thegreatestben
Everything posted by thegreatestben
My fancy new car with power windows and a stereo
thegreatestben replied to cute wee gem's topic in Other Projects
Love this car, what a life it's had! Glad I saved it twice from owners who treated it like shit. -
I wouldn't be suprised if they changed some of the pinouts. If you're lucky you haven't fried anything and you might just need to repin a couple things.
Pinouts are usually printed on the board in my experience if you dont' have luck with diagrams.
With those brackets you can add some strength/rigidity by staking them on the bends.
Ling post but I would chuck some $$ in a hat to see this thing get an aftermarket ECU.
Are any of the vacuum lines hooked up differently to the stock setup? In my old MR2 it had a smallport 16v motor setup which came from a FWD car with power steering, It always had a high idle when I got it. After reviewing another 16v smallport in a stock car at pickapart I carefully made note of what each of the lines connected to the TB did and worked out the powersteer idle up lines were looped (no PS in aw11 mr2). I blocked them off instead of looping and that sorted my problem. You might have a similar problem with lines being capped/looped?
Checking out a motorbike in Upper Hutt
thegreatestben replied to peteretep's topic in Lower North Island Region
I can probably squeeze this in.- 1 reply
I think the $55 are a cheaper copy of the $100 one. I suppose if you only use it once that hurts but buy once, cry once.
Vacuum fill kits on trademe aren't badly priced: https://www.trademe.co.nz/motors/car-parts-accessories/tools-repair-kits/repair-kits/listing-2534612104.htm?rsqid=208f7d2cbf5348d8b555dd4f1c58d5ad-001
I'd look at thermostat too, had a few cars misbehave badly and all down to a dud thermostat.
Had mine go in the old E34, new (aftermarket) switch was a dud. Found that the original switch worked fine but had worn down in the spot it was adjusted to. So I cut the face of the plunger off and a little bit of length of the shaft. Drilled and tapped the shaft and wound in a pan head screw. I was able to tune the switch into a spot that worked perfectly and will likely last another 25 years
Nice work my friend!
This is nice!! I feel like I know most 80's stuff well but these are new to me. Right up my alley though!
KustomKreeps 49 Hudson - Discussion
thegreatestben replied to KustomKreeps's topic in Project Discussion
This is very cool! -
Probably to the engine but vans are usually a bit tricky, highlux ran into this problem on his hiace doing the same, carb to efi, mani design not compatible with space. Have a look at whether gaskets are all shared on NZ gaskets. Believe they are within years of manufacture.
These are pretty lego, I would go straight to 4y. Got to watch the coolant jacket behind number 4 on the head/block eroding away. So easy to spanner though. My experience is all while they are in a forklift though so can't help you beyond that and maybe LPG haha...
Fucking do it.
Amazing, worth reading before work and being late as a result
chch any auto sparky's looking for a cashie?
thegreatestben replied to d.p.n.s's topic in South Island Region
I hummed and hah'd over a 525i manual one in dark blue. BAD timing. Was a 540i on trademe recently, wanted a bit too much and not really interested in a v8 one tbh. 520i or 525i. Holla if you ever hear of one -
I'm looking for an E34 wagon as well and hummed and hah'd over your one before you bought it. I hadn't owned one at the time and since owning my 535i sedan I've been keen on an E34 wagz. -
Sell it to me -
Bit late now but don't suppose you looked through the output of both boxes? It probably just needs a persuasion tap from el hammeroso. Or is the support bearing slightly off?
Browndog's Supervan 2 (yet another one!)
thegreatestben replied to browndog's topic in Project Discussion
more please -
Favour needed - pick up a car and store for a week?
thegreatestben replied to Rhyscar's topic in Lower North Island Region
I can do this.- 6 replies
- beersies
- help needed
(and 1 more)
Tagged with:
