RUNAMUCK Posted February 17, 2014 Share Posted February 17, 2014 Have you kitted the carb yet? They run like a bag of hairy arseholes if the gasket on the top of the bowl fucks out. Quote Link to comment Share on other sites More sharing options...
Beaver Posted February 17, 2014 Share Posted February 17, 2014 nah havnt kitted it. Quote Link to comment Share on other sites More sharing options...
AllTorque Posted February 18, 2014 Share Posted February 18, 2014 I'd be checking for intake manifold gasket leaks. Have you set the tappets on the new motor? Quote Link to comment Share on other sites More sharing options...
Beaver Posted February 18, 2014 Share Posted February 18, 2014 Its a new gasket, whats the best way to check? Yeh I checked the tappets, they were pretty much spot on. Im not 100% on my tehnique mind you.... Quote Link to comment Share on other sites More sharing options...
Truenotch Posted February 18, 2014 Share Posted February 18, 2014 Squirt brakleen around the manifold and see if the teens change. Edit - teens is an autocorrect for revs, but it's lol so I'll leave it. Quote Link to comment Share on other sites More sharing options...
KKtrips Posted February 18, 2014 Share Posted February 18, 2014 So wait - wut - you have zero vacuum at idle but you gain vacuum when you open the throttle? Quote Link to comment Share on other sites More sharing options...
AllTorque Posted February 18, 2014 Share Posted February 18, 2014 Did you make sure ALL the old gasket was off the head and manifold? To check you can run a slow garden hose over it while idling and you will hear a sucky sucky. Was the gauge vacuum hose a snug fit over the nipple? You should be able to feel it sucking on your finger if you pull the vacuum hose off and cover it with your finger. Might also be worth doing a compression test, being an unknown motor. Quote Link to comment Share on other sites More sharing options...
AllTorque Posted February 18, 2014 Share Posted February 18, 2014 Another thought. You haven't tapped into a distributor advance port have you? Quote Link to comment Share on other sites More sharing options...
Spencer Posted February 18, 2014 Share Posted February 18, 2014 Lol. Quote Link to comment Share on other sites More sharing options...
Beaver Posted February 18, 2014 Share Posted February 18, 2014 Squirt brakleen around the manifold and see if the teens change. Edit - teens is an autocorrect for revs, but it's lol so I'll leave it. I loled. WIll give this a whirl. So wait - wut - you have zero vacuum at idle but you gain vacuum when you open the throttle? Zero at idle, zero at revs, but a blip of vacuum (just over 10) when the throttle slams shut Did you make sure ALL the old gasket was off the head and manifold? To check you can run a slow garden hose over it while idling and you will hear a sucky sucky. Was the gauge vacuum hose a snug fit over the nipple? You should be able to feel it sucking on your finger if you pull the vacuum hose off and cover it with your finger. Might also be worth doing a compression test, being an unknown motor. Yeh I gave the face a good clean up before fitting new gasket and carb. Have compression tested the motor and its 150-160 on all four. Vacuum line is snug as a bug in a rug. Another thought. You haven't tapped into a distributor advance port have you? Nah just took out a blanking plug near the base of the carb (but on the manifold runners intself) and screwed in a threaded nipple. Quote Link to comment Share on other sites More sharing options...
Beaver Posted February 18, 2014 Share Posted February 18, 2014 Lol. What you loling about fooooool Quote Link to comment Share on other sites More sharing options...
Nominal Posted February 18, 2014 Share Posted February 18, 2014 Is the gauge any good? Suck it and see! Quote Link to comment Share on other sites More sharing options...
Beaver Posted February 18, 2014 Share Posted February 18, 2014 Yeh i can suck on it and make vacuum, but that doesnt mean its accurate I guess Quote Link to comment Share on other sites More sharing options...
KKtrips Posted February 18, 2014 Share Posted February 18, 2014 Gauge sounds fucked. Bring it to the lockup on Thursday night and we can try it on the Commy to see how it compares to the factory Commy gauge. Quote Link to comment Share on other sites More sharing options...
Spencer Posted February 18, 2014 Share Posted February 18, 2014 Just having a lol, if its not on the dizzy advance port you have a epic vacuum leak or fucked gauge. 1 Quote Link to comment Share on other sites More sharing options...
Beaver Posted February 18, 2014 Share Posted February 18, 2014 Gauge sounds fucked. Bring it to the lockup on Thursday night and we can try it on the Commy to see how it compares to the factory Commy gauge. Will probably be away thursday but will see. Quote Link to comment Share on other sites More sharing options...
AllTorque Posted February 18, 2014 Share Posted February 18, 2014 Gauge sounds fucked. Bring it to the lockup on Thursday night and we can try it on the Commy to see how it compares to the factory Commy gauge. Whoa. Factory vacuum gauge. So fancy. 1 Quote Link to comment Share on other sites More sharing options...
KKtrips Posted February 18, 2014 Share Posted February 18, 2014 Or as someone said the other day "WOAH you have a backwards rev counter - TRIPPY!" That story may have been embellished slightly but was mostly true... Quote Link to comment Share on other sites More sharing options...
Beaver Posted February 18, 2014 Share Posted February 18, 2014 rofl it was even worse. I was all, ahhh KK your tacho is fucked, its going backwards Quote Link to comment Share on other sites More sharing options...
KKtrips Posted February 18, 2014 Share Posted February 18, 2014 Oh yeah - it was you wasn't it... LOL I forgot who it was that said that. Quote Link to comment Share on other sites More sharing options...
