Beaver's '78 Two Point Five S
Snoozin
  • Replies 243
OK - they look better than I thought they would..
Bring em down to pinkys tomorrow night and use impact gun to take all the nuts and bolts out - will be a million times faster..
Also chuck discussion thread link into your first post ya doofus..
The 2 halves of the shell may be welded together then - or at least will be sealed with some silicone style sealant so may be a cunt to pry apart without the tyres being removed first..
I suppose if we leave 30 psi in each tyre then they'll come apart if they are not welded together..
Yeah they will be able to fine - they just won't be able to balance them till the centres go back in..
But is there any point in actually splitting them?
Just polish the outer shell, paint the centre..
BAM - A-La-Carte sweet riyums..
Just remove air and chuck 4 or so bolts back in to hold them together once the centres are removed. It would be a million times better if you don't crack the seal because they can be a cunt to seal up again.
