Beaver Posted May 23, 2011 Share Posted May 23, 2011 ah yes, its never easy is it Quote Link to comment Share on other sites More sharing options...
Snoozin Posted May 23, 2011 Author Share Posted May 23, 2011 It'll be a piece of wees and look awesome. Reap the rewards of figuring out a method to said awesomeness. Quote Link to comment Share on other sites More sharing options...
Brock-Lee Posted May 23, 2011 Share Posted May 23, 2011 I will bring my mkfres to pinkys so you can out jdm snoozineUROLAJ Quote Link to comment Share on other sites More sharing options...
yoeddynz Posted May 23, 2011 Share Posted May 23, 2011 Now start saving for one of these.... http://www.trademe.co.nz/Trade-Me-Motor ... 953389.htm Quote Link to comment Share on other sites More sharing options...
Beaver Posted May 23, 2011 Share Posted May 23, 2011 if I talk nicely to manu and/or grinta Im sure one of them will be able to spin/make something up. I know grinta made some sweet lipped spacers for his val Quote Link to comment Share on other sites More sharing options...
EvoBilly Posted May 23, 2011 Share Posted May 23, 2011 sams got some photos of a nissan rb in the engine bay looked like it would fit ok apart from the gearbox Quote Link to comment Share on other sites More sharing options...
Beaver Posted May 23, 2011 Share Posted May 23, 2011 engine is perfectly fine for now haha Quote Link to comment Share on other sites More sharing options...
yoeddynz Posted May 23, 2011 Share Posted May 23, 2011 Cheers Richard for link to Collin with our old 2500S estate. I have sent him a PM. Its good as we had lost his contact details ages ago and wanted to find out how old Hoe was doing! Quote Link to comment Share on other sites More sharing options...
glen Posted May 23, 2011 Share Posted May 23, 2011 I remember seeing a while ago a trump 2500 that was running a rb30e out of a vl i think. so im fairly sure it would work out in th end. Quote Link to comment Share on other sites More sharing options...
Snoozin Posted May 27, 2011 Author Share Posted May 27, 2011 You'd be right, outer lamps are a dual filament 3 pin kinda deal so run on hi/lo beam. Quote Link to comment Share on other sites More sharing options...
Beaver Posted May 27, 2011 Share Posted May 27, 2011 right. so since both sets of bulbs are no go on high beam, must be a relay or something at fault? Quote Link to comment Share on other sites More sharing options...
mark105 Posted May 27, 2011 Share Posted May 27, 2011 would say so, if its anything like my datsuns the inner and outer highs are wired in parallel so if one blows the other still goes so the fact that neither work would suggest relay or relay is not getting power to turn highs on. got a multimeter? basic as to test. Quote Link to comment Share on other sites More sharing options...
KKtrips Posted May 27, 2011 Share Posted May 27, 2011 this ^^ Quote Link to comment Share on other sites More sharing options...
Beaver Posted May 27, 2011 Share Posted May 27, 2011 yep got one. need to find the relay first lol think I know where it is (slash there is a big one hanging out near the lights so I guess its that). should I just be checking for 12v getting to the relay? or seeing what comes out of it? or both I guess? Quote Link to comment Share on other sites More sharing options...
kyteler Posted May 27, 2011 Share Posted May 27, 2011 The headlamps work on Richies one, you should have bought that. :D :D :D ...OK I'll stop being a cunt now. (in this regard, that is) Quote Link to comment Share on other sites More sharing options...
mark105 Posted May 27, 2011 Share Posted May 27, 2011 check both, there should be 12V there at 2 points, one 12V should be on the switch side of the relay that when the relay is switched on will goto the high beams and the other to one side of the relay coil and the switch on the column should earth out the relay coil when going into high beam. this is the logical way it should work but in reality could be different, got a wiring diagram? Quote Link to comment Share on other sites More sharing options...
Snoozin Posted May 27, 2011 Author Share Posted May 27, 2011 If you haven't had any joy by the time I get home I'll snap a pic of the wiring diagram for you and post it man. Quote Link to comment Share on other sites More sharing options...
Beaver Posted May 27, 2011 Share Posted May 27, 2011 nah havnt got a wiring diagram (first car I havnt had a haynes for, really should get onto that). that would be mint thanks richie, will have a dig after work and see what I can figure out Quote Link to comment Share on other sites More sharing options...
Snoozin Posted May 27, 2011 Author Share Posted May 27, 2011 Here you go yo. From Haynes manual. Personally I'd be checking the switch. Quote Link to comment Share on other sites More sharing options...
Beaver Posted May 27, 2011 Share Posted May 27, 2011 Champion. Will check it out in the morning when I can see straight Quote Link to comment Share on other sites More sharing options...
