Haven't actually measured anything but it looks like this is the outer cv situation
Y10 wingroad
25 hub spline, 22 axle spline
U13 bluebird
27 hub spline 25 axle spline
  • Replies 169
I can get some out of the states if I have to
The factory Sr20 wingroad doesn't exist on amayama or in any parts lists which is dumb because I want part numbers.
I might even change the hubs to something 114.3x4 to match the disk rear
The ones I posted are available in nz
Was one at tga pick a part a year or so ago
can you use the Bluebird front suspension complete? like put the whole hubs/knuckles on? that way you get your 4x114, bigger brakes etc
The ones on the donor need everything replaced. But possibly.
Later wingroads are used to upgrade stuff as well. Tho this wingroad already has "the big brakes" on it that sentra foamers want
At this point il put the engine in and check the axle lengths for a start. There is 100% a factory set of axles and cvs that will just go on without changing anything. This will probably take me another 6 months, so the donor car will be going as a rolling shell, let the budget build back up too
Lol last month I sold a set of multistud 5 spoke wheels nearly identical to the ones I have on the car now, cos why would I need those. The ones I have on are only 4x100.
Found it, and it makes sense I guess
Y11 wingroad sr20ve appears to have a 25/55/25 with 42 tooth abs ring
Bout 150 each
Looks like all the Y10s have the same outer cv splines, so they must use different axles. Early early y11s were just a face lifted y10 as well
Not that common engine fitment
Seems to also be a Presea PR10 fitment, and sentra/tsuru 2.0 which is what axles all the Americans use for Sr20 swaps. So easy to get
Current plan is
See if disk rear end actually fits. If it does I will convert the front end to 4x114.3 using Y11 wingroad hubs and spindles. (Y11 AD van are apparently 4x100) this gives you a few bolt on brake options. Can go 4 pot r32. But I will probably go for 11" disks and calipers from a p11 primera (m6, I think this is the one with white gauges/cvt or vvl. Needs 15"wheels). Possible that avenir brakes also bolt on to the Y11 spindle so could also do that and just do a full avenir brake swap. Which would be 11" and twin pot.
(bluebird doesn't have abs so would have to rig up the sensor into that, so never mind)
  • 4 months later...
Pretty sure this has sat on the lawn for 12 months
Ga15 started on the first crank
It sat cos I needed to turn it around to weld up the bum, but there was a car in the way for months, and then it was winter and rained for months.
Proba bly pull it to bits now while I wait for parts for other stuff
BUY a scooter so I can get it in the shed for paint
Im a tard, the ones I have are also multi stud
IMG_20221007_164029_edit_211733067621337.thumb.jpg.e93e4cf21fcd3bb8c838f7ea002e7b20.jpg
Wingroad drum rear end. The spindle is welded on, I think you could grind the welds off, you would have to weld up the two holes at the top as they go right through and re drill as the bolt holes for the disk spindle fall within, but slightly smaller of that. Abs ring is smaller and 42 tooth.
Bearing HU8042
Bolt pattern 94mm wide
68 tall
Here is a drum hub sitting on a dusk spindle
IMG_20221007_161704_edit_212410382025400.thumb.jpg.66ca5a722cdffa1259389c8aef762483.jpg
Other than the abs ring they seem to be interchangeable
I'd like it if the abs worked, so something to consider
I measured both rear ends and it looks like the disk one is 3cm wider. Measuring this at the spring perches and shock mounts
The bushings at the front look to be the same width so they will slot in. There is easily enough spring in the arms to take up 1.5cm each side
They are however 4cm longer, so would push everything back that much. It might be best to just chop the drum spindles off and drill and tap mounting holes for the disk spindles to bolt to
I bet the drum beam has these spindle locating pegs as well, so that will make locating the holes easy as
IMG_20221008_140932_edit_258635303122513.thumb.jpg.4035d2f22723b5d565f039de01d4d23a.jpg
Will also need to cut the flex hose mounts off and weld them on the drum beam. Then some minor changes to the hard line to get them to line up.
Needs handbrake cables with a loop end, probably avenir ones, but they may be a bit long. Don't think that's a major to have made if needed
Wheel track will be exactly the same which is cool.
The drum shoes have about 1mm of meat left on them, so good timing, probably just put the wheel back on for now, now that I have an idea of what's needed so I can wheel it around for engine swap
Fired up the good reliable, economic, zippy GA15de for the last time (to take a video incase I sell it, but always on the lookout for a body with blown engine)
Got removing stuff. It's pretty quick, it's just fuel lines, power steering lines, 2 grounds, 6 plugs, aircon lines, radiator hoses, intake pipe, push loom through firewall, shifter linkages, exhaust and then 4 engine mounts.
But I got stuck at the axle nuts, needs a deep 32mm, I have 2 32mm sockets but not a deep one.
So tomorrow crack those out and celebrate taking another perfectly fine running nissan off the road.
Offered up some parts to see how much more I have to spend at the junkyard
This is the bluebird radiator. It's wider and taller, fits bottom mounts, bonnet closes, could be made to work easily (Sr20 has bigger diam hoses)
Top of core is in line with panel
IMG_20221013_161718_edit_531371577701731.thumb.jpg.14b93f3d4df55ad13a1a2a64234131f4.jpg
So it would sit on a very slight angle. I think a little foam in between there and some top mounts to hold it a little back and it will be fine.
Unfortunately my ga15 rad is excellent cond, replaced recently. Bluebird one not so good but entirely functional.
If I have to get a new one il be looking at other nissan ones Sr20 sentra maybe
IMG_20221013_162218_edit_531536806464726.thumb.jpg.c774992beaa11eb94b6611898e3b12e5.jpg
Fans plug in no worries, Sr20 fans are thinner than GA fans BTW.
Hopefully itl clear the engine when it goes in, and hopefully itl clear the turbo and alternator etc. Sounds like people fit one Sr20 fan for clearance if they don't have a full donor. (it doesn't matter, but the metal shield just barely clears the alternator on the GA with the bluebird radiator)
I also offered up the crossmembers that goes front to back under thr engine, with the mounts on it. They are different construction. Ga15 has a tube type member, Sr20de has pressed steel.
The front mount appears to be the same, can't see the rear well enough but I'm told it's different and you need the Sr20 one. The members them selves look to be the same length and spacing, so with some luck I can use the Sr20 one complete (not a major to swap the rear mount, it just looks a bit beefier, assuming all the distances are the same otherwise)
Will confirm all mounts once the engine is out. Potentially need to use the bluebird high pressure steering hose. Apparently you can use the aircon system with what's in the car without major work.
