Forgot to mention I bought this thing from a dealer and got a 1 year 'Protecta' mechanical warranty thrown in.
From the warranty booklet:
Suspension air bags, shock absorbers, rubber components that have failed due to wear or degradation and catalytic converters are specifically excluded.
But I did manage to claim for the instrument cluster repair when the speedometer stopped working.  So a $900 job only cost me the claim excess of $395.
None of this surprises me as I have weekly phone calls with these warranty companies about customers vehicles... But everyone seems to be shocked and offended when they find out how little is actually covered.
So let this be a lesson.  Read the exclusions, actually fuck it - read everything.  Owners manual, insurance policy wording, anything you are buying or signing.
  • Like 9
12 hours ago, Nominal said:
Land Rover is high performance
Not really….. but really, really unreliable and not small problems either. The insurance companies know this.
15 hours ago, Nominal said:
How come the XJ8 is a cheaper purchase?
The regular v8 is lower spec and they made more of them.
8 hours ago, RUNAMUCK said:
To a dumb hillbilly like me, 06 is a pretty new car. Surprised so much has given trouble on a car so new?
There's a reason $160,000 fell off the price tag. Still a reliable car compared to a BMW.
  • Haha 1
I know I really shouldn’t but I really like that.
Agree on the colour of the interior though. She’s a bit old man’s jacket. The grey appeals.
Hmmm "air suspension fault" on the dash, all shocks on full hard and no ride height corrections happening.
"Leveling plausibility error" isn't very descriptive but usually seems to mean an air leak between the compressor and reservoir or a tired compressor.  Couldn't see any leaks at the reservoir or valve block so time to remove the front guard liner and have a look at the compressor, if I can't see any leaks I'll throw a piston seal kit at it.
And will continue to ignore the cat efficiency faults
Done some diagnosing today. I'm putting my money on either the compressor exhaust valve sticking or the main valve block.
All ride height sensors read normal and the only pressure sensor is showing sensible numbers.  Couldn't find any air leaks.
The only way for air to leave the system is through the exhaust valve at the compressor. If it sticks open, the compressor can't air up the reservoir tank and whenever a strut valve is open, the ride height decreases as the air goes out the open exhaust valve - even with the reservoir valve open. So the system gets confused, throws a plausibility error and shuts everything down.
Looking at the live pressure data while driving, this all seems to add up. Next problem is the exhaust valve is part of the compressor assembly. So I might spring for a new one.
More diagnosing and I was pretty sure the exhaust valve or compressor was the fault.
Managed to remove the compressor in half hour, easier than expected.
Dismantled it on the bench and found absolutely nothing wrong with any of it.  Piston rings looked good, the exhaust valve assembly was clean with the right resistance on the solenoid. All the check valves work.
Stuck it all back together and commanded all struts and the reservoir to air down. Starting from there, it pumped everything up to pressure in a normal amount of time.  About 3 minutes to get the car leveled and fill the reservoir to 200psi.
Watched the live ecu data as it was doing it's thing and everything appeared to make sense.
Then it threw the suspension fault light again. So now I have absolutely no fucking clue what could be wrong.
Tomorrow I'll try recalibrate the ride height sensors and have a play with the valve block.
  • Like 8
Pulled the valve block and reservoir this morning.  It sits under the spare tyre in a little foam igloo so it's pretty easy to get at.
Of course everything was dry, free from corrosion and looked fine.  I put some pressure into each port and nothing leaked noticeably.
So I had another go at a ride height calibration.... Which failed as usual. Unable to complete the air up procedure.  The car looked pretty level to me!  Used the scan tool to get it to air all the struts to maximum height and then I found it.
At normal ride height, it doesn't leak.  But as soon as you get any droop on that corner - whoosh.  The system doesn't have a ride height sensor on the driver's front, it just uses the passenger side and looks at the pressure difference between them.
Anyways, its decision time.  The passengers front strut started leaking a few months ago so I threw in a second hand one which ended up having a good air section but the shock is mega soggy.  Do I;
A) Replace both front air struts with new Jaguar/Bilstein ones.  Everything will work, probably won't get change from $4k.
B ) Replace both fronts with Arnott ones, they delete the active damping (which I quite like). Closer to $2.5k.
C) Convert to Jaguar S-Type R coilover struts. Maybe $3k with some modified or custom front strut tops....assuming I can still find the parts
D) Use the Arnott Eibach coilover conversion kit. Worse ride, no adjustable height or damping, higher ride height than I'd like. It's the simplest conversion to do where everything will bolt in and play nicely. Probably $2.5k
E) Roll the dice on a pair of second hand struts and see how far they go.
Most people online seem to think the adaptive damping isnt worth saving but I think they've never driven the car in a way to make it work - its pretty noticeable when you start throwing the steering wheel around.
2 hours ago, VitesseEFI said:
Struts not rebuildable? I mean I’m sure they’re not intended to be but maybe can be done?
Nick
All the gubbins is glued and bead rolled / crimped together like a coke can.  There is a crowd who do rebuilt ones for $1500 each but their reputation is shithouse in the Jag community - lots of early failures and dead ones out of the box.
