Gaz Posted August 26, 2012 Share Posted August 26, 2012 Heyhi. Going to drop some rims in tomorrow to get widened, the question is how much. Car is a Chevette coupe, wheels are 14", guards are lipped. I am not going to change mounting face so its all about moving outter out. (three piece wheels) I have dropped a plumbline down from the outter edge of guard and measured that I can pump out dish 2.5inches front and rear. My question is should I do this much or go more? What have you widened steal guys done before or 3p wideners? Gaz Quote Link to comment Share on other sites More sharing options...
Esky_addict Posted August 26, 2012 Share Posted August 26, 2012 May be no help to you but ive widened a few sets of 14" steels to 8". i just cut out the old centres then welded them into new barrels at the same backspace of some 8" tridents I have. What do you mean by 3p wideners? Quote Link to comment Share on other sites More sharing options...
Gaz Posted August 26, 2012 Author Share Posted August 26, 2012 3 piece wheels. The wheels are 3p alloy not steel. No cutting and welding required. Gaz Quote Link to comment Share on other sites More sharing options...
Esky_addict Posted August 26, 2012 Share Posted August 26, 2012 Oooh I see Quote Link to comment Share on other sites More sharing options...
JoKer Posted August 26, 2012 Share Posted August 26, 2012 would aim for 1" at least out side of guard if possible? tuck tires in got legals? i might just be deaming Quote Link to comment Share on other sites More sharing options...
crustywhip Posted August 26, 2012 Share Posted August 26, 2012 I just bolted the rim on the car and then run a straight edge up to the arch. Measured how much I wanted it to come out and then added another 5mm to that when I dropped them off. Quote Link to comment Share on other sites More sharing options...
Gaz Posted August 26, 2012 Author Share Posted August 26, 2012 Solid rear end I guess what Im asking is about 'poke'?. Will running it 1" further than the outer edge of the guard look shit? Rims would be 14x8 once widened and running 185 55 14 Gaz Quote Link to comment Share on other sites More sharing options...
Simon Posted August 26, 2012 Share Posted August 26, 2012 With solid axle you can't really get away with going outside of the guard at all unless you are going to be running a high ride height (which is obviously not recommended) or a boat load of stretch. Quote Link to comment Share on other sites More sharing options...
Bling Posted August 26, 2012 Share Posted August 26, 2012 Depends what look you're going for I guess. With the stretch being so popular it's only a matter of time before it's likely to not be legal. So i'd personally just go flush with the guard. Probably not ideal look wise though if you're stretching 185s on to 8" rims. Quote Link to comment Share on other sites More sharing options...
Gaz Posted August 26, 2012 Author Share Posted August 26, 2012 Just re-measured itd be 8.5's. 3inch of dish, would really like 4". Brad, if your reading how far out did your old cookie cutters sit on the shvit? Gaz Quote Link to comment Share on other sites More sharing options...
kpr Posted August 26, 2012 Share Posted August 26, 2012 flush with guards, and mild stretch. then lower it down to suit. too much poke looks yuck. and cant go as low, while still being driveable. esp on live diff Quote Link to comment Share on other sites More sharing options...
Beaver Posted August 26, 2012 Share Posted August 26, 2012 what he said^ Quote Link to comment Share on other sites More sharing options...
KIRK Posted August 26, 2012 Share Posted August 26, 2012 i put centre in wheel and played around then told guy to weld so cant remember back spacing/offset. but yeh this on the back is about quite close to inline with guard, maybe ever so slightly inside. if you do all the wheels the same maybe to just inside the read guard the front will have heaps of room due to camber + i think the wheels are slightly more inside on the front(in relation to guard). was ok at that height but i made it lower and was rubby rubby even with little tyres and big hammer time on guards i think this pic below, is from before welding and i pretty sure/99% i moved the centres in more. would of been better to keep like this. for the back anyway. front would of looked stink. but i think something like this pic is what you should do if you want to keep it driveable. ps thats just desprung on one side so slight camber angle. def dont go inline with edge off guard otherwise you'll have to keep car real high edit: assuming 2 door sedan is the same arches as 4 door... Quote Link to comment Share on other sites More sharing options...
Gaz Posted August 26, 2012 Author Share Posted August 26, 2012 Oh cheers bro those pics help. I might have to take a fe mm off then Gaz Quote Link to comment Share on other sites More sharing options...
Jase Posted August 29, 2012 Share Posted August 29, 2012 if its lowered and you haven't got an adjustable panhard in there yet stop. your diff could be poked 20mm one way and give you the wrong measurements, depending on the look you want a 195 45 on a 14x8 would be the profile i'd go for. with 10mm poke outside the top guard lip you shouldn't have problems as your diff heads running out of room by the time you start getting to brads/tims wags rideheight. also remembering you can molest the twin skin rear wells as you don't have a pesky extra set of doors Quote Link to comment Share on other sites More sharing options...
Steelies Posted August 29, 2012 Share Posted August 29, 2012 i overshot by 10mm (too far out man) on the rear and now i want to cut em and re-position. i have difference from side to side also. Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted August 29, 2012 Share Posted August 29, 2012 thats your pan hard rod buddy Quote Link to comment Share on other sites More sharing options...
durty Posted August 29, 2012 Share Posted August 29, 2012 make it adjustable, pretty sure someone did a tech thread on how to make one Quote Link to comment Share on other sites More sharing options...
DJZ Posted August 29, 2012 Share Posted August 29, 2012 Be aware that if you are having new outers made there may only be certain sizes that you can get which is the problem that I had. I asked for one thing and got something different because they only had the formers to do ½ an inch either side of what I wanted. Quote Link to comment Share on other sites More sharing options...
Gaz Posted August 30, 2012 Author Share Posted August 30, 2012 ^^^ tis the problem I have by the looks. Have talked to Gavin & cant really get the outcome I want. Back to steelies. Gaz Quote Link to comment Share on other sites More sharing options...
