Truenotch Posted January 31, 2011 Share Posted January 31, 2011 Yum. Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted February 8, 2011 Share Posted February 8, 2011 Looking good! Progress is coming along nicely! Quote Link to comment Share on other sites More sharing options...
Dell'orto Posted February 8, 2011 Share Posted February 8, 2011 Cleaning the blasting grit out of the diff housing is a cunt of a job eh! Quote Link to comment Share on other sites More sharing options...
KKtrips Posted November 15, 2011 Share Posted November 15, 2011 Nice one Spanners - not too much more to go till she'd running - also are you back in Wellington/Kapiti again now? Quote Link to comment Share on other sites More sharing options...
spanners Posted November 15, 2011 Author Share Posted November 15, 2011 yeah bruv been here for ages but work has been slow. My stepbro broke his arm working at an engineering shop so I told his boss id take over for a couple of weeks if he let me use his shop to do my car. So progress should be good. In the end I am actually working there paid full time until xmas so will have a lot of late nights making that bitch so so sweet! Quote Link to comment Share on other sites More sharing options...
Truenotch Posted November 15, 2011 Share Posted November 15, 2011 Glad to see it's back on track man! How much did Brian charge for the driveshaft? I need to get one made up soon and may as well get it done along with a pair of axles (that I've been putting off for ages). Quote Link to comment Share on other sites More sharing options...
spanners Posted November 15, 2011 Author Share Posted November 15, 2011 was 250 incl gst. I supplied front yoke thing and rear (hilux) flange though. He was good, only took 2 days and its very nice. Quote Link to comment Share on other sites More sharing options...
nothingsfree Posted November 16, 2011 Share Posted November 16, 2011 Sweeet! Stoked to see progress on this thing! Are you pulling everything out for panel an paint? Quote Link to comment Share on other sites More sharing options...
spanners Posted November 17, 2011 Author Share Posted November 17, 2011 will tear it all apart for panel and paint at some stage but that will be last thing to do, so that once its done i dont have to fuck up my paint by fitting new brackets etc Quote Link to comment Share on other sites More sharing options...
nothingsfree Posted November 18, 2011 Share Posted November 18, 2011 will tear it all apart for panel and paint at some stage but that will be last thing to do, so that once its done i dont have to fuck up my paint by fitting new brackets etc Haha exactly, Im doing the same thing. Tempted to even go for cert with it unpainted incase I have to change anything, tho I should be sweet. Quote Link to comment Share on other sites More sharing options...
spanners Posted November 18, 2011 Author Share Posted November 18, 2011 Mines gonna look so gay at cert time. I plan to have it so slammed that the sump hits catseyes but of course will need to have all 4 corners wound up to 90mm for cert, so I will have hacked guards etc that wont be filled with wheels. I have to do what you did on the front soon - whip off the guards, chuck the car in the air and turn full lock left to right and see what hits. Quote Link to comment Share on other sites More sharing options...
Roman Posted November 19, 2011 Share Posted November 19, 2011 A cats eye would tear your sump a new arsehole! Quote Link to comment Share on other sites More sharing options...
spanners Posted November 19, 2011 Author Share Posted November 19, 2011 Yeah its not ideal, the sump pan sits real low cos the motor is so tall. Hopefully I can make a smaller one at some point Quote Link to comment Share on other sites More sharing options...
nothingsfree Posted November 20, 2011 Share Posted November 20, 2011 Yeah I just got the engine back in Kermit last night. With two people bouncing on the front, my sump/ crossmember bottoms out on ground . Im gonna modify the sump, and stick a filthy big sump guard from the radiator support panel back to the gbox. Do you need to wind it up to 90mm to get enough travel/ suspension arms correct. Quote Link to comment Share on other sites More sharing options...
spanners Posted November 20, 2011 Author Share Posted November 20, 2011 Na all my suspension is adjustable and is sweet at quite a range of heights I think, but 90mm is the height of my sidewall and thats the lowest that the cert guy is gonna let me go. Unless I get lower profile front tyres which might allow a slightly lower car. Does your engine pretty much sit on the x-member? Mine has about 1mm clearance, which means my sump is the lowest point on the car. Not a great idea but its cheaper than a dry sump (altho drysump is fucking brilliant) Quote Link to comment Share on other sites More sharing options...
nothingsfree Posted November 21, 2011 Share Posted November 21, 2011 Yeah it is, I spaced it up a little, so I think iv got bout 4-5mm room. Im going to modify the sump, prolly shorten it, and widen it, to get up just above the height of the xmember. Then going to run a big heavy bash plate from the radiator support panel, back to the gbox.. Quote Link to comment Share on other sites More sharing options...
spanners Posted November 21, 2011 Author Share Posted November 21, 2011 Yeah thats probably on the cards for me too, the lowest part of the sump is quite far below the xmember really Quote Link to comment Share on other sites More sharing options...
kpr Posted December 5, 2011 Share Posted December 5, 2011 liking the lower arm/ caster arm mod. Quote Link to comment Share on other sites More sharing options...
Brennan Posted January 11, 2012 Share Posted January 11, 2012 Hey spanners. Looking mint. When you say you have spent loads to get the beams in there. What sort of money are you talking about at an estimate ? What where the most expensive unexpected bits etc ? Kind of second guessing whether I should bother with my ke70. Keep up the great work though! Quote Link to comment Share on other sites More sharing options...
LingLing Posted January 11, 2012 Share Posted January 11, 2012 very mean starlet, would it feel heavier than before when you drive it? specially the nose? would it understeer at tight corners? also, how does it feel at the down low torque when compared to 20v 4age? Quote Link to comment Share on other sites More sharing options...
