Low n' Slow mk1
davidian
  • Replies 348
It's just due to the fact that before attachments were killed, you utilised the attachment function, removing that capability for reasons unknown, did not remove the attachment icon. There are another few threads kicking about with it still there as well. No drama.
Yeah real good bugger on the phone.. You helping Chris with sizes tonight/last night by the time you read this?
You will prob tell him but what he needs but may as well make a list here.
Rings
Main bearings
Bigend bearing
Need to check crank for marks in which case it will need a grind and we will have to buy undersized bearings. Ideally we want it measured to see ifit has gone oval
Crank seals front and rear
Aux shaft seal
Valve stem seals
You need to ring Bowdins or wherever you get parts from and find out exactly what comes in kits. Bowdins sell a thing called a conversion kit which usually has valvle stem seals and cam seals in it along with head gasket.
I will bring the ridge remover and hone around this weekend.
