Guest Posted October 3, 2009 Share Posted October 3, 2009 Now I don't know if it would work, but it looks like it could. Try bolting the centre behind the inner and outer for the rear pair to make a bit of stagger in there. Quote Link to comment Share on other sites More sharing options...
Simon Posted October 3, 2009 Author Share Posted October 3, 2009 Yeah, i was thinking that also. That is how i had them bolted for polishing and it looked like it was almost made to be like that. (but its not) See pic below. But i will get the face of the center turned flat so at least it could work. However it would give the wheel like -20 and 10'+ width but depending how i bolted it could keep it 9.5... Im going to be rolling the rear guards enough as it is haha. Would be sweet if that worked though. I like the look of the center behind too. Quote Link to comment Share on other sites More sharing options...
Gaz Posted October 3, 2009 Share Posted October 3, 2009 Looks good as! I suggest sand blasting the centers then leave them to surface rust, if they are steel that is. Would look mean with polished lip and haggard center. Gaz Quote Link to comment Share on other sites More sharing options...
Simon Posted October 3, 2009 Author Share Posted October 3, 2009 Looks good as!I suggest sand blasting the centers then leave them to surface rust, if they are steel that is. Would look mean with polished lip and haggard center. Gaz Thats a bloody good idea, im trying to do things a bit different. Too bad they are alloy though. Quote Link to comment Share on other sites More sharing options...
Gaz Posted October 3, 2009 Share Posted October 3, 2009 Rusty airbrushing lol. So keen to get my cage airbrushed timber look when I get it I haven't read ya whole thread but Im guessing you have used two sets of inner shells? Have you drilled a new hole yourself for the valve to come through? Gaz Quote Link to comment Share on other sites More sharing options...
Simon Posted October 3, 2009 Author Share Posted October 3, 2009 Yeah, I bought the wheels off Hugo (yokonikero) who did the modifying, not that it was too involved. Im going to run tubes though. Yeah they are just two sets of 6j (i think) wheels with the back rings put together. Its probably only Chris Cain who gives a shit / would know that they are not the real deal lol and they were cheap enough for the specs. 14x9.5 -10 But if I do what I / Z.E.B mentioned above Im guessing they could become -25 to 30 offset and a bit over 10' wide for a staggered rear pair. Bit silly really as the dish looks a bit too much bolt on flares are cheating. Quote Link to comment Share on other sites More sharing options...
Gaz Posted October 3, 2009 Share Posted October 3, 2009 Ah true. A tube will still need a valve somewhere tho right? Gaz Quote Link to comment Share on other sites More sharing options...
Simon Posted October 3, 2009 Author Share Posted October 3, 2009 Yeah mang Quote Link to comment Share on other sites More sharing options...
cheater_5 Posted October 4, 2009 Share Posted October 4, 2009 I don't fucking care. Looks dope. Make it low Quote Link to comment Share on other sites More sharing options...
Gaz Posted October 4, 2009 Share Posted October 4, 2009 Ah yup yup just drilled with normal drill by the looks. Going to look mean when finished. I did mine and gave up about where you are now lol. Gaz Quote Link to comment Share on other sites More sharing options...
Jammy-Fishpaste Posted October 11, 2009 Share Posted October 11, 2009 got coilovers yet? / is it low yet? Quote Link to comment Share on other sites More sharing options...
Simon Posted October 11, 2009 Author Share Posted October 11, 2009 Its lower than the bump stops at the rear. Going to have to cut them in less than half. Also make exhaust go under the diff. Im going to have to either shorten the shocks 20mm or move the mount on the diff down further. Which is the better plan? Its way more slammed than factory when the back ends off the ground and the shocks topped out haha. Got to finish exams then i can polish the other wheels on the cressida, then sell it plus the other wheels i have and then will have the money buffer to send the struts to driftmonkey to work magic and return as coilovers. Going to make up a hagard guard roller the attatches to hub and pivots. This way i can put tension on it perpendicular to the car with another cars tow bar or winch haha. I cant be bothered doing all the fiber glassing like what lofreq did, plus i dont need the clearance that he did. Hope suspension cert is reasonable price. Would be nice to make OS Jap meet. Quote Link to comment Share on other sites More sharing options...
Brock-Lee Posted October 20, 2009 Share Posted October 20, 2009 Dont fuck around with slotting shit. get some cheap camber plates and wind it on. Is a way better solution. Looks mean otherwise. Im liking this project Quote Link to comment Share on other sites More sharing options...
Bombsquad Posted November 8, 2009 Share Posted November 8, 2009 My 2c.. Very cool!! lovin the rims and the flag. Quote Link to comment Share on other sites More sharing options...
Truenotch Posted November 8, 2009 Share Posted November 8, 2009 Over stretched tyres and the dish is too much. You should have kept those modgies. Quote Link to comment Share on other sites More sharing options...
cheater_5 Posted November 8, 2009 Share Posted November 8, 2009 Very much liking where this is heading Simon. Mad aeroplane probs. Front poke is a bit much for me, looks mexican. Cough Quote Link to comment Share on other sites More sharing options...
lowlancer Posted November 8, 2009 Share Posted November 8, 2009 Agree with cheater in general. Too much poke but looks awesome otherwise. How did other Corona fellow get them to look as they did? Quote Link to comment Share on other sites More sharing options...
Simon Posted November 8, 2009 Author Share Posted November 8, 2009 Yeah, the fronts definitely stick out too far. Looks funny. Will try and get 10mm machined from the center to bring them back to 0 offset for the front. Depending on brake clearance that is. Yokie's blue coupe was a factory turbo one and they had factory flared guards. His red sedan was a hack and just had the shit bashed of of the guards. Gutted he only has one guard from the coupe or i would have bought them off him. I dont want flares. Next on the list is get the panhard rod to hold the diff center at that height and cut the bumpstops to suit. Then its build coilovers and cert for jap meat. May have to do some ringing round to find someone that will cert it haha. Will trailer it across the NI if anyone knows of a lenient certer. Quote Link to comment Share on other sites More sharing options...
lowlancer Posted November 8, 2009 Share Posted November 8, 2009 I like your style. Flares really are quite horrid. Quote Link to comment Share on other sites More sharing options...
BobbyBreeze Posted November 8, 2009 Share Posted November 8, 2009 I think that will look fine if you just camber the front in more? Less pissing around with wheels etc too. Unsure you'd want to machine 10mm off them either? Quote Link to comment Share on other sites More sharing options...
