Everything posted by nvmyvl
On my mates on i used 12mm ali hex rod. Tapped the ende m8 to fit the rose joints. Havent failed yet, and they have been given some pretty harsh abuse
I might know of one of these setup for the grass, if anybodys keen. 125cc 5 speed on it. Goes hard. Or i have a crg kart with a kt100 on in. Full race spec. Raced at te aroha dirt track for a couple of seasons.
I have used the old trick of putting part in the lathe and spinning it, while cutting with a hacksaw. Works quite well for small parts.
If you want polyurethane sheet, let me know. I have racks of it at work. Heaps of off cuts. What thickness and what colour?
Or else I can supply polyurethane blocks in what ever size you want. And what ever shore hardness you want
Have you got the parts apart from the rubber? If so I should be able to pour urethane into them to make up the mounts.
I will have a look at home on the weekend, as I'm sure there is still 2 motors for a front spoiler in my garage. But I may have thrown them out. Can't remember....
did it do it with the old plugs? if not then put your old plugs back in. i have had brand new plugs not work from the box.
Precision laser cut in huia road, otahuhu. I use them for all laser cutting thru work. Cheap and fast
don't muck around with jif or toothpaste, use the proper stuff that works. PLEXUS. its a spray that polishes and removes light scuffs and scratches. if you are near manukau, i have a can that you are welcome to use.I se it most days to clean acrylic display things we make
when do you need it done? i can prob help.. i got a table saw at work.can take 3200mm long sheets. also dressing planks down is not a prob. flick me a PM and i will see what i can do. Im based in penrose. Cheers Blair
Hmmmm I just registered my boat trailer today. Best part is that it's not a 2015 home built (more like a late 1980's), but that's what they registered it as. Just got a 3 year warrent on it as well.
Funnily enough it's out in Pokeno as well. Will find out how much he wants, it's not a HSV one either tho. Was my mates daily driver, but now he has a company ute, so doesn't need it.
looks to be one....... PS I know of where there is one going cheap if anybody is interested. cream on superlows and 20" rims. done approx. 95kms. 5.0 litre
Those are my 20's that are for sale. I have made a few trailers for jet skis and dirt bikes, that look amazing on 20's. That and the other 2 rims were destroyed in an accident.
Bantam, flick me your delivery details, and i will send you some polycarb windows for the louvers. let me know the size. i got a heap of offcuts at work.
Www.raj.co.nz Look at the rubber strips pdf's on there
^^ Ronnie gets his bushes made by me at my work. You will prob be getting red ones. This is called PU40 grade. Has a shore hardness of approx 90A. Colors are indicative of hardness. Dark Blue = 60-70A Orange = 75A Yellow = 80A Red = 90A Black = 95A
What about using Polycarb for the windows? easy to cut with a jigsaw to shape. I can supply the polycarb if wanted.
Wats the pitch on the tap you would need?
Alex's 1968 'oldman special' HB Viva discussion....
nvmyvl replied to yoeddynz's topic in Project Discussion
I work in the Auckland Branch of Mulford Engineering Plastics. Let me know if you need any polyurethane rod and i will see what i can do for you. Possibly easier and cheaper to machine the bushes, than buying them off the shelf Cheers Blair -
ok so lets see if im right............. 1- prob not. the compressor will be running all the time and wont have enough time to fill the tank let alone deliver the correct pressure to spray with. 2 - yes it should be. i use a gravity fed gun from blackwood paykels. cost about 80 bucks. 3 - 2k is better but laquer is good. I just sprayed a VH commy engine bay with laquer and it turned out great. 4 - depending on the size of your car. the VH i am spraying will take 4 litres for exterior im told. My mate bought 5 just to be safe. 5 - Im not in CHCH, but i have been useing my mates double garage with one side blocked off with a tarp. 6 - Yes. Clear coat is always good. brings out the metallic, if you are useing a metallic. Hopefully this is correct.
i will donate the material. looks like sentra is keen to machine. you will owe me a skid in the stock car hahaha
I can supply the phenolic plastic if you find somebody to make it. How soon do you need it? i have a big job on here at work at the mo, but may be able to chuck it onto the cnc when its finished.
