  • Replies 1k
I haven't checked the cam properly but it seems fine. I'll be checking to make sure the cam is straight and true though.
Current theory is Valve float causing a chatter at high RPM and it's fatigued over time.
1 minute ago, Celica RA45 said:
check your collets on the valves and see if they havnt moved ,looking at that bucket looks like you can see the shim impression ,are you still using ti val;ves
Thanks Glenn, I'll check all the collets. Still using Ti valves as it was just a standard motor that we refreshed. I'll be looking into steel valves for the next build.
Hey @Celica RA45 here's a question...
Since the manual engines run TI valves which are obviously lighter, does this mean they run a softer valve spring as well? Compared to auto engine with steel valves.
also markku we have seen the collets move down the valve with ti valves and regrab the stem in different places to hold on .the weak link is the exhaust valve ,they have a tendency to drop heads
2 hours ago, Truenotch said:
I wouldn't worry too much. I'm pretty certain my issues were caused by this abuse:
Wow, that would not have helped, impressive as it was!
14 minutes ago, Celica RA45 said:
well thats a silly thing to do wasnt it ,were you wearing beer glasses lol
... Yeah, I'd had a few beers... I'd only planned on doing a small skid but got carried away.
Still, no regrets.
