  • Replies 88
  • 5 weeks later...
And thats a wrap. Carib went off to its new owner today. Will be in wellington for a bit and then heading up to Whangarei.
Its a shame to pass it on without driving it in anger on a track, but the wagon ruined it for me. I miss the Liftback, it was a far better platform to drive. I never built up any confidence in the wagon, and it wasnt enjoyable to drive.
I found it quite funny, I took the Tomcat out for a quick drive after work, and then drove the Carib to meet its new owner. The Carib was such a contrast; the controls were light and easy, but it felt like it was powered by a 500,000KM 4AF. SO slow and gutless around town. On the motorway, up at high RPM, thats where it shines, but otherwise shit it was flat.
The Tomcat on the otherhand left me grinning and chuckling like an idiot.
  • Sad 1
  • 1 year later...
On 21/05/2021 at 22:16, kws said:
Ever since looking for a Corolla, the goal was that it HAD to be manual. Autos are lame, and no good for a fun weekend/track toy. With my car, I made the compromise of an auto based on availability and cost, but with the knowledge it would be manual swapped in the near future. Well, that time has come.
I've been squirrelling away parts for the swap since I got the car, and a couple of months ago the big bits fell into place. A C52 manual transmission, flywheel with near new clutch and various other bits I need.
During the Pick A Part run when I first got the car (the same time I got all the seats) We also pillaged a manual AE111 wagon there for the other major manual bits we would need like the shifter base with cables, master cylinder and pedals.
With everything finally falling into place I arranged a time to take up some space that Iain, the friend helping me with the swap, has at a lockup, as doing the swap there with ample space will be easier than in my garage.
We planned that with the two of us it should take two days, but we were realistic that if anything goes wrong it would be pushed out, and that was OK, but it had to be done by the end of the week.
The plan was to remove the engine and box complete. I had debated if this was the best way and came to the conclusion that it will be easiest to deal with the various bits we need to swap over (such as fitting the shifter cables which is a ballache with the engine in place), and if I choose to do the cambelt and waterpump at the same time this would be a lot easier than in the car. Having the engine out of the car means we wouldn't have to try deadlifting the gearbox up onto the engine from under the car and line it up. That's never fun.
Sunday
The day before we were due to pull the engine out I had a list of jobs to do to prepare the car for the work. The main one was to strip all the interior dash trims out to gain access to the pedals and center console/shifter. Taking it out now means not having to do it at the lockup.
To remove the panels the first part that needs to go is the center console with armrest. This is held in with two 10mm bolts in the armrest storage area, and two screws on the side. Under this was festy (this is a word you will hear a lot when I'm talking about the interior of this car...). Much crumbs.
Next, the center stack needs to come out. To do this remove the three climate knobs, and the recirc slider and then remove the two screws behind the far knobs.
The center stack will just pull out after that. Its held in with some clips at the top so might take some pulling. Be aware there is some wiring going to the cigarette lighter socket, and that will need disconnecting.
This leaves you with the bare climate control and whatever is in the center area (a useless CD player and single DIN pocket in my case)
Now remove the contents of the center stack, usually a double din bin. There are four screws securing it. This reveals the ECU (and lots of festy as all hell mould from leaking drinks).
Next the glovebox needs to be removed. This is done by removing the small trim at the bottom of the A pillar that tucks under the kick panel. Behind that panel is a bolt, remove that, along with the screw in the opposite bottom corner of the glovebox panel and then the three screws along the top edge of the glovebox when open. The glovebox will pull free.
The other part to remove is the trim above the drivers legs. This is once again held with a bolt behind the little trim panel at the base of the A pillar and a bolt in the opposite corner. The top edge is held in by tabs. Behind this, there may be a steel plate, which I guess is some sort of impact protection thing, and this is held with three bolts.
Now you can remove the rest of the center console. Its held with two screws on the far left and right top corners (would've been behind the glovebox and knee panel). It clips in at the top too. To gain more access to the shift cable retaining plate under the dash I also remove the footrest; this is done with a good hard yank toward the rear of the car.
Feels a bit weird driving around in a car with only half a dash and no center console.
With the interior ready to go the only other work I needed to get done was to replace the axle seals on the gearbox, and replace the shift linkage bushes.
The axle seals are easy enough if you know what you're doing. First note is to take photos or make a note of how recessed the existing seals are. In my case, they were at the base of the chamfer, but I didn't take note of this when fitting the seals, instead hoping they would bottom out (they don't) and I ended up pressing them in too far.
This was a cockup that resulted in my wasting new genuine seals and having to fit aftermarket seals instead as removing them damages them. Removing the seals with the correct tool is easy enough though
To drive the new seals in, place the old seal over top and use a hammer on the old seal to drive the new seal into place. Take care it goes in straight, and to the correct depth. It also helps to lube the outside of the new seal to help it go in. Once the seals are in place slather the inside lips in rubber grease to reduce any risk of the axle tearing the seal when refitting.
The shifter linkage bushes were easier. Under the rubber cap is this nut. Remove it.
The linkage will then slide off. Take care of the lower slider as that can fall off, and the orientation of the rubber boot. There is a bush in the arm, and one in the rubber cap above the arm
The old ones weren't too bad, but they were running dry with no lubricant at all.
If your slider is plastic you can replace it, but in my case mine is metal so I cleaned and lubricated it before refitting. The slider is the bit in the centre of the photo. The new bushes got lightly lubricated before fitting too.
Refit the washer, nut and then the rubber cap
Job done. The car was loaded up with all the tools I thought I'd need (Needed more), all the various parts, and the next day it was driven to the lockup to begin work.
Monday
I met up with Iain at the lockup, and backed the car in. After unloading, off came the bonnet and we looked at what we had to do. Iain had taken the time to write up a very comprehensive list, which we started ticking jobs off as we went.
Up on stands, and this is how it spent the majority of its time. Quickjack would have hindered us in this job as it would have restricted access to under the car, as I spent a lot of time with my legs sticking out the side.
With the car on stands, all the fluids got drained and the battery removed. Of course, the drain tap on the bottom of the cheap radiator isn't drilled through so doesn't act as a drain tap. We also cracked the hub nuts as this requires a lot of force and someone to stand on the brakes to do. They're torqued to 215NM, so quite tight.
It's interesting how dirty the auto trans fluid was too. I haven't checked it since I got the car, and the trans was shifting fine (for a late 90s 4 speed auto). The fluid was black and stank; well overdue for a service.
The wiring loom was disconnected from inside the car, and fed through the firewall. The body side of the fuse box was disconnected and the engine side was left to go with the engine. The radiator was removed, and all the coolant hoses disconnected from the engine and tucked aside. The heater side of the heater hoses can be hard to remove and risks deforming the pipes, thus we removed them from the engine instead.
This is the big lump we're aiming to scrap
Next the axles had to come out. These are a pain to remove as they have a spring clip inside the gearbox. One of the shafts is accessible from the top, with a long bar and a hammer to whack it free, the other is only accessible from underneath, which resulted in me under the car on my back beating the CV with a pry bar and hammer until it popped free. When hammering on the shaft there are notches in the CV cup that you can use without causing damage
Before we could hoist the engine out we had to sort one critical thing, the AC. I didn't want to degas the AC system, and since it worked really well we had to be careful to keep the system intact. We unbolted the compressor from the engine and lowered it down onto a jack. This moved it away from getting caught up but stopped it hanging on its own hoses.
The last thing to do before removing the engine was to disconnect the mounts. The Front and RH mounts are easy. The rear is a pain due to access but isn't impossible. Stack a bunch of long 1/2" extensions out through the RH wheel well and use a rattle gun on it to remove the through bolt; it has a captive nut.
It's a different story when it comes to the LH (transmission) mount. On the auto, Toyota has made it as hard as possible to reach all the fixings to get it free, because hey, why not eh? In the end it was a mixture of ratchet spanners and squeezing hands into spaces that are too small that got the bolts out.
With that done it was time to lift. A leveller is essential for this job, it's basically the only way you can get the engine in and out without smashing a whole bunch of other things in the engine bay. To get the engine in and out you need to tilt the trans hard down.
The poor engine crane was making some interesting noises lifting this lump. It's amazing how much heavier the auto and torque convertor is than the manual.
We finished the first day with the engine and auto out and on the ground ready to split.
Its a bit oily down here. Most of this is from the valve cover and distributor O-Ring that were leaking when I got the car. It must have been leaking for years.
Its also left a bit of a mess on the crossmember
So the plan for Tuesday was to do the things you don't want to do with the engine in the car, such as the master cylinder and shifter cables. We also needed to fit the pedals, and run the clutch hard lines on the firewall.
To be continued.
That pulsar exa in the background, i own that now. Do you have a thread on it? Some history would be nice
Unfortunately can't help on that. Not my car (was a shared space) and I can't recall who owned it. It was a regular at the local autocrosses with the HVMC.
You should definitely start a thread on it, exas are cool.
+1 for exa thread, very cool and hard to come by car these days.
  • 11 months later...
Instead of making a new thread each time I buy a less interesting to most, but could be interesting to others, car, I'm going to revive this thread and throw them in here.
22 minutes ago, thegreatestben said:
Spicy leaf! I reckon it will be hard to go back to a non ev for a daily appliance, suspect you'll agree.
I'm hoping I'll be rich soon enough so I can buy a new 5 series EV wagon <3
I have heard that. I love the GE8 Fit a lot, so will be interesting to see how this compares daily. Just waiting for a type 2-1 adaptor to show up and then I'll be able to leech some free power from work too :lol: Tomorrow I'll run the gauntlet of getting to work (Porirua) and back (Upper Hutt) on a single charge (should be easy)
I loved my leaf, same year and specs, except mine had alloys and no hidden spice.  They all handle well though considering their weight, many a time have I had ABS kick in because its overly reassuring planted nature.
Strangely, prices have gone up slightly since I sold it late last year... possibly because the subsidy is gone.
I do like that colour a lot. They look better in a darker colour (except black) than the lighter shades.
Pricing is all over the place at the moment, mostly because half the people selling are trying to dump them before the RUC comes into effect, and the other half just want to upgrade to something newer, so it's split in the middle. Leafs (leaves?) with real bad battery SOH are a dime a dozen too, it takes a bit of work to pick through them and find one that has a good battery.
Can confirm it can do Upper Hutt to Porirua and back on half a charge, even with the heater on. I can see why most Leaf owners avoid Transmission Gully though, that shit was brutal on the guess-o-meter, watching the ks drop away by the second.
So far enjoying the car. It's a nice appliance. I'm driving it like a normal car currently and not really trying to hypermile, so I'm surprising a few people on the road by not being the slowest thing around. Traffic light drags are a laugh too. I do find that without the reassuring buzz of the ICE at certain RPM to judge my speed by, i find my speed tends to creep up a bit.
  • Haha 1
I never pay attention to the guessometer. It's wrong no matter what the battery % is. It's best to look at the % readout if you have it on your leaf, you should.
My experience with 76%~ SOH 26kW leaf...
  • 86km round-trip work commute, a heavy foot and a penchant for cruising in the fast lane at cheeky fractions of the speed limit: no problem in summer, but sometimes got home with 5-10% left in particularly cold rainy winter days. Girlface managed 20-30% though so totally fine for better drivers.
  • Could get to Palmy and back with a stop in Otaki to get to 80% each way (and an 80% stop in Palmy).
  • Upper Hutt to Wellington airport and back is fine in summer, probably want to stop at the pak n save on the way back in winter.
  • Charging to 100% is fine, don't nickle and dime the battery, it'll drop regardless of what you do.
edit: oh and my leaf's speedo reads 10% under the real value, apparently it's pretty much all leafs that do this and is why you often see leafs crawling in the slow lane at 90.
edit 2: you're going to fucking love this coming winter when you find out you can set the climate control to have everything warmed up and the seat ready to heat your arse when you jump in for your morning commutes.
44 minutes ago, Bling said:
How long before we need a Leaf thread and get banned from OS?
I'm waiting on diy battery modules/Cell replacement or upgrading battery packs haha
Later model motors?
