SHGWAG Posted June 1, 2011 Author Share Posted June 1, 2011 Dave, the best thing about platform adjustables, is you can be any height & not effect your spring rate. Beaver, I suspect if Work Japan do them in white, Work NZ should be able to source them for me. Wi'll just cost me extra I suspect. Link to comment Share on other sites More sharing options...
Brock-Lee Posted June 1, 2011 Share Posted June 1, 2011 Agree. But you can't raise it, it looks boss as fuck at current height. Link to comment Share on other sites More sharing options...
SHGWAG Posted June 1, 2011 Author Share Posted June 1, 2011 What's gay is that the C-West guards are wide enough to keep it this low, but they require the sideskirts too. Plenty of room under the rear to stay at this height. Link to comment Share on other sites More sharing options...
mixmasterlex Posted June 2, 2011 Share Posted June 2, 2011 That sounds like a solution, not a problem Link to comment Share on other sites More sharing options...
SHGWAG Posted June 2, 2011 Author Share Posted June 2, 2011 Sideskirts are yuck. Work NZ got back to me. $3050 for the wheels (they didn't state if this includes GST) with an 8 week lead time from date of order for the white set. Link to comment Share on other sites More sharing options...
kyteler Posted June 2, 2011 Share Posted June 2, 2011 So that's less than your estimate by $350. Sweet? Link to comment Share on other sites More sharing options...
SHGWAG Posted June 2, 2011 Author Share Posted June 2, 2011 Yes. Hopefully I get a decent bonus this month & can grab them / Buy a BL5 GTB instead. EDIT: Quot doesn't include centre caps or wheel nuts. Link to comment Share on other sites More sharing options...
glen Posted June 3, 2011 Share Posted June 3, 2011 Link to comment Share on other sites More sharing options...
sentra Posted June 5, 2011 Share Posted June 5, 2011 be sure to get them in multistud so they will fit on your honda Link to comment Share on other sites More sharing options...
SHGWAG Posted June 12, 2011 Author Share Posted June 12, 2011 Slapped the standard struts back in, looks disgustingly high, but means it's one step closer to a WOF. It's idle is slightly off, I put this down to dirty plugs, which I'll change next time I'm over in Hamilton. Last obvious thing to do is quieten down the exhaust. Then go for WOF check. Probably wait 'til August to do this, have a few big weekends ahead & time / money is in short supply. Link to comment Share on other sites More sharing options...
rollaholic Posted September 2, 2011 Share Posted September 2, 2011 this thread makes me desire an FD more than i thought possible (was already in my top 3 fav cars) shame people seem to want moonbeams for the most godawful examples awesome to see a project go from fucked out POS to actually running and driveable! Link to comment Share on other sites More sharing options...
SHGWAG Posted September 2, 2011 Author Share Posted September 2, 2011 Nearly passed a wof too. Failed on: Headlight adjustment (FIXED) Front brake hoses unsecure - Just have to find the clips to re attach them to the struts. Loose wiring under dash (FIXED) Worn wiper blades (FIXED) Unsecure Battery (Was unsecure due to my old one fucking out / getting a replacement under warranty) Diff Mounts Worn - This is kind of a big one. I have to drop the whole rear subframe to fix this, & the mounts need to be pressed out/in. Other than that she's all hunky dori. Link to comment Share on other sites More sharing options...
yoeddynz Posted September 3, 2011 Share Posted September 3, 2011 Loose wiring under the dash is a fail for a wof? Like how loose? hanging down around your feet or just a bit loose and messy? I think it must have been a quiet day when you took it for a test! Is it also true that cars can fail if the rear parcel shelf has been cut to fit speakers? crazy. Link to comment Share on other sites More sharing options...
kyteler Posted September 3, 2011 Share Posted September 3, 2011 Is it also true that cars can fail if the rear parcel shelf has been cut to fit speakers? crazy. 100% True. Link to comment Share on other sites More sharing options...
yoeddynz Posted September 3, 2011 Share Posted September 3, 2011 Bugger- because my Viva has been 'opened' out slightly to fit bigger speakers at some point- maybe 20mm bigger dia over the original holes? I have made a new parcel shelf to hide it. Hopefully they dont go looking up inside boot - no reason why they should as the car has no stereo. Link to comment Share on other sites More sharing options...
kyteler Posted September 3, 2011 Share Posted September 3, 2011 If it's done in a manner that doesn't stick out like dogs balls you will probably be fine. That said, it depends on your tester. What you could do is make up a liner for the underside? HIDDEN, DUN DUN DUUUUUN. Link to comment Share on other sites More sharing options...
Hemi Posted September 3, 2011 Share Posted September 3, 2011 If it's done in a manner that doesn't stick out like dogs balls you will probably be fine. That said, it depends on your tester. What you could do is make up a liner for the underside? HIDDEN, DUN DUN DUUUUUN. this^^ it is a structural part of the car but so long is its done tidy and you arnt trying to fit 15" subs into them you should be fine . underdash wire might be where some of the relays reside next to the go pedal i myself have had an unfortunate incident of 910 where a wire came down and hooked under accel pedal without me knowing .. went to go and it ripped it out and killed the car . more pics of skids please shgwag im getting very impatient Link to comment Share on other sites More sharing options...
yoeddynz Posted September 3, 2011 Share Posted September 3, 2011 Cool- I'll tidy it up and make it look stock, then hide it. I agree to about vids of skids. I have always been tempted in the UK of the many many cheap FDs there. People buy them then sell em after the first fill up, or after struggling to find someone prepared to work on them..."ewww- its got one of the odd rotary things in it- no sir,, we don't work on them" Link to comment Share on other sites More sharing options...
Hemi Posted September 3, 2011 Share Posted September 3, 2011 i dont understand the mentality/ do the exact same ting when anything bedford or tanner related rolls in the door Link to comment Share on other sites More sharing options...
Josh Posted September 6, 2011 Share Posted September 6, 2011 SHGWAG, can you document/let me know how your diff mounts go, I think I'm going to have to do this in near future. Link to comment Share on other sites More sharing options...
