kws Posted March 16, 2024 Author Posted March 16, 2024 2 hours ago, AllTorque said: Re dash lights, check your alternator and battery. Often when there are codes everywhere it causes by low voltage. A lot of modern cars will turn off the alternator when idling until there is enough electrical load. Oh yeah, i didnt mention it but i tested the battery and alt and both had good voltages. It is a Japanese battery, so no idea how old it is, but it has no issue starting the car. I do wonder since I was creeping along in traffic if the revs, and voltage, dipped a bit low and caused the CANBUS to throw a wobbly. The Alt has a normal solid pulley, so fancy clutched pulley here, so no idea if the ECU can control it. Quote
Goat Posted March 16, 2024 Posted March 16, 2024 I don't think it controls the pulley. It just controls the regulator. But no idea if Suzuki does that though. It was just the/a solution to the problem i would never ever have considered or got to by myself. Battery was fine, car started well. Everything was good until it wasnt. Then it would be good again after a day or so. Quote
jakesae101 Posted March 17, 2024 Posted March 17, 2024 4 hours ago, kws said: Oh yeah, i didnt mention it but i tested the battery and alt and both had good voltages. It is a Japanese battery, so no idea how old it is, but it has no issue starting the car. I do wonder since I was creeping along in traffic if the revs, and voltage, dipped a bit low and caused the CANBUS to throw a wobbly. The Alt has a normal solid pulley, so fancy clutched pulley here, so no idea if the ECU can control it. You can also have pretty wild voltage fluctuations with the ecu regs when they are on the way out. My commodore was all over the show charging voltage wise when the reg was on its way out but didnt throw any codes just noticed because i have a factory voltage gauge. Blairs auto electrical have a massive stock of parts was 120$ and i replaced the reg and rectifier for good measure was relatively simple just need a grunty soldering iron for the rectifier to the windings. Quote
kws Posted March 17, 2024 Author Posted March 17, 2024 Going from my drive this morning, even at almost-stalling rpm the alt is still pushing a min of 13.5v. Normally it didn't drop below 13.8v when driving. Quote
mjrstar Posted March 17, 2024 Posted March 17, 2024 Had a friend's ford territory that did that..one of the main relays was brown inside and occasionally it would only let about 8 volts through.. quite trickey to diagnose, uncool for her when it shuts everything off and every warning on the dash starts scrolling through.. Quote
DB8-TypeR Posted March 19, 2024 Posted March 19, 2024 When we imported the wifes vitz from Japan it would do weird shit. Turns out the fuse for the Alternator "sense" circuit was missing so ECU wasnt able to tell alternator to output anything Can only assume another vehicle nearby on the wharf or ship needed a fuse so they grabbed on from the vitz Quote
kws Posted March 19, 2024 Author Posted March 19, 2024 I'm waiting on a battery tester to arrive so I can test the battery, but being it's from 2019 and spent some time on the docks/ships before i pressed it into regular service, it's probably not living its best life. Looks like the alt is ECU controlled and it's acting "normal" currently. I am not too worried about it, I'm 99% convinced it was my fault for crawling along in second gear with the revs real low. Quote
kws Posted March 24, 2024 Author Posted March 24, 2024 I've been thinking about these for a while, even before I got an Alto, as they are a common mod in Japan. I finally bit the bullet and lowered the front seats. One of the biggest criticisms of the Alto in reviews is that instead of sitting IN the Alto, you sit ON the Alto. The two front seats, despite being nice fancy Recaros, are not height adjustable (lower spec Altos, including the RS Turbo, are) and you sit very high in the car. For example, I'm not particularly tall and my shoulder in the standard seats, is about halfway up the window The other issue was that on the track I had to slightly slouch in the seat for my helmet to clear the headlining. Not ideal. Knowing I want to track the car more, and that slouching in the seat wasn't safe, I convinced myself it was a safety upgrade to lower the seats and gain more headroom. Yes. Safety. So I went on Yahoo Japan and bought a pair of TakeOff Low-Posi Kun seat spacers. These emulate the standard spacers by being one piece with a crossbar between the two legs There are other brands, some of which offer adjustable spacers so you can change the height or the tilt of the seat to suit you, but the TakeOff ones are the only spacers to have the crossbar. I've seen what can happen to Recaro seats when the two rails aren't braced together, and the seat tries to splay them apart. I'm not a small or light person, certainly not the build of person the Alto was designed for, so strength is important. The TakeOff spacers have also been strength tested in Japan and each set comes with an individually serialised certificate of strength testing. It won't mean much in NZ, but it gives me some confidence that the product is good. The TakeOff spacer lowers the seats by 50mm. It doesn't sound like much, but when you put the two spacers side by side it's huge. The top one is the standard spacer, and the black one is the lowered spacer. When put side by side, it's noticeable, as the example photos from the site show Standard Lowered A wad of money, and a few days later, I had a pair of spacers in my hands They're a nicely made piece of kit. Very solid. The included strength certificate It comes with all the fittings needed, if they aren't the standard fittings (it reuses all standard fittings) The thick brass washers are optional spacers to raise the seat slightly. It also makes the rails smoother to adjust. I'm not bothered either way and wanted to go as low as possible, so I left them out I had seen a few different ways to fit the spacers. The most common is to just remove the seats from the car completely, but I didn't want to remove the seats from the car and get them dirty in the garage, so I opted to tip the seats back up onto the folded-down back seat and work on them there The seats are bolted to the car with 4x T40 bolts. You can see the large fabric covered stock spacer here, between the rail and seat. Don't forget to unplug the connector under the seat. These seats don't have side airbags, so I didn't bother disconnecting the battery. This is just the seatbelt and passenger occupancy connector. I unbolted the seat and carefully tipped it back onto the back seat. I turned it so I could work from the back door opening Disconnect the plug and unhook the wiring from the spacer and rail The spacer is then bolted to the seat with 4 bolts (orange arrows) and 7 studs with nuts from the rails below them (green arrows, one side of the rail has an extra stud; 3 on one side and 4 on the other). All are 12mm. I loosened all nuts and bolts before removing any of them. Don't forget to undo the large 14mm securing the seatbelt buckle on the side too. The rail comes off as one piece Leaving the spacer Remove the four bolts holding that on and you have a bare seat. You will need to unhook the fabric from each end of the spacer, I used a trim tool to lever it towards the middle of the seat and unhook it from the metal lip. I then affixed the TakeOff spacer to the standard rails, using supplied washers and the original nuts. Protip, don't mount the buckle yet, it has to go through the fabric on the seat first, so wait until the rail is mounted. Then it was a case of mounting the rails to the seats. The holes are slotted, so I put two bolts on one side of the seat and slid the rail onto those to support it while I put the other two in. There is enough space to slip the seatbelt wiring between the spacer and the seat base. I tightened all the nuts and bolts down and fit the buckle on the side. Once the wiring was clipped and tied in place, the seat was then lowered back down onto the floor, using the locating studs to place it. The bolts were then tightened down. The visual difference was immediate It's significantly lower than the stock driver's seat. I couldn't help myself so jumped in and sat on the newly lowered passenger seat, which made me even more keen to get the driver's side done next. I followed the same procedure, which went quicker this time now that I knew what I was doing, and had the driver's seat installed in no time. Tons of head space now. No chance of helmet issues next time I take it to the track. The little fabric flap now just hangs aimlessly down covering everything. It's not attached anymore, but I'm sure if it bothered you you could glue or velcro it to the spacer to hold it in place. I've seen people cut the fabric or jam it between the spacer and seat base, but I'm happy with it as it is. I've only taken it for a short drive so far, I'm planning on taking it to work tomorrow anyway, but already the differences are pretty big. Obviously, I've had to adjust all my mirrors and steering wheel down (speaking of, the steering wheel is now at its lowest position, so I can see why column spacers exist), but the biggest thing for me is that now I'm looking through the middle of the windscreen, not the top half, and the interior mirror no longer blocks a chunk of my left-hand vision. In terms of driving, the seats feel more comfortable, maybe due to my leg position now, and the car feels a bit more confident in corners. I guess lowering a significant percentage of the cars weight (me) will help that by lowering the center of gravity. It really does feel like you're IN the car now. The only downsides so far are that it's harder to do the old arm-out-the-window when driving, as my shoulder is now just above the waist line of the door, and I've hit my elbow on the armrest on the door when turning once or twice since I'm not used to there being something there. I'm looking forward to my drive to work tomorrow and seeing how it goes around the twisty roads. Quote
tomble Posted March 25, 2024 Posted March 25, 2024 Quote ... now I'm looking through the middle of the windscreen, not the top half, and the interior mirror no longer blocks a chunk of my left-hand vision. Quote
kws Posted March 25, 2024 Author Posted March 25, 2024 21 minutes ago, tomble said: NGL, i honestly think the car was designed to have the seats lowered in the first place and the big spacer was an afterthought, everything falls so nicely to hand now and its much better to drive. It cannot be understated how much better it is to be able to press the HVAC buttons without having to reach down and across. I need to take you for a blast at some point Quote
kws Posted April 8, 2024 Author Posted April 8, 2024 Another thing I had been wanting for a while but was hesitant to buy due to cost finally came on sale, so I snapped it up. Since my car was a track toy in Japan it came with some goodies still attached, one of which was the Cusco front swaybar. This apparently takes the swaybar from the standard 18mm up to 20mm, which Cusco claims is "ratio with standard 138%", whatever that means. Either way, it's stiffer. The bar is so dirty it's hard to see, but it's definitely thicc and blue. I suspect this, along with my blown rear shocks and wrong rear springs, worked together to cause the handling at the last track to day just be straight up hostile. The car would not rotate, it was all over the place, and really wanted to push on in corners. Since I've fixed the shocks and springs now, the one thing left to do to balance the handling was to fit a rear swaybar. The car originally had one when it was in Japan, but it went missing at some point before I got it (likely before it left Japan). The Alto Works apparently has a standard rear swaybar integrated into the rear beam, but I haven't seen how big this is, I suspect tiny. I've been watching the auctions for ages now trying to catch a bargain on a used bar, since they weren't cheap new. I had no luck, but by chance I was having a nosy over on RHDJapan and noticed the exact bar I was looking for was on sale, so jumped at the chance. So, here is my new Cusco 16mm rear swaybar. It's both easy to fit and a real pain. The bolts that hold the end plates to the rear beam have to go under the lower spring pads. Trying to lever the pad up with a trim tool with one hand, whilst using the other hand to push the bolt through, is not my idea of fun It also makes it hard to get the hex key into the bolt to stop it from turning as you tighten the nut. In hindsight, I would probably drop the rear shocks off and lower the rear beam until there is no pressure on the spring and just lift the pads up. I got there in the end though, and the bar fits nicely. As soon as I started the car I noticed a rather large issue; the pipe before the rear muffler was knocking on the swaybar end plate, badly. Doing some research, it seems this is a common thing and the first thing to try is flipping the exhaust hanger. I pushed the car up a ramp on one side to give me some extra clearance Mine started on the stock side, albeit it had been raised up above the normal height (possibly for clearance when the car was lowered) Zero clearance I undid the bolt holding the hanger in place and moved the hanger to the other side of the bracket. I then reinstalled the bolt down into the stock hole, which has the captive nut (the visible nut is just a locking nut the previous owner used to secure it to the upper hole, which doesn't have a captive nut) This gave me ample clearance As a bonus, the exhaust is no longer obscured behind the rear bumper As opposed to A quick drive shows that the exhaust is no longer rattling its little head off, so that's a success. I haven't had a decent chance on the twisty roads to test the new swaybar, but already the car seems to corner flatter and feels more confident in corners. I'll take it to work later in the week and hit some twisties and see how it feels. Since the car was already in the garage I took the chance to do a couple of other changes. One was to replace the rear engine mount with a newer genuine part, and a Silkroad insert. The standard Type 1 mounts are known to be softer than the later mounts, so the new part alone should help tighten it up and fitting the inserts should improve it further, without the harshness of solid mounts. New genuine mount, and inserts The inserts fill these gaps Like so. I slathered them in rubber grease and used a mallet to hammer them into the mount. The inserts are a flexible polyurethane. Interestingly the inserts stick out on both sides of the mount Here's the old mount in place. I first tried to remove the bolt that goes through the small end of the mount and soon realised that no, it doesn't fit The solution was to take the bracket off the gearbox There's a little plastic cover over the hole in the subframe the big end of the mount lives in. This is held in place with a clip on each end, obscured by the swaybar I don't know if it's because of the bigger swaybar, or if it's an issue with the stock one too, but there was no way the mount would slip out passed the bar. I ended up having to undo both swaybar links, and unbolt one end of the D bushes that mount the bar to the subframe, so I could lift the bar up high enough to slip the mount out It turns out the previous owner had given stiffening the stock mount a go at some point. He had slipped some rubber sheets into the gaps and then slathered the whole thing in.. something. Glue maybe? It didn't really help, there was heaps of movement in the mount I slipped the new improved mount in, bolted it all back into place and reinstalled the swaybar. Since the links were off, and I had new ones (because I had previously noticed that the old ones were stuffed), I replaced those too. Unfortunately the nut on one of them was stuck and someone had stripped out the hex in the balljoint (not me) So out came the spinny death wheel, which made quick work of it. And the new links went in with no issue. I did have to source a new nut from my stash though, as genuine links don't come with new nuts (!). With everything tightened up, and the wheels back on, it was test drive time. Immediately you could notice the mount was stiffer. At startup and idle there is a noticeable vibration in the cabin. Not horrible (like my Integra with solid mounts), but it's there and causes a couple of small rattles. Once the revs are above idle though, the vibration is gone, and boy does the mount make a difference. There is no backlash in the engine coming off throttle, and gear changes are even more direct (they were already bliss). Everything just feels more solid. I'll live with the vibration, it's just part of having a road going little track toy, but A+ definitely worth doing so far. Finally, one last small change. I finally got the courage to add a third stage to the boost controller. I know from information about what the previous owner did, that the car used to have three settings programmed by CADCARS on the boost controller before it was exported, "comfort mode" - 14.5psi, "circuit mode" - 18psi and "mountain pass mode" - 21psi. Stock boost is 8psi, and that could be achieved by turning the boost controller "off". I've had it set so A is stock 8psi, B is 14.5psi and C wasn't set. Since I was confident the car was happy on 14.5psi, and knowing it previously ran up to 21psi without issue (I'm not going to push it that far), I finally set C to 18psi and holy moly, I thought 14psi was fun! Accelerating through the gears to 100kph is pretty rapid, but the real fun is around town, where you can just rip around like a madman, whilst still under the speed limit. Coming out of corners, second gear, 18psi, with the LSD gripping like crazy, whilst doing 45kph, leaves you with a massive grin. AFRs seem happy, although intake temp does climb pretty quickly, indicating the little spooly boi is getting pretty close to its limits for not just making heat. Thankfully the massive Greddy intercooler recovers quickly and the temps drop back as soon as you're off boost. Right, I think that's about it for now... *opens Yahoo Auctions Japan* Quote
kws Posted May 2, 2024 Author Posted May 2, 2024 In the early R06A engines like in my Alto, the crank thrust bearing issue is well known. I decided to preemptively replace mine. From 2016 to around 2019, when they changed to the Type 2 cars (which basically just incorporated all the changes made through the production of the Type 1 cars), the crank thrust bearings have an issue where the metal was too soft, and the bearings could wear prematurely. The issue is so prevalent that Suzuki Japan issued a warranty extension/recall in Japan for it, extending the warranty to 10 years/200,000km. Unfortunately this doesn't carry over to imports in NZ, and I've also seen reports that getting Suzuki to actually cover the work means waiting until the engine is basically toast from the bearings failing. Their "solution" is to replace the crank, block and bearings; a full rebuild. My friend Tom @tomble with the blue HA36S, who unfortunately had an engine whoopsie on track earlier in the year, happened to order a spare pair of thrust bearings with his order of bits to rebuild his engine. Knowing my car was in the VIN range of affected cars, I obtained the bearings from him, intending to replace them before things went bad. I was doing this preventitively, not because I knew mine were stuffed, keep that in mind. I had been ignoring the niggle at the back of my mind knowing my car could be affected by it. The usual indication that the bearings are starting to fail is a knocking when engaging and disengaging the clutch, as the force of the clutch causes the crank to move due to excessive runout. My car was what I would consider quiet, for what it is. No noises out of the ordinary, but the other day when I drove the car to work my Android Auto was a bit slow to connect and the first couple of minutes of my drive had no music... and what happens when there is no music, you hear EVERYTHING. At one point, I thought I heard a slight tapping when coming on and off the clutch in traffic. It was quiet, and I couldn't be sure I wasn't just hearing things, my car does buzz and vibrate a bit at low RPM due to the inserts in the rear mount... That day after work I picked the bearings up from Tom. I couldn't risk it. Last night, after work, I put the car up on stands and set about replacing the bearings. Unfortunately they are inside the engine, so not a "simple" task, but overall very doable in a garage on stands, with standard tools (with the exception of a torque wrench and angle gauge, both of which are easy to obtain). The biggest issue is that the sump needs to be removed. To do so, the front pipe of the exhaust needs to also be removed, so there is space for the sump. My bolts were a bit rusty, so with a lack of fire-making abilities, I aimed the heat gun at them on full blast and got them as hot as I could (pretty hot, really). With a crack, the bolts came free. I completely removed it, but I guess you could probably just drop it down and leave it hanging if your rear bolts were unable to be removed I also drained the oil and removed the filter. I did this with an engine that had sat overnight, so as much oil would be in the sump as possible, so I wouldn't have it dripping on me when the sump was off. Next, I removed all the sump bolts and tried to get the sump off. The sump is sealed on with goop, and I battled for a very long time trying to break the seal. In the end, and I wouldn't recommend it if you have other options, I used a claw hammer to pry it free. It worked well with no damage, but you could easily break the sump if you aren't careful. There were two points on the front edge of the sump that were perfect to pry from With the sump off, I had access to the guts. It was very oily, so photos will be limited, but I removed the cap in question (second from the flywheel). With the cap removed you can see the bearings. Thankfully both of mine were still in place; when they get bad one, or both, can slip out and drop into the sump leaving the crank free to move back and forth. The bearings are curved and wrap around the top of the crank, one on each side of the main bearing cap. Using a pick to carefully push on the end of the bearing, you rotate the bearing around the crank so you can slide it out Well, it appears I was on borrowed time This is what the bearings should look like; the old ones are the inside pair There was no sign of any metal in the oil, or in the bottom of the sump, so I guess it's just been slowly grinding itself away over 100,000km. The new bearings (and the "good" old bearing) measure 2.5mm, the bad bearing? It's lost almost half a mm of metal You can tell if they are the original bearings (or at least not countermeasure parts), as the markings on the back will be different to the new countermeasure parts Old New Thankfully the crank bearing itself looked great, plenty more track days left in it The crank also appeared to be in good shape. The "bad" side had some slight ridges in it, but was smooth and still looked polished (some looked really chewed up when the bearing failed) I cleaned and lubricated the new bearings, slipped them into place on the crank, and reinstalled the bearing cap. Of note, was that before I removed the old bearings I could move the crank back and forth in the block by hand a small but noticeable amount. Now, I can't. The bolts are stretch bolts, which means they stretch when torqued correctly. Normally you would consider them one-time use, and replace them, but since I would be waiting over a month for a pair of new bolts from Japan, I looked for an alternative. According to the workshop manual, there is a spec that allows the bolts to be reused. You measure the thickness of the bolt at two specific places along its length; A, where the bolt would thin when stretched, and B, where the bolt should be original thickness. Subtract C from D, and that leaves you with a value that needs to be less than the 0.12mm limit. My calipers wont be amazingly accurate, they're ancient and weren't that expensive in the first place, but the main thing is that regardless of what the reading is, the value still needs to be consistent and less than 0.12mm. Because I didn't want to be left with no bolts that are in reusable tolerance once I pull the bearing cap off, if mine were over tolerance, Tom was kind enough to supply me with his old bearing bolts, since he used all new ones in his rebuild. I went through every bolt and measured them All of them were within tolerance, some more so than others, so I picked the three best ones and knew I could at least rely on them if mine were no good. I checked the two bolts from my engine, and one was 0.10mm, which is closer to the limit than I liked, so I swapped that for one of Tom's bolts and reused the other. Using my torque wrench and angle gauge I started torquing the bolts up. The spec is 30nm to seat the cap/bearing, undo it to zero, and then 20nm, before turning to 45 degrees and then a further 50 degrees. Both bolts torqued up fine, and the first one went to the two angles fine. Unfortunately when doing the first 45 degree angle on the second bolt the little lever that holds the angle gauge in place slipped, so I lost the accuracy of how far I had gone. I ended up removing this bolt and replacing it with another of Tom's bolts, which went fine this time. The sump was pretty clean after draining the left over oil out of it, so I scraped all the old sealant off and cleaned the inside with brake clean I then cleaned the sealing surface on the engine block, which is super fun upside down under the car. Permatex Ultimate Grey seemed to be a good replacement for the Threebond called for in the manual, so I slathered some of that on the sump and fitted it to the engine The bolts need to be fitted in a crisscross pattern from inside out, and were the perfect chance to use my little 1/4" torque wrench as their torque is quite low. The sealant needs overnight to cure, so I finished by installing the exhaust front pipe I wanted to make it as obvious as possible that the engine had no oil in it overnight Today after work, the sealant was cured, so I filled the engine with oil and fired it up. After a quick check that nothing was leaking, everything looked and sounded fine. It appears I dodged a bullet this time. I took the car for a drive, and it was noticeably quieter. I didn't think it was particularly loud beforehand, but there is less "mechanical" noise from the engine now. The two main noises that seem to be gone are the knocking/clunking when I back up my driveway from a stop when cold. I attributed this to the gearbox, as I had to slip the clutch a bit and it wasn't too happy doing it. Now that noise appears to be gone. The other noise was at high RPM, off boost, particularly when decelerating, the car would have a kind of buzzy tapping noise. It wasn't a bad noise, but it was there. This also seems to be gone. Over all the whole engine just seems quieter. I guess the bearing failure was more obvious than I thought. It's a good timely reminder that anyone with a Type 1 Alto (Works, RS, NA or Lapin), Wagon R, Hustler, or Jimny with the R06A engine is on borrowed time with their bearings unless they have been changed. Some of them go fine for many thousands of KM, and some don't last to 50,000km. My car has had a very hard life, and at 100,000km the bearings were stuffed and probably had one more trackday in them before it fell to bits. I'm very happy to know they have been done now, and extremely relieved to have caught that before it wore further and grenaded the engine. Quote
kws Posted June 3, 2024 Author Posted June 3, 2024 Because I can't leave anything well enough alone, I wanted to do some science and see if I could make a low-cost big brake kit for the Alto. I know there are a few options from Japan, which in the big scheme of things, aren't badly priced, like the Silkroad Big Rotor kit, which takes you from 230mm to 255mm rotors, but they aren't off-the-shelf parts, and after shipping its around $500NZD for the kit. Any time I needed replacement rotors I would have to buy them from Silkroad in Japan, with the associated freight costs. There was some info online about people using the "14V" caliper brackets from a Suzuki Swift/Ignis/Kei and the rotors from the same car, which give you a 257mm rotor. So, I found a wrecker that had an HT51S first-gen Swift in stock, which after checking the parts catalogue, had the brakes I needed. I snaffled these up; A pair of calipers with 14V brackets and a pair of used rotors. I knew off the bat that the rotors wouldn't work without some work, but the brackets should fit the standard calipers. The theory here is although it's still using the standard Alto calipers and pads, it moves the caliper further from the center, giving it more leverage on the rotor, and more stopping power. I guess more metal would also aid in cooling too. It's a shame the car lost its fancy 4-pot Blitz brake setup. That used massive 286x22mm rotors, although they don't fit under stock wheels. It's been a long month or so of not being able to drive the Alto. The last time I took it to work the steering was more murdery than usual, with the car all over the place depending on if I was on throttle or not, so something wasn't right. I got home and jacked the car up to have a look, and found the top mount on the LH front strut had a ton of play in it, so I went down a rabbit hole of throwing money at the problem. Now I'm waiting on the parts to do a full refurb of the front suspension, including new bushes, arms, shocks etc. It did happen to tick over the big 100k on that drive home though In the meantime, other than a quick jaunt out to a friend's place to help with their Alto rebuild (always handy to have a second car to know how it goes back together), it's been parked up feeling sad. So with the big brakes in hand, I jumped in, pressed the start button and nothing. It seems three weeks was a smidge too long for the ODB2 adaptor to be left in the connector and it had flattened the battery. A quick jump with my jump pack, and into the garage it went. I jacked the front corner up, and removed the wheel, exposing the cute little brakes That's the stock 230mm rotor. It's 17mm thick and has a hat height of 45.1mm. Ignore the rust, that's just buildup from sitting outside. I removed the caliper and bracket. This shows the difference in the brackets "14V" for the big rotors The stock rotors were a little stuck on, so I used the removal holes and a bolt to push it off. It's interesting to note that the removal holes are very close to the studs, this is due to the design of the hub, which unlike most, isn't a complete circular face. And with the rotor removed, this is the hub. See what I mean about the lightweight minimalist hub? The rotor dust shield is a bit of a joke too. The rotor size difference is noticeable when you put them together The problem with the big rotor, is although the thickness is the same at 17mm, the hat height is different. Instead of 45.1mm like the Alto, it uses a 49mm hat height. This pushes the face of the rotor back towards the hub by almost 5mm. I tried without any spacers behind the rotor first The 14V brackets are in the same location as the Alto brackets, so of course the rotor now hits the brackets (and dust shield). I had really hoped 3mm would be enough, and it's what a couple of people in Japan running this setup are running, but the rotor still wasn't centred in the bracket. It's probably not an issue, but I really wanted it to be centered. I stacked 5mm worth of washers behind the rotor and checked again (because 4mm spacers don't exist) Looked pretty darn good to me. The stock caliper bolts on without issue. The only real problem I have is that now the center bore of the rotor isn't on the center ring of the hub anymore, because the hub tapers from 60mm down to 54mm (so it needs a 60mm CB rotor and 54mm CB wheel... whhhhyyyy) When I did the same work to the Corolla, using 3mm spacers behind the rotors, the rotor was still hubcentric because the rotor was on the hub-centering ring as it didn't taper. It's probably OK, everything is clamped together by the wheel and nuts, but something doesn't feel right about not having the rotor hubcentric. It did look pretty good behind the wheel. You can see how far the caliper is pushed out and how much the rotor fills the wheel Stock Big Boi I've been through catalogue after catalogue and I can't find anything off the shelf that has a similar hat height, thickness and in a diameter similar to the big brakes. There was a Toyota one that was almost perfect and wouldn't need a spacer, but the CB on the rotor was only 54mm, because they don't use a stupid step-up on the hub. There are options for having the center bored out of a Toyota rotor, or another rotor machined to work, but at the end of the day I'm trying to find an off-the-shelf option that doesn't need extra work, is available locally and most importantly, is cheaper than buying a kit from Japan. The Suzuki rotor with a 5mm spacer behind it is the best option so far, but it needs to be hubcentric. I'm wondering if I could fit a 54-60mm centering ring in there, but for now, I've shelved the idea of big rotors. I have plenty of other things to sort out first. I may end up buying the bolt-on Silkroad kit, we'll see. Quote
mjrstar Posted June 3, 2024 Posted June 3, 2024 Can you space the caliper bracket inwards,with a single piece non welded spacer? Edit :Aah never mind it looks like the bracket bolts to the outboard of the hub flange. Quote
shrike Posted June 3, 2024 Posted June 3, 2024 If you can find an off the shelf Hub centering ring that you use on wheels that are different bore to the hub you can put them behind the brake rotor Hope the below makes sense, ive done this on my AE111 for both front and rear rotors without issue, wouldn't be hard to turn up on the Lathe either if there isnt an off the shelf option Id probably make the black lower portion go out to the edge of the hub, could do these out of aluminum, or stainless Edit if it has a taper might may sense to make a tapered locating ring on the lathe Quote
kws Posted June 3, 2024 Author Posted June 3, 2024 2 hours ago, shrike said: If you can find an off the shelf Hub centering ring that you use on wheels that are different bore to the hub you can put them behind the brake rotor Hope the below makes sense, ive done this on my AE111 for both front and rear rotors without issue, wouldn't be hard to turn up on the Lathe either if there isnt an off the shelf option Id probably make the black lower portion go out to the edge of the hub, could do these out of aluminum, or stainless Edit if it has a taper might may sense to make a tapered locating ring on the lathe I think I follow; I considered something like this, basically a hubcentric spacer behind the rotor? The problem i came up against was the clearance from the back of the rotor isn't enough to get anything through from behind (because of the 60mm step just behind the rotor), so i'd need to insert a hub centering ring (like you use on aftermarket wheels) from the front of the rotor to take up the space. Quote
kws Posted June 3, 2024 Author Posted June 3, 2024 2 hours ago, mjrstar said: Can you space the caliper bracket inwards,with a single piece non welded spacer? Edit :Aah never mind it looks like the bracket bolts to the outboard of the hub flange. Correct, the bracket bolts to the front of the hub flange. I could mill down the bracket but I believe that's a big no-no and makes me even more uncomfortable than the un-centric rotors. Quote
shrike Posted June 3, 2024 Posted June 3, 2024 28 minutes ago, kws said: I think I follow; I considered something like this, basically a hubcentric spacer behind the rotor? The problem i came up against was the clearance from the back of the rotor isn't enough to get anything through from behind (because of the 60mm step just behind the rotor), so i'd need to insert a hub centering ring (like you use on aftermarket wheels) from the front of the rotor to take up the space. The problem with doing it from the front is That it could cause issues locating the wheels onto the hub centre? Any reason why it's stepped? If your spacing it out 5mm anyway you could make up on a lathe a tapered sleeve that makes the hub 60mm where the rotor bolts on, ideally you'd start at say 65mm at the bottom on the hub face with the ID of 60mm and then the 5mm up you'd make the OD 60mm and the ID tapered to suit the hub Not sure if I'm explaining that well Would make the hub 60mm to the height you need and then still allow the correct hub bore to suit your wheels @yoeddynzdo you understand what I'm trying to say :p To simplify ID at the bottom to suit the Hub OD of 60mm OD say 65mm or as wide as you can get it to the edge of the drive flange keep that OD for the 5mm spacing you need to space the brake disc then reduces to 60mm to fit the brake disc bore ID tapers as needed to suit the taper of the Hub centre I'd have it flush with the Disc hat face as long as you have enough height of the hub center to center your wheels on if not then you could step it down to the factory size after the disc for the height you need I'd start with a 70 or 75mm solid bar and machine it down from there Makes sense in my head lol Quote
kws Posted June 3, 2024 Author Posted June 3, 2024 7 minutes ago, shrike said: The problem with doing it from the front is That it could cause issues locating the wheels onto the hub centre? The wheels wont be hubcentric anymore, there isnt enough space on the hub center for them to be with a 5mm spacer. They'll have to be studcentric. In my head a locating ring from the front of the rotor would be flush with the face of the rotor. Any reason why it's stepped? No idea, must be a Suzuki thing since the Swift rotors have a 60mm CB and the wheels are 54.1mm like the Alto If your spacing it out 5mm anyway you could make up on a lathe a tapered sleeve that makes the hub 60mm where the rotor bolts on, ideally you'd start at say 65mm at the bottom on the hub face with the ID of 60mm and then the 5mm up you'd make the OD 60mm and the ID tapered to suit the hub I believe there is a pinch point behind the rotor where the space from the 60mm step is quite close to the back of the rotor, so you couldnt fit a sleeve through the rotor Red is the pinch point where you'd have maybe a mm of space to get anything through there since the ID of the rotor almost matches the OD of the stepped section and its very close to it Not sure if I'm explaining that well Would make the hub 60mm to the height you need and then still allow the correct hub bore to suit your wheels @yoeddynzdo you understand what I'm trying to say :p To simplify ID at the bottom to suit the Hub OD of 60mm OD say 65mm or as wide as you can get it to the edge of the drive flange keep that OD for the 5mm spacing you need to space the brake disc then reduces to 60mm to fit the brake disc bore ID tapers as needed to suit the taper of the Hub centre I'd have it flush with the Disc hat face as long as you have enough height of the hub center to center your wheels on if not then you could step it down to the factory size after the disc for the height you need I'd start with a 70 or 75mm solid bar and machine it down from there Makes sense in my head lol Quote
