drftnmaz Posted February 17, 2009 Share Posted February 17, 2009 you wont get the tyre on with tyre machine without ripping the bead to sh!t, which is why most people wouldnt bother making rims like these, only the dedicated cheap guys Quote Link to comment Share on other sites More sharing options...
cheater_5 Posted February 17, 2009 Share Posted February 17, 2009 oh lol, didnt see where the valley is on dem. haha thats going to suuuccckkk Quote Link to comment Share on other sites More sharing options...
Guest Posted February 17, 2009 Share Posted February 17, 2009 Can't see how it will rip the tyre putting them on eh, the front and rear are exactly the same diameter. Should be just the same as doing it normally? Edit: omg whered mitch's post go. Quote Link to comment Share on other sites More sharing options...
Rusted Posted February 17, 2009 Share Posted February 17, 2009 Air bottle compressed to throw beads in. Stern setup boe!! Quote Link to comment Share on other sites More sharing options...
drftnmaz Posted February 17, 2009 Share Posted February 17, 2009 Can't see how it will rip the tyre putting them on eh, the front and rear are exactly the same diameter. Should be just the same as doing it normally?Edit: omg whered mitch's post go. i dont know how to explain it more clearly than in my other post \/ if i get a minute i'll take some pics to explain tonight "the back piece has a slow taper and the front has a small step with sharp taper so when you put on tyre machine the tyre goes over the small step and sits in the recess while the rest of it goes over the lip, so when you no longer have small step then you have to assemble rim around the tyre" Quote Link to comment Share on other sites More sharing options...
yokonikero Posted February 17, 2009 Share Posted February 17, 2009 see how on the front bit it tapers in on a bigger angle than the rear. its so wen the tire is getting put on it slides into the dip allowing it to move further to the other side so the tire bead dusnt have to stretch to much to slip over the rim lip. Quote Link to comment Share on other sites More sharing options...
yokonikero Posted February 17, 2009 Share Posted February 17, 2009 if u do put a shit tire on using a tire machine. DO NOT DRIVE ON IT. haha let it sit for a day or to. you will loose psi. Quote Link to comment Share on other sites More sharing options...
Gaz Posted February 17, 2009 Share Posted February 17, 2009 Was looking at mine tonight. The goo they use when using a tyre machine is for what? Sealing or lubrication? I want to try put my tyres back on myself as the rims are seperated at the mo. Will they just pop onto the bead when I fill with air? Mine are not modded from diff rims like these. Quote Link to comment Share on other sites More sharing options...
durty Posted February 17, 2009 Share Posted February 17, 2009 Was looking at mine tonight. The goo they use when using a tyre machine is for what? Sealing or lubrication?I want to try put my tyres back on myself as the rims are seperated at the mo. Will they just pop onto the bead when I fill with air? Mine are not modded from diff rims like these. lubrication Quote Link to comment Share on other sites More sharing options...
drftnmaz Posted February 18, 2009 Share Posted February 18, 2009 Was looking at mine tonight. The goo they use when using a tyre machine is for what? Sealing or lubrication?I want to try put my tyres back on myself as the rims are seperated at the mo. Will they just pop onto the bead when I fill with air? Mine are not modded from diff rims like these. yea lube... i would assemble the rims first so you can do a nice bead of selant on the inside, you dont NEED a tyre machine to fit a tyre, you can push one side on and use the crow bar working around the bead till it pops on, but its alot of work compared to going to a tyre shop, we used to do it back in the day Quote Link to comment Share on other sites More sharing options...
Gaz Posted February 18, 2009 Share Posted February 18, 2009 Supposed I need em balanced either way! Quote Link to comment Share on other sites More sharing options...
Guest Posted February 18, 2009 Share Posted February 18, 2009 Yup went to tyre shop today after drilling holes for the valves, tried getting a bald tyre on there but no luck, it did rip it a bit. Did however get the 185/60 Yokos stripped off my Dunlop rims and now I'm assembling the wheels around them, almost needs to run skinny tyres to be able to seal them with the tyres on . Will seal them tonight after work then wait a few days for that to dry proper then I'll see how I go getting at 185 on a 9.5" rim! This apparently is a 185/60 R14 on a 9" so yeh Quote Link to comment Share on other sites More sharing options...
yokonikero Posted February 18, 2009 Share Posted February 18, 2009 you dont NEED a tyre machine to fit a tyre, you can push one side on and use the crow bar working around the bead till it pops on, but its alot of work compared to going to a tyre shop, we used to do it back in the day its piss easy. i can do two tires on rims in about 5min. jus need sum soapy water too rub on the bead. next tym i do ill take a vid Quote Link to comment Share on other sites More sharing options...
drftnmaz Posted February 18, 2009 Share Posted February 18, 2009 you dont NEED a tyre machine to fit a tyre, you can push one side on and use the crow bar working around the bead till it pops on, but its alot of work compared to going to a tyre shop, we used to do it back in the day its piss easy. i can do two tires on rims in about 5min. jus need sum soapy water too rub on the bead. next tym i do ill take a vid yea i spose with a 60 series or something it would be quite easy, all the ones we did were low pro 17s and such, 20-40-17 on 7" rims etc Quote Link to comment Share on other sites More sharing options...
yokonikero Posted February 23, 2009 Share Posted February 23, 2009 you dont NEED a tyre machine to fit a tyre, you can push one side on and use the crow bar working around the bead till it pops on, but its alot of work compared to going to a tyre shop, we used to do it back in the day its piss easy. i can do two tires on rims in about 5min. jus need sum soapy water too rub on the bead. next tym i do ill take a vid **NOTE** the soap was slipry haha Quote Link to comment Share on other sites More sharing options...
treggo Posted February 25, 2009 Share Posted February 25, 2009 That looks fucking brilliant Quote Link to comment Share on other sites More sharing options...
Bistro Posted February 25, 2009 Share Posted February 25, 2009 bANGIN' Quote Link to comment Share on other sites More sharing options...
FLAWLES Posted February 25, 2009 Share Posted February 25, 2009 I <3 u do you have any rims for sale??? just wondering? but god that looks amazing high 5 Quote Link to comment Share on other sites More sharing options...
yokonikero Posted February 25, 2009 Share Posted February 25, 2009 looks good man. what size tires did you end up running? Quote Link to comment Share on other sites More sharing options...
Brock-Lee Posted February 25, 2009 Author Share Posted February 25, 2009 fuckin awsome bro. FUCK I LOVE THAT REAR STANCE Quote Link to comment Share on other sites More sharing options...
