 1.2 with super low comp and others have had good results from them. If I find (or if someone could help) find an after market ball bearing turbo that would be great but its hard to find one small enough hahahaha Yes injectors are on the cards. Looking at ones from a honda prelude h22a either the 345cc's or the 290's and thatll be more then enough Quote Link to comment Share on other sites More sharing options...
Testament Posted August 5, 2013 Share Posted August 5, 2013 how small is tiny for the t/b. not worth swapping one from civic or something? I gues bother to adapt somethign vs. cost vs. benefit. this said increasing the boost doesnt really mean you need a bigger t/b its only if you increase the volume flow, with more rpms, bigger cam, better flowing heads/manifolds that makes the t/b become a restriction unless the factory really made it well undersized to start with. If you were looking aftermarket I would look at the small journal bearing garretts they are pretty good value and some of the most efficient turbos you can buy which = less heat = free hp's Quote Link to comment Share on other sites More sharing options...
phatt20 Posted August 5, 2013 Share Posted August 5, 2013 from memory the throttle body was a two stage affair with one tiny butterfly and one slightly less tiny one? Quote Link to comment Share on other sites More sharing options...
Testament Posted August 5, 2013 Share Posted August 5, 2013 ohhhh ok yeah - for the cvcc stratified combustion chamber bussiness, I forgot about that Quote Link to comment Share on other sites More sharing options...
avjoe Posted August 5, 2013 Author Share Posted August 5, 2013 Yeah bastard of things. Tuning is a bitch too. Almost impossible to chip do im just going to use a progressive fuel reg with a bleed valve. Its rough but about all you can do. Unless I go for one of those hks piggy backs. Yeah you'll need a fuel cut defender to get any higher then 15psi sadly. Hoping to regrind the cam in time too so that will put a little more acid on the tb Quote Link to comment Share on other sites More sharing options...
SHGWAG Posted August 6, 2013 Share Posted August 6, 2013 Hi Joe, do you have any photos of the interior? Like the Gear 'Knob'......? 1 Quote Link to comment Share on other sites More sharing options...
Archetype Posted August 6, 2013 Share Posted August 6, 2013 Oh man, a silver Turbo II with black interior is my dream car. Ok, maybe not my dream car, but I like it a lot. Quote Link to comment Share on other sites More sharing options...
avjoe Posted August 7, 2013 Author Share Posted August 7, 2013 Hi Joe, do you have any photos of the interior? Like the Gear 'Knob'......? ...... yes lulz Will put pics up of the new wheel tonight with the gear..... 'knob' lol Quote Link to comment Share on other sites More sharing options...
Snoozin Posted August 7, 2013 Share Posted August 7, 2013 does anyone know the specific type of mk3's these are? 13" with curved spokes. They're a MK3S. Quote Link to comment Share on other sites More sharing options...
yetchh Posted August 7, 2013 Share Posted August 7, 2013 Had an hks piggy back on a T2 I used to own.. thing was pretty mental, have to watch the cvcc cam tho as they have a tendency to wear so you lean out and burn a valve or two.. but I guess if your gonna do a regrind they could re face and harden it.. Quote Link to comment Share on other sites More sharing options...
avjoe Posted August 7, 2013 Author Share Posted August 7, 2013 Had an hks piggy back on a T2 I used to own.. thing was pretty mental, have to watch the cvcc cam tho as they have a tendency to wear so you lean out and burn a valve or two.. but I guess if your gonna do a regrind they could re face and harden it.. Oh yeah nice man. How hard was it to tune? Yeah ccvc is a cunt They're a MK3S.Thanks man. Ive Googled mk3s and theres no match ay. Talked to a heap of people and they reckon its a presessor to the mrk3s. But not actually a mk3s? Haha I dont know. Quote Link to comment Share on other sites More sharing options...
Brock-Lee Posted August 7, 2013 Share Posted August 7, 2013 try mk3-s Quote Link to comment Share on other sites More sharing options...
yetchh Posted August 7, 2013 Share Posted August 7, 2013 Dunno, wasnt tunable had preset fuel and ignition curve changes.. wound the boost to about 18 and kicked arse.. Oh yeah nice man. How hard was it to tune? Yeah ccvc is a cunt CVCCs' awesome bro.. almost a hundy hp per liter.. if my Cleveland was that good I'd be doing 11's D Quote Link to comment Share on other sites More sharing options...
