3 minutes ago, fletch said:
Want me to have a look for you?
It says someone has taken a rear drum, which I don't think is true. If its got a disk rear end I'd be very interested in it
  • Replies 169
12 hours ago, RUNAMUCK said:
Does this thing go Zutututu yet?
Had to tuck it out of the way for access to do work on the house, now I'm gona resow my lawn so minimal access to garage till that comes in.
Now that some house supplies (several tons of rocks and soil) have been used up I can roll it back and get a little done on the driveway while the baby is otherwise entertained.
Pretty much everything is there to go now, need to skim flywheel and drill sump
  • 7 months later...
Got a 97 dated momo steering wheel and a boss kit for about $20 all up. So il probably cert airbag delete.
Nissan wheel is growing all sorts of gross stuff on it even after a clean
Steering wheel was pretty worn, has like a million kms on it, had been thinking about grabbing one from the wrecker, but also about an after market wheel, and going through pulling thr 25 year old airbags out as its getting carted anyway. I actually got the boss kit like 2 years ago
Looks alright I think l. Th3 momo also has about a million kms on it, but inwill have a go at recovering it with some fresh leather.
Fitment is about the same, maybe 1cm slimmer to the dash I guess.
Will have to sort something out for the horn, wingroad has airbag, horn and clocks print set up. Ad vans and y10 sentra wags don't have airbags, so might investigate their steering columns to see if itl be easier to set up th3 horn contact with those parts
Il also pull the passenger airbag, the computer, and I think I need to replace the front belts as they have the yellow wire going into them? Not sure if that's a requirement from a cert pov
Probably non airbag ones from the above cars
