Hi, Im looking at buying a car with the cert plate attached in the rear door jamb, weird place, if i get it id like to move it to the boot, Is this allowed?
  • Replies 9.6k
7 hours ago, cletus said:
Technically only a certifier is allowed to remove or fit a cert plate
You will end up with 4 holes to fill and paint too
Thanks for that, The plan will be to paint the car anyway so to weld up a few holes and paint isnt an issue.
@cletus how likely are these to fail cert on a scale of “this will show up in the fabrication foibles” thread?
I'm picking they won't be looked upon favourably. (Rear shock in a Hyundai H1/Imax with separate coil.)
Eeesh
Never seen that before apart from in a "hey look at this dodgy shit" thread
Looks like the eye would be under a lot of stress welded on the side like that especially if the bump stop is on the shock
Would definitely need some input from LVVTA before certifying that
Just now, cletus said:
Eeesh
Yeah I kinda figured as such. Might be worth going to a traditional shock of the right length or moving the eye. We'll get them in and see what we're looking at
Yeah possibly.
It probably looks worse than it actually is just because it's different
There's 2 potential issues I can think of , one is as previously mentioned,  the eye being stressed but like bling says a gusset would fix that
The other thing is the loading on the shock shaft will be slightly off center.
Which would be similar /less than the loads in a mcpherson strut type suspension
So if the internals of the shock were the same spec as a mcpherson strut (they have a bigger shaft and bushings to handle more load) then its probably ok
Ah yeah didn't think about that loading. Banana shock anyone?
My rear shocks came with similar length sleeve which doesn't make sense (to me) when you have a shock with that much thread to make use of. I ended up swapping mine for sleeves twice as long. Eye is pressed into bottom of sleeve so different design in that area.
On 08/03/2022 at 18:31, Bling said:
Could add gussets full length of the sleeve?
Yeah we discussed gusseting it. Would be a super simple job and the base is steel rather than alloy which is nice. Alternatively, it's actually longer than the factory shock, so the factory shock would fit in there (not valved for the springs, but our certifier up here is a pillock and wouldn't know shock valving and spring rates if they took a steaming giant shit on his chest).
My cousin (vans owner) is an engineer and the suspension company has asked for feedback and installed pics so can probably go back and say "this is shit, send us a shorter shock insert and a base with an eye on the bottom rather than the side".
It's likely done that way so the manufacturer can get away with using a common length shock, I'd bet that most cheaper adjustable suspension companies have a few different length inserts and make top and bottom mounts to suit each vehicle, whereas more expensive high end setups will be made specifically for the car
The fact it has that damper adjuster setup at the top adds a bit of length,  if it was a shock designed for that application then it would probably be more expensive but the adjuster would be at the bottom on the body
I know there are specific limits in terms of camber when going through a cert but is there anything similar for castor?
I’ve gone from a steering box to rack and pinion and it’s increased the castor quite a bit - do I have to stay within factory specs?
Slipping a bit of garden hose on the top and bottom coils of lowering springs to take up the tiniest bit of play when the struts are unloaded. Still fit securely into the bottom and top cups and are captive. Is this a problem come wof or cert time?
On 21/03/2022 at 13:55, rusty360 said:
Hey Mr Cletus, have you ever certed some seat belts in the back of a 105e anglia saloon?
I don't remember doing one for upper anchorages, lowers should be easy enough if it's not rusty
Not like camber. There are suggested figures in the CCM
In general= More positive caster = better
On a lot of older cars, the factory caster settings are near zero or even negative in some cases. Which doesn't work with modern tyres, suspension and steering
I'd suggest using some plain black hose of some sort. There's probably nothing wrong with using garden hose and it will likely work fine but it might be the sort of thing that draws attention from someone who might be a bit fussy
