DB8-TypeR Posted December 26, 2011 Share Posted December 26, 2011 Should get a slimline Radiator fan, can get 10" ones for $50 or so. I run them on both my cars to clear the headers since I have thicker than OEM radiators Quote Link to comment Share on other sites More sharing options...
keltik Posted December 26, 2011 Author Share Posted December 26, 2011 These fans run 3 speeds and are pretty fancy, since they still fit and the engine is unlikely to move forwards unless i really fuck something up - they can stay i reckon. Quote Link to comment Share on other sites More sharing options...
DB8-TypeR Posted December 27, 2011 Share Posted December 27, 2011 Fair enough, my factory ones physically couldnt fit even after being attacked with a stanly knife. Have also changed the Shuttles one to a push fan rather than pull Quote Link to comment Share on other sites More sharing options...
lou Posted December 27, 2011 Share Posted December 27, 2011 Looking at your pics makes me feel dirty. Oh so dirty. Quote Link to comment Share on other sites More sharing options...
keltik Posted December 27, 2011 Author Share Posted December 27, 2011 I get that a lot, especially on NZD Quote Link to comment Share on other sites More sharing options...
Vintage Grumble Posted December 28, 2011 Share Posted December 28, 2011 Plate bizo work out ok? Quote Link to comment Share on other sites More sharing options...
keltik Posted December 28, 2011 Author Share Posted December 28, 2011 Fits sweet as, then the Jew turned up so i got distracted and havnt quite finished bolting it on. Aiming for first cranking session on Friday night Quote Link to comment Share on other sites More sharing options...
keltik Posted January 5, 2012 Author Share Posted January 5, 2012 Well after yelling at it for a week, I finally got round to turning it over tonight. I rescued the bolt from the bell housing using a endoscope from jaycar and a lump of magnet taped to a length of plumbing solder. Worked real well actually. Wired up the last couple of sensors and hit the key. It built oil pressure eventually, all of the ECU sensors were reporting a reasonable value and the cam sensors were syncing with the crank sensor nicely. So far everything as expected then. Next job is to get a timing light and make sure the cam sync is correctly calibrated. Its 99% sure going to be right but i would rather check before i go any further. I also need to make a throttle cable bracket out of some steel bar and wire in the idle control solenoid and throttle position sensor. After that - i just need to push the car out of the shed, turn injection back on and see if it will fire. Mildly shitting myself as i always do at this point in the job. Quote Link to comment Share on other sites More sharing options...
johnnyfive Posted January 5, 2012 Share Posted January 5, 2012 I got timing light if you want holmes. Quote Link to comment Share on other sites More sharing options...
keltik Posted January 5, 2012 Author Share Posted January 5, 2012 Ill swap you stick magnet for timing light Quote Link to comment Share on other sites More sharing options...
johnnyfive Posted January 5, 2012 Share Posted January 5, 2012 How soon you need it? I bored of house/need to go get burgers Quote Link to comment Share on other sites More sharing options...
keltik Posted January 5, 2012 Author Share Posted January 5, 2012 Dont really need it for a while, will need to hook up TPS before i can attempt to fire it Quote Link to comment Share on other sites More sharing options...
keltik Posted January 5, 2012 Author Share Posted January 5, 2012 Im currently doing 2/tenths of fuck all tho. Might boost into town now actually and get a few things i need from work. What Greer up to? Quote Link to comment Share on other sites More sharing options...
johnnyfive Posted January 5, 2012 Share Posted January 5, 2012 get out your soldering gat, ill be there in 20? beaten : stalemate Quote Link to comment Share on other sites More sharing options...
keltik Posted January 5, 2012 Author Share Posted January 5, 2012 get out your soldering gat, ill be there in 20?beaten : stalemate Go on then, head over - we can poke it with a stick. Plus you have more comfortable whip Quote Link to comment Share on other sites More sharing options...
chees- Posted January 5, 2012 Share Posted January 5, 2012 Im currently doing 2/tenths of fuck all tho. Might boost into town now actually and get a few things i need from work. What Greer up to? just to be creepy, i'm at home Quote Link to comment Share on other sites More sharing options...
johnnyfive Posted January 5, 2012 Share Posted January 5, 2012 I'll round up the gang + a burger + timing gun. I'm 90% sure gun works. Im currently doing 2/tenths of fuck all tho. Might boost into town now actually and get a few things i need from work. What Greer up to? just to be creepy, i'm at home chuckles Quote Link to comment Share on other sites More sharing options...
keltik Posted January 5, 2012 Author Share Posted January 5, 2012 Im currently doing 2/tenths of fuck all tho. Might boost into town now actually and get a few things i need from work. What Greer up to? just to be creepy, i'm at home YOUR NOT VG! Quote Link to comment Share on other sites More sharing options...
keltik Posted January 9, 2012 Author Share Posted January 9, 2012 So at lunch time today, waimaks helped me wire in the TPS and idle control solenoid, then he fashioned this awesome throttle cable bracket; Then we did this; aI3KMMB2jKA Exhaust is gettin welded up on Friday, the week after that i should be able to go brum brum....then sell a kidney so i can afford a tune. Quote Link to comment Share on other sites More sharing options...
Honda Ass Dragger Posted January 9, 2012 Share Posted January 9, 2012 Not sure if you have seen: http://www.performanceforums.com/forums ... so-now-V12 Quote Link to comment Share on other sites More sharing options...
