Yeah it kind of sits around 1.034ish, jumps between  .98 and 1.04. Sitting at 14 Initial and 32 all in around 2800,  power it drops down to .78-.8.....
What about decel? I would imagine you'd want no gas being I injected at all so lambda 1.2..
  • Replies 2.4k
1 minute ago, ajg193 said:
I find no difference in performance between 1 (14.7:1) and 1.23 (18:1) at 100 km/h cruise in Starlet. But the reported fuel consumption drops almost 20% when lean.
Starts to jerk if I go too high..
What ECU are you using?
You might have an option for fuel cut decel you can turn on, shuts off injectors completely.
Does your link system have auto tune?
Just aim for lambda = 1 for any cruise settings (40-70 kPa, 2000 - 3500 rpm). You can adjust it after you have everything else set.
0.85-0.90 above 90 kPa everywhere
and maybe a bit leaner for high vac everywhere, but 1 should be fine
Around idle region 0.90-0.95 is good
Yeah, you could possibly get around that issue by advancing the timing a bit so it has more time to burn. But each engine is different at cruise settings.
Do you know if your ecu lets you tune by just adjusting your desired AFR once you have your volumetric efficiency table dialed in?
Eg on the megasquirt once it is fully tuned all I have to do is say "I want 18:1 at this cruise region" and it automatically changes to that without having to check what the actual afr is and adjust stuff.
Also, my AFR values could be complete bullshit as I am running a chinese LSU 4.9. But I think they are pretty good from the way the ECU gets the predicted fuel for each AFR value pretty much right.
 Link g1 lemv5
Fuel use on deceleration is pretty minimal anyway. So fuel savings by enabling it won't really add up to much, but they do make you feel superior to people running carbs.
Running stoich under engine braking will use less than 10 cc/min.
Driving at 100 km/h will use 100 cc/min or more.
Idling will use around 15-20 cc/min
Actually I do have an overrun setting, just haven't set decel kpa yet..
Every little bit you can do all adds up eh. Plus better engine braking/no fumes on downhills. Well at least around our place with many hills it certainly helped on the v6.
We ran the Viva on the v6 up to the nats at rotorua(?) with no fuel cut. Then turned on fuel cut for trip home (were still learning things) and it gave a very noticeable drop in consumption.
Because v6.. Not tiny 4 pot
  • Haha 1
I'm not saying it's not worth doing (I have mine set up to cut fuel). Definitely good regarding fumes.
But the fact of the matter is that you can only get so much air past a closed throttle - it will use essentially the same amount of air as it would at idle. One minute of driving at 100 is about the same fuel consumption as 10 minutes of going down hills if you don't cut the fuel.
The reduction in fuel consumption in your case was probably mainly attributable to changes in driving style and other changes you made to the tune on the trip. Did you go on the desert road both ways? I've always found my fuel consumption to be significantly higher on the desert road (higher altitude, so lower engine power and operating in less efficient revs/load) compared to driving closer to sea level.
I'm just been lurking this thread for ages, haven't felt like I've had too much to offer but there is something that I feel maybe relevant to this "off throttle" stuff is that the "off throttle" area of the map is diabolical to get tuning accurate for using a lot of the popular tuning methods when dealing with VE tuning.  As such, most of the maps I see I feel are likely to be dumping excessive (like not just slightly too much, but massively) amounts of fuel in some of the very low load areas of the map and people may or may not be aware that their map is doing that, it kindof feels to me like that "over-run fuel cut" feature could almost be seen as a band aid to this kind of thing.
I don't know if anyone has played with modern Ford ECUs or not, but they don't run conventional fuel maps/VE tables.  Instead, they require a slope and offset to be defined for airflow vs pressure at each rpm and essentially assume that the airflow can overall be defined a increasing as a linear function vs manifold pressure.   There are other corrections to "tidy up" things, but the basis of their mass airflow calculation centres on that.
The interesting thing about it, is the offset is defined by "Manifold pressure at 0 airmass" - which is an interesting one.  Essentially the assumption (or reality...) is that you will not get any fresh airflow through your engine below a given manifold pressure at any given rpm, and it probably goes without saying that the manifold pressure will not be the same for each rpm.   If you do a scatter plot of rpm x map after a long session of driving you can see that even with the throttle closed the MAP will consistently stop at a minimum amount, and you get a clear shape through out the rpm range - that point may not be the zero airflow point, but it still paints an interesting picture.
Any numbers >0 in the fuel map which are at the 0 airflow manifold pressure, or below that will be infinitely surplus to requirement.   Any numbers in the area of the 0 airflow part of the map which are "close" to what the typical cruise load VE numbers are  going to be way in excess of what they need to be, as you get close to the 0 airflow pressure the VE numbers should steeply drop off.
Here's an example calculated by Paul Yaw for one of his rants on his company blog page:  (reference : http://injectordynamics.com/articles/shelby-gt500/ - search for "just maths and physics" and btw, NSFW)
VEvMAP
Most VE maps I see don't end up looking anything like this, but that is usually not a problem thanks to overrun fuel cut - or the fact that the engine never drews enough of a vacuum to really be too much of a problem.   I do try and do my best to get this kind of thing sorted out, and have actually played with just not running overrun fuel cut and instead having the fuel table drop away and zero out at the areas I determine are likely to be "0 airflow" - which granted relies on higher resolution map spacings than you normally see <40kpaA.  Guys I've done it for have not complained about fuel consumption and I've actually had it reported back "this is better off/on throttle than stock?!?!"... like unprompted, maybe placebo stuff making to want to find ways of being nice to their tuner, but one way or another at least my fucking around with this has been interesting.
What I don't like about the magical "injector off at x map" thing is that you have to tinker around to progressively phase timing in or out to try and alleviate any jerkiness if the injector off thing happens at an inconvenient point, and of course the pressure where shutting the injectors off at may be optimal at different pressures at different rpm - as above.   Of course there is another thing, if you are at air speeds where wall wetting is a big factor and then you shut the injectors off, you lose your puddle... so when you turn them on again you need to rebuild that as well.   Keeping this balance nice at air speeds could arguably make it nicer to drive and also save some fuel that could be wasted from the driver ending up driving around weird transient torque things.
TL;DR?  But just thoughts/observations/experiments I've played with and still ponder on, sorry if it's actually no new news - I was triggered by "fumes" and "big difference in fuel consumption"  :)
  • Like 8
  • Sad 1
Just to post another graph, because, well, that's what I do.
This is a plot of my engine, RPM vs MAP and then the colour scale is MAF airflow.
So the blue line is basically zero airflow point mentioned above.
Definitely not blanketly happening at the same KPA value throughout rev range.
It's interesting to see how it looks like some approximation of the inverse of the torque curve.
I guess that makes sense - at the RPM where the engine is trying harder to gulp in more air, it's going to generate a stronger vacuum.
I know I keep banging on about it, but it's amazing how much more resolution and ease of tuning you can get with a MAF in some areas.
With a MAF as your load axis, when you are tuning that blue line its just a flat straight line across the bottom row of your table.
Elegance through simplicity.
13 hours ago, BlownCorona said:
have you seen KPRs 4ages? his unicorns have defiantly seen some shit...
I've been aware of his shenanigans 4ages ;)
  • Haha 2
Right got a few questions for the gurus from a diy efi noob
basics - ems stinger ecu
setup for wasted spark 3 ignition channels thru Mitzi j723t igniter and Mazda/ford coil pack for v6
36- 1 crank trigger and vr. ( magnetic ) pickup
I have power in the right places and tachometer on laptop shows steady 200rpm cranking so theoretically the sensor and settings for crank trigger are working
rising rate ignition and dwell settings are as set for Mitzi ignitor
tested ignitor and coil resistances and connections and wiring
don’t seem to be getting spark visible at plugs or on lead tester but have had a few chuffs on engine start ether
stinger software has an ignition simulator but it won’t seem to open on laptop
any ideas ? I’m kinda at the stage of fuck it buy a link atom g4x ...
