DJZ Posted February 22, 2012 Share Posted February 22, 2012 Insert VQ, do a skid. Quote Link to comment Share on other sites More sharing options...
mikey Posted February 22, 2012 Author Share Posted February 22, 2012 Insert VQ, do a skid. Word! Quote Link to comment Share on other sites More sharing options...
yoeddynz Posted February 22, 2012 Share Posted February 22, 2012 Good idea keeping the old engine for sure. Do you know the rough size of a VQ if it were a box?..... (just thinking about V6 Vivas....) Quote Link to comment Share on other sites More sharing options...
10Speed Posted February 22, 2012 Share Posted February 22, 2012 Overall height from oil pan to top of intake manifold....................28''height to top of heads......................................................23 1/2'' height to top of front cam covers.......................................24 3/4'' width from head to head not including plumbing tubes............22 1/2'' overall length from front idler pully to where trans bolts up...........21'' http://forums.hybridz.org/index.php/top ... imensions/ Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted February 22, 2012 Share Posted February 22, 2012 for that kinda money i would deff go VH45de vh- later model one with steel backed guides etc... then get a flywheel/adaptor plate kit to bolt it to nissan silvia manual box (they are available from the usa). But thats just me. The v6's u are talking about are also very cool. I've been in 350z's and was surprised by their poke. -Nathan, Quote Link to comment Share on other sites More sharing options...
mikey Posted February 22, 2012 Author Share Posted February 22, 2012 The vh45de is a pretty tight fit due to it being a 90 degree v8 in an engine bay designed for a straight 6. And according to wikipedia it only has 278hp? Anyway, Ive gotten a little ahead of myself. That auction doesnt have a Buy-Now but Im leading the bidding with 16 hours to go. No other bids so far. Fingers crossed. Quote Link to comment Share on other sites More sharing options...
fuel Posted February 22, 2012 Share Posted February 22, 2012 a VH45 is a very wide engine and would most likely not fit, same goes with the VK series. Quote Link to comment Share on other sites More sharing options...
DJZ Posted February 22, 2012 Share Posted February 22, 2012 How about a VH45 and two turbos? Quote Link to comment Share on other sites More sharing options...
xsspeed Posted February 22, 2012 Share Posted February 22, 2012 ^ Sweet lunch room Quote Link to comment Share on other sites More sharing options...
mikey Posted February 23, 2012 Author Share Posted February 23, 2012 Sweet everything. Quote Link to comment Share on other sites More sharing options...
Truenotch Posted February 23, 2012 Share Posted February 23, 2012 They're a shitter compared to the VQ / VK series of engines though... I reckon stick with the initial plan - the sound of a screaming NA V6 will suit this car perfectly. Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted February 23, 2012 Share Posted February 23, 2012 according to wikipedia it only has 278hp? The 4.5 L VH45DE featured variable valve timing, also known as VTC, from 1990 until 1995. This was due to the "Gentleman's Agreement", requiring all imports to produce no more than 280 hp. Nissan got around this by publishing the hp rating without VTC, meaning it's actual power rating is closer to 310 hp and 330 lb·ft. of torque. Quote Link to comment Share on other sites More sharing options...
mikey Posted February 23, 2012 Author Share Posted February 23, 2012 Auction won by me with 1 bid. It's on, much like Donkey Kong. Quote Link to comment Share on other sites More sharing options...
yoeddynz Posted February 23, 2012 Share Posted February 23, 2012 sweet! Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted February 23, 2012 Share Posted February 23, 2012 cool! take lots of pics Quote Link to comment Share on other sites More sharing options...
woody Posted April 25, 2012 Share Posted April 25, 2012 Hi, depends on what horse power you want and what application you need the motor for and budget etc. Plenty of Vq30det around and on trade me, Vq35 are a nice motor as is the vq30det. Nw to the forum so can someone tell me how to insert an image. Quote Link to comment Share on other sites More sharing options...
DJZ Posted April 25, 2012 Share Posted April 25, 2012 Bit late to the party there, he's already bought a motor. To insert an image you need to add [!img] to the start of the link and [!/img] to the end minus the two !s. Quote Link to comment Share on other sites More sharing options...
woody Posted April 26, 2012 Share Posted April 26, 2012 Hi, Looking at the correspondence I presume that it is a vq35 that has be bought ? I have the previous engine the vq30det in my BMW 318ti ( now BMW 3L Ti), running a 350z manual box. Quote Link to comment Share on other sites More sharing options...
mikey Posted April 26, 2012 Author Share Posted April 26, 2012 Yep I bought the VQ35. It should be ready for pick up in under a week! So pumped. ha I'll run the 350z box as well. Did you throw away the carbon tube and get a steel shaft made using the existing yoke? I believe you can cut and re-bond the carbon shaft, but I doubt anyone in NZ would do it. Quote Link to comment Share on other sites More sharing options...
woody Posted April 26, 2012 Share Posted April 26, 2012 The Vq35 is a great motor, I have one of those as well the only problem I have ever had with it is that it keeps hitting the red line on the rev counter. Figured out my right foot is to heavy. I used the carbon fiber driveshaft and adjusted the motor position to fit it in, only because the motor position was within 30mm of where I wanted it. If you can, use the carbon fibre driveshaft, do you want the dimensions of the shaft ? Other than that you will need to cut the shaft and turn off ( in a lathe) the remaining shaft off the yoke, then weld on a steel shaft etc. Would be great if you could use the original carbon fibre shaft as it will reduce your rotational mass a lot, and I have never heard of them breaking even in 350z that are around 900hp, still use the carbon shaft. Quote Link to comment Share on other sites More sharing options...
