Correct radiator for this will be a p10 primera. It's the same as the ga15 wingroad in dimensions and style, but it has the 35mm hose outlets for the bigger SR hoses.
There's one at the wreckers, old but in good cond. But I'd rather pay another $50 and get a new one:thumbleft:
  • Replies 169
Good choice. I only have regrets from wrecker radiators.
I took the rhs engine mount out of a h11 presea
It is the correct type.
However I will also need the bracket/plate it bolts to on the engine as the bluebird one is different again. Maybe someone has an Sr20 dead on their floor? Be easier to take it off an engine not in the car, bit of a pain at the wreckers as it slumps over when you pull the mount
Basically I chose a bad donor, but it was a great car to drive till the wof ran out and there was nothing cheaper, so I might have to buy a blown facebork hustle engine for a few bits
Are you sorted for flywheel etc? I believe this setup collecting rust in my shed is to suit sr20.
The Original plan was to mod it to fit between Evo motor and 370z gearbox, but Nissan rb26 made way more sense once I found out it shared the same crank pcd as early 6 bolt 4g63
How many spline is the clutch?
All fwd sr20s (not 4wd/det. 4wd is same, larger, diam as rwd) have same diam flywheel, but if I change boxes I'd need a different clutch and pressure plate
I think that's for rwd
Bluebird one is 215mm diam, 24 spline,  25.4mm spline diam
Somethung with a 32a box would have 215mm diam, 18 spline, 20.5 spline diam
Stock RWD SR20 clutches utilize a 240mm diameter, 24 spline clutch disc with a 25.6mm diameter sprung hub.
I believe I wouldn't physically fit on the fwd flywheel
This is the bracket I need to swap for the engine mount.
IMG_20221016_134314_edit_717591265389982.thumb.jpg.60f60818fe3bce4969e82f5800a28c25.jpg
There should be about 70mm centre to centre on those top end bolt holes, with the centre one being about 37mm taller.
This bluebird one is wider and taller
Had a brief look at the wiring. If you have a Ga16 sentra and you get the correct Sr20 donor, you can just plug everything in.
In my case that is very much no. Not sure if it's because ga15, but I think really its because of what I'm calling "big nissan" donor.
Not a huge issue in my case, I expected as much, and even more so it doesn't really matter because I'm putting the haltec in it.
I might check out some other SR nissans to see what their loom does, as it might be worth it to change a section of the loom to the correct type for in cabin plugs.
First up was the alternator sub loom. Bluebird has the same plugs on the alternator and aircon pump, but car side is different. Unwrap the bluebird alternator loom section, as it is partially connected to the rest of the engine loom. Unpin the yellow with red stripe and the white wire from the grey 8 pin plug. Can now seperate the bluebird alt sub loom
Ga15 alternator loom is already fully seperate, so just have to unclip it and attach it to the Sr20 alternator (80amp vs the ga's 70amp)
The loom clip thing needs to be moved a little, so the wires aren't too strained
Otherwise that's it
The ga actually uses much heavier wiring for this too, also sr has 2 power feed wires coming off the alt. mildly interesting
