weber or dellortos???
fordcapri1980
whats your carb preference??
24 members have voted
  1. 1. whats your carb preference??
    • weber
      11
    • dellorto
      13
dellortos and webers are so similar anyone saying one is thaaaat much better than the other is full of it. same goes for the street/race comments. either can be setup to run perfectly well for street or race, providing the carb is correctly sized for the application.
This is the truth here
Purely for my own interest what about Mikuni/Solex or OER carbs?
the mikuni / solex worked well as an OEM carb 30 years ago, but with 30 years of wear and lack of parts supply, they are normally avoided.
OER, are supposedly not too bad, but will be interesting to see if they have the same staying power as the Weber or Dell'orto bodys.
Having a carb throat per cylinder enables streetable characteristics even with a bigger cam. Due to there being less vaccuum signal degredation as the low rpm exhuast gas reversion can't corrupt the vaccuum signal for any of the other cylinders.
ive tunned dcoe and dhla plus ida's solex mikuni etc, dellorto and weber are pretty much the same thing you can argue which ones better but they both work good, dellorto has a diaphram style accelerator pump thats about all that could make it slightly better. dont get emmision versions get the race ones. and factors to consider when buying is it costs alot when you have to replace all the emullsion tubes air jets/holders or venturies and fuel jets needle valves wateva just = $$$$ and anything with shaft play isnt worth touching. prety much both same process to tune also so yeah get wateva you can afford thats in good condition with approximatly close jetting. jetting is easy to find for your engine.....
also solex are a pain just because you cant walk into a shop and buy parts
oer are just weber design with external float bowl adjustment etc
Reading "how to modify ford S.O.H.C engines" by David Vizard last night. He quoted a guy from Lynx in aussie as saying that they've found better lower mid range power with the dellortos. and well as a few more peak HP as well.
David Vizard writes some cool books. He used to build Avenger engines back in the 70's. I have an article in which he talks about the tricks he used to build his 160HP Avenger race engines.
Awesomely cool stuff and the guy really knows how to build an engine.
If any of you are interested here is an article by David Vizard about "Turbulence and Combustion Dynamics" in Avenger engines.
http://www.gofastnews.com/showthread.ph ... n-Dynamics
