Jase Posted August 29, 2012 Share Posted August 29, 2012 just after ideas want to ditch the heater circuit due to firewall shift, was thinking of running twin 12v blowers (hairdryers, the guts at least) for the demisters unless theres other options out there opinions> Quote Link to comment Share on other sites More sharing options...
KKtrips Posted August 29, 2012 Share Posted August 29, 2012 You can get some sweet demister heater fans from marine suppliers - a lot of the race car guys use them for helmet coolers and demisters also. Like this http://www.ucosm.com/helicopter/cabin_heat.htm Quote Link to comment Share on other sites More sharing options...
drtdvl Posted August 29, 2012 Share Posted August 29, 2012 You can buy inline electric fan heaters with ducting for cars. I was looking at the in place of my heater matrix setup. Quote Link to comment Share on other sites More sharing options...
JoKer Posted August 29, 2012 Share Posted August 29, 2012 ya marine "bilge pumps" are the bee knees 1 Quote Link to comment Share on other sites More sharing options...
ryanfels Posted August 29, 2012 Share Posted August 29, 2012 This is relative to my interests Quote Link to comment Share on other sites More sharing options...
corey_jorg Posted August 29, 2012 Share Posted August 29, 2012 yea where would i be able to purchase one of those? just had a look on tardme but no luck. Quote Link to comment Share on other sites More sharing options...
zep Posted August 29, 2012 Share Posted August 29, 2012 Search for them on google NZ. Easy to find. Quote Link to comment Share on other sites More sharing options...
felixx Posted August 29, 2012 Share Posted August 29, 2012 ask Burnsco? www.burnsco.co.nz Quote Link to comment Share on other sites More sharing options...
vivaspeed Posted August 29, 2012 Share Posted August 29, 2012 I have one of these in the race car and it is generally okay when driving, but a bit shit if you want to clear the window first time round - really needs some heating in it. Use towel / then fan. There were some on the tard a few years ago that were a low profile heated blower that could sit on dash, or get a 12V travel hair dryer and strip the guts from it. Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted August 29, 2012 Share Posted August 29, 2012 keep heater core and make ducting for 2 bilge pumps from it give 2 blower setting for luxury comfort then mount somewhere convenient Quote Link to comment Share on other sites More sharing options...
JoKer Posted August 29, 2012 Share Posted August 29, 2012 http://www.trademe.co.nz/motors/boats-m ... 610219.htm http://www.trademe.co.nz/motors/boats-m ... 918973.htm i finded heaps once I remembered the not bilge "pumps" but fans/blowers Quote Link to comment Share on other sites More sharing options...
HighLUX Posted August 29, 2012 Share Posted August 29, 2012 At a guess Jase is playing with a Gemini which=heater gear on firewall so no good keeping factory core Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted August 29, 2012 Share Posted August 29, 2012 yea where would i be able to purchase one of those? just had a look on tardme but no luck. LOL if its not on trade me it does not exist Quote Link to comment Share on other sites More sharing options...
zep Posted August 29, 2012 Share Posted August 29, 2012 Here is an entire page of them: https://www.absolutemarine.co.nz/products/?id=4484 Jase, I am using one in my gemini. I've mounted a plumbing t-piece to get it to blow in both directions. The only thing you have to do is cut away the back of the console (the part you put your wallet in) to get it to fit in there. Quote Link to comment Share on other sites More sharing options...
Jase Posted August 29, 2012 Author Share Posted August 29, 2012 mean beans they look like the go for the puff, i'll have plenty heat coming through the firewall no doubt and the car won't likely be driven too often, but might look into a heating circuit to go in line, i'm guessing hairdryers just run a hot wire setup. Quote Link to comment Share on other sites More sharing options...
zep Posted August 30, 2012 Share Posted August 30, 2012 They have enough grunt to push themselves along the desk. 100+CFM it's crazy. I agree, it's hot enough under there to not bother with a heater. Quote Link to comment Share on other sites More sharing options...
drtdvl Posted August 30, 2012 Share Posted August 30, 2012 http://www.t7design.co.uk/ Quote Link to comment Share on other sites More sharing options...
slacker.cam Posted August 30, 2012 Share Posted August 30, 2012 The problem with running a 12V electric heater of some sort (ala hair dryer) is that to produce enough heat to do anything you need a lot of power. 12V hair dryers plug into cigarette lighter sockets and on the high side will draw 5 amps which is only 60W total output (less the power to run the internal fan). imagine putting a 60W light bulb up against your window and waiting for it to demist your windscreen. it just isn't enough heat. So, the problem is that to get enough power at 12V to create enough heat you need to draw huge amounts of current which requires big wires, etc, etc, etc. Most guys with electric vehicles use 240V ceramic heaters and wire them in to their high voltage battery packs. This works really well as with the higher voltage you only need a few amps to crank out the heat. I definitely think your best bet is to try the bilge fan and see how it goes. If it's not enough then worry about what the next step is after that. The V8 supercar guys seem to rave on about some kind of 2in1 shampoo that's apparently excellent for stopping windscreens from fogging up - like that FogX stuff but better. A quick search should fill you in on what kind to use. The plan for my racecar is to run the bilge fan + shampoo anti fog. Quote Link to comment Share on other sites More sharing options...
slacker.cam Posted August 30, 2012 Share Posted August 30, 2012 One more thing. Looking at the T7design place linked above. The smallest hot water heater they have is rated at 2.2kW (http://www.t7design.co.uk/index.php?mai ... cts_id=189). To match this with an electric heater requires 183A. Waaayyyyyy more than your alternator can even supply and it would require MASSIVE cables. Just wanted to justify my claims above... Quote Link to comment Share on other sites More sharing options...
10Speed Posted August 30, 2012 Share Posted August 30, 2012 VW guys have been looking for alternative heating for years, as if you run an aftermarket performance exhaust you typically have to sacrifice your heater boxes (which clamp around the exhaust manifold) - so far as I know no one has found a working alternative yet (except for a petrol powered/burning heater...) Quote Link to comment Share on other sites More sharing options...
