pies Posted April 10, 2008 Share Posted April 10, 2008 you get your breaks sorted boe? Quote Link to comment Share on other sites More sharing options...
Gaz Posted April 10, 2008 Share Posted April 10, 2008 He is doing ti right now. New cylinder in drums, twas ceased Quote Link to comment Share on other sites More sharing options...
pies Posted April 10, 2008 Share Posted April 10, 2008 He is doing ti right now. New cylinder in drums, twas ceased yuh saw it last night. go ozzy for makin russel pump brakes till the piston came out Quote Link to comment Share on other sites More sharing options...
Unclejake Posted April 10, 2008 Share Posted April 10, 2008 ^ u shut yo mouf I fisted it out Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted April 10, 2008 Share Posted April 10, 2008 New cylinder in but failed on it not quite being adjusted correctly (hopefully the prob) as the left rear is still slightly weaker than the other side. He also decided to fail me on my new tyres being to much of a change in diameter from the original ones grrr so doing wof with Gazze's bitch n wheels tommorrow morning jut wanna knock the bastard off Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted April 11, 2008 Share Posted April 11, 2008 well done mate shes a minta did you need/get a cert? Quote Link to comment Share on other sites More sharing options...
durty Posted April 11, 2008 Share Posted April 11, 2008 He also decided to fail me on my new tyres being to much of a change in diameter from the original ones grrr so doing wof with Gazze's bitch n wheels tommorrow morning jut wanna knock the bastard off thats so silly i went from 185/70s to 185/55s and they didnt say anything at all Quote Link to comment Share on other sites More sharing options...
Sparkle Posted April 11, 2008 Share Posted April 11, 2008 13s look better than 15s IMO. Hardcore. Quote Link to comment Share on other sites More sharing options...
Gaz Posted April 12, 2008 Share Posted April 12, 2008 He also decided to fail me on my new tyres being to much of a change in diameter from the original ones grrr so doing wof with Gazze's bitch n wheels tommorrow morning jut wanna knock the bastard off thats so silly Aparently is law Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted April 15, 2008 Share Posted April 15, 2008 so man did you need a cert or stick it in for a wof? Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted April 16, 2008 Share Posted April 16, 2008 so man did you need a cert or stick it in for a wof? Na man just got a WOF But true story this one, i will probably go for cert a bit later anyways when got some coin / job. Hopefully all it should require is a drive shaft loop anyways Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted April 16, 2008 Share Posted April 16, 2008 so man did you need a cert or stick it in for a wof? stuff yeh my mate just stuck his 2l in for a wof and the guy just said "nice old car mate and origanal makes a change" didnt even notice it was a 2.l . i would just put mine in for a wof but they will tell me a need a cert cos its low. so i may aswell get a cert 1st. Quote Link to comment Share on other sites More sharing options...
Unclejake Posted April 16, 2008 Share Posted April 16, 2008 Hopefully all it should require is a drive shaft loop anyways You supply the steel strap. I make the loop. Kisses. Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted April 16, 2008 Share Posted April 16, 2008 Mean sweet deal Quote Link to comment Share on other sites More sharing options...
Gaz Posted April 16, 2008 Share Posted April 16, 2008 Hopefully all it should require is a drive shaft loop anyways You supply the steel strap. I make the loop. Kisses. Might as well just get BDA to drop some strap at your workshop then Quote Link to comment Share on other sites More sharing options...
Unclejake Posted April 16, 2008 Share Posted April 16, 2008 ^ No worries/ you guys arrange it. I wanted to purchase a steel cut-off saw anyway I will do so this week if possible I just printed off the regulations and it doesn't mention strap thickness nor mounting requirements. Rivnuts FTW. Quote Link to comment Share on other sites More sharing options...
Gaz Posted April 16, 2008 Share Posted April 16, 2008 I used 60mmx6mm strap. Im pretty sure its supposed to be 5mmx50mm tho. Either way should pass. Has to also have same strap in floor pan so it doesnt rip holes in floor. and two bolts either side so 4 all up. I used m10 I think. Gaz Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted April 16, 2008 Share Posted April 16, 2008 So can it be done as shown in my sweet drawing bellow or does it need to wrap the entire way around the shaft If it needs to go the entire way around the easyest way i can thing of doing it is getting a large tube and cutting a 50mm piece from it then weld tabs to the sides ... or a splitable one would be good ease of fitment. Quote Link to comment Share on other sites More sharing options...
Gaz Posted April 16, 2008 Share Posted April 16, 2008 Wrap right round. and you need two.. One on each universal apparently. 150mm from the universal. Also get M12 bolts just to be safe. They is what you need for your seats to bolt through floor and Id guess they would want similar for DS looop Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted April 16, 2008 Share Posted April 16, 2008 TWO!!!! oh man that makes it like ... twice the hardness Quote Link to comment Share on other sites More sharing options...
