  • Replies 274
Yeah good work dude. When you can go get a sheet of cold rolled steel in 0.8 or 0.9 whatever that gauge is and you will be amazed that shaping panels just got 100% easier. 1.1mm zinc plated is for horse floats.
Will do, Spencer. I think I will need to for the outer door skin. I will struggle to fold the edge over straight on this stuff. Might need to find someone with a bender too.
Just now, AllTorque said:
Anyone have suggestions on where to get cold roll sheet metal in Welly by the part sheet?
@Nominal ?
I got some from Steel and Tube seaview. They only do full sheets and don't have the facilities to cut it, so you need a trailer. It was inexpensive.
I had a sheet of 1mm delivered from steel and tube before lockdown. Sheet itself was $65. Could carve a chunk off for you if you like.
Last time I bought cut bits it was electrogalv from Kia Ora Sheet Metal on Adelaide Rd. I think they sold that site though.
Not sure if this is the same company? https://www.kiaorametalindustriesltd.com/
@grunta or @Steelies might know. There's probably a sheet metal trade shop somewhere in Porirua.
I have been a lazy ass the last couple of weeks. Started on the outside of that corner.
I got it a bit hot and it warped a little. Going to have a go at shrinking.
  • 3 months later...
