Requiemk Posted January 23, 2011 Share Posted January 23, 2011 bridgeport doesn't add that much power then. mates rx7 got tuned on friday non bridgeport 200kw at 8 psi Link to comment Share on other sites More sharing options...
Insani-T Posted January 23, 2011 Share Posted January 23, 2011 I dont see why not? My cousins Skyline is over 1000nm and pushing 500hp Link to comment Share on other sites More sharing options...
SHGWAG Posted January 23, 2011 Author Share Posted January 23, 2011 bridgeport doesn't add that much power then. mates rx7 got tuned on friday non bridgeport 200kw at 8 psi It's quite a small bridgeport, could have taken alot more meat taken out of the plates, but decided against it as I've heard horror stories of having a massive port and the bridge collapsing at high boost/rpm. Link to comment Share on other sites More sharing options...
Simon Posted January 23, 2011 Share Posted January 23, 2011 You don't need mad ports to get power out of turbocharged tangaz. In fact they are a lot more drivable and reliable as a road car with minimal porting +T. Also, you should spend less time chasing meat and finish this. It's way better Link to comment Share on other sites More sharing options...
SHGWAG Posted January 23, 2011 Author Share Posted January 23, 2011 I don't think I'll ever finish this. There are soo many things I want to do to it. Seats Wheels Speakers that work Paint List goes on.. Link to comment Share on other sites More sharing options...
Brock-Lee Posted January 24, 2011 Share Posted January 24, 2011 if power run was done in 4th (1:1) then you need to multiply by the inverse of the diff ratio to get the torque that the engine is producing Link to comment Share on other sites More sharing options...
Mike-e Posted January 24, 2011 Share Posted January 24, 2011 coudividegh Link to comment Share on other sites More sharing options...
SHGWAG Posted January 24, 2011 Author Share Posted January 24, 2011 if power run was done in 4th (1:1) then you need to multiply by the diff ratio to get the torque that the engine is producing Was in 4th, Think it's a 3.9 diff So 710/3.9 = 182nm ?? Link to comment Share on other sites More sharing options...
cute wee gem Posted January 24, 2011 Share Posted January 24, 2011 293ft-lb or 397nm That's calculated from 250kw@6000 (335hp) I think that's right? Edit: That's 293ft-lb @ 6000 rpm, it may be more at a slightly lower rpm Link to comment Share on other sites More sharing options...
SHGWAG Posted January 27, 2011 Author Share Posted January 27, 2011 Using an online calcualtor I got 367 NM Link to comment Share on other sites More sharing options...
mixmasterlex Posted January 27, 2011 Share Posted January 27, 2011 vids of boosting fun plz Link to comment Share on other sites More sharing options...
SHGWAG Posted January 27, 2011 Author Share Posted January 27, 2011 Might pick it up saturday if I they can sort the boost spike problem. Have a vid of it Idling, but have no way of uploading. *EDIT: They think they have sorted it, but won't find out till they chuck it back on the dyno. Link to comment Share on other sites More sharing options...
SHGWAG Posted February 17, 2011 Author Share Posted February 17, 2011 So boost problem was fixed, however the clutch was playing up / slipping on the dyno. So I've ripped the box out. Replacing the old organic clutch plate with something of the puk variety. This won't be cheap so I've got to put a hold on this as my daily needs a wof next week. Link to comment Share on other sites More sharing options...
SHGWAG Posted February 26, 2011 Author Share Posted February 26, 2011 Still needs work, have to get around to putting the interior back in as well. Link to comment Share on other sites More sharing options...
Bombsquad Posted February 26, 2011 Share Posted February 26, 2011 Uggh dyno'd at cartoon, why didnt you take it over to tga or down terapa? Link to comment Share on other sites More sharing options...
SHGWAG Posted February 27, 2011 Author Share Posted February 27, 2011 Te Rapa made a cock up of my brothers tune (They also thought 80psi compression on a rotary was nothing out of the ordinary - it had leaking water seals, but they dyno'd it anyway) I'm happy with the timing & AFRs that it has atm, and the power curve is nice and smooth. When it gets back to TGA & is run in I'll evaluate who will be doing the big power tune. Link to comment Share on other sites More sharing options...
nothingsfree Posted February 28, 2011 Share Posted February 28, 2011 Forgot that this was just the run in tune. Cant believe its taken them that long to sort, fuck that. Still, that first decent thrash will be epic... Link to comment Share on other sites More sharing options...
SHGWAG Posted March 1, 2011 Author Share Posted March 1, 2011 Actually, the clutch is my delay, as I had to spend money on other things this month. but yea, they were mad busy over Christmas. They want another couple of hours with it after I've put the new clutch in. Link to comment Share on other sites More sharing options...
SHGWAG Posted April 5, 2011 Author Share Posted April 5, 2011 So just got a phone call this morning.. It's ready. New clutch is in & its happily running 12psi. GANGSIGNS I'm flat out with work untill next Friday, so will go pick it up then. Will then swap bonnets, so I can bomb the current shite one. Start to reassemble the interior Wire up the "Scramble boost" switch. Unwire the RSM out of it Wire in new gauges. Fit the numberplate. Fit the front chin spoiler. Not sure if I want to keep the wideband wired in, or sell it - Could probably use the cash. Link to comment Share on other sites More sharing options...
mikuni Posted April 5, 2011 Share Posted April 5, 2011 I'll grab it for you bro. Link to comment Share on other sites More sharing options...
