The Boring Cars of KwS
kws
Somewhat off topic but I'd totally contribute to a leaf thread.
Swapping leaf engines into things is a thing.
Swapping non-leaf engines into leafs is a thing.
Upgrading leaf components and hacking them to go faster is a thing.
 They also work great for riling up your backwards racist uncle at the family bbq :)
  • Haha 4
  • Replies 80
In my quest to not spend any money and do nothing on the Leaf, I spent money and did stuff on the Leaf. Yeah.
In my defence, part of it is maintenance, and part of it is stuff I had in the garage already.
A local EV part supplier was having a sale on a "Leaf Bundle" so I decided to grab one. It included a cabin filter, two front strut caps, and a LeLink OBD2 dongle for Leafspy.
The strut caps were pretty easy. I removed the two covers on the cowl
Which gives access to the strut tops. One of mine was in good shape but drowning in water, so I dried it out, buzzed the rust on the top with a wire brush, coated it in WD40 and fitted the cap
The caps are nicely shaped and 3D printed, designed to snap into the lugs in the center of the top mount. They completely cover the whole top mount, so there is little chance of water pouring into them
The other side was a bit crustier, so I dried it out and gave it a good scrub with a wire brush, before again soaking it in WD40 and capping it off.
Next, since the bonnet was open, I moved on to fitting some LEDs. On this car, the low beam is some fancy and really good at night LED setup, which is very crisp white. Nissan paired these up with normal yellow park light bulbs
I had some T10 LEDs already, so popped the big cap off the side of the lamp
Which gives access to the park light bulb holder
This rotates counterclockwise to remove the holder and bulb
The bulb then just pulls out. After test fitting and checking the polarity of the LED was correct, it was refitted
The results are rather obvious. They blend in with the low beam LEDs much better
In theory, they should use a little less power too. So, you know, savings. Eco.
The interior was treated to some LEDs too, for more eco-savings
The one in the boot didn't miss out either
Serial killer cold white, of course, for maximum SPACE AGE feels (not just because that's what I happen to have).
Moving along, next up was to set up the LeLink adaptor and fiddle with Leafspy Pro.
Screenshot_20240509_183513_LeafSpy-Pro-1
So my SOH is 71.56%, a bit lower than the 75% I was hoping it was, but shouldn't be an issue. The battery seems to be pretty well balanced too, with a low voltage differential of 17mV. Obviously previous owners haven't done a lot of quick charging either, as in 108,000km it's done 173 of those.
The other thing I wanted Leafspy for was to convert the language in the dash display to English from Japanese. The media unit was already converted by the previous owner. A quick and easy change in the advanced settings and everything was in English. Very easy to do, and almost worth the cost of the Pro app alone. People charge $80 for this service.
Finally, I had a nice replacement cabin filter that needed to find its way into the dash. This was a real pain in the bum, to be honest. I had seen a couple of videos about replacing them, so wanted to try the through-the-glovebox option first.
There is a little door at the back of the glovebox, that is removed with a gentle tug
With it removed, you can access the filter cover. This doesn't line up with the opening you just created, it is further back in the dash
There is a clip on the top which I lifted to remove the cover
With the cover removed, I grabbed the filter and started to manhandle it out of its home. It liked its home, it really didn't want to be removed.
It turns out, that the filter is much bigger than the opening, and needs to be crushed to fit through it. I got the filter half way out, but then the glovebox was in the way. Only one thing to do then. Remove all these screws
Remove this panel by popping it free and wiggling it out towards the rear of the car. The fusebox lives here btw. This might even be an optional step, I'm not sure.
And then with some wiggling and jiggling from both ends of the glovebox, pop the clips free and remove it. Dont forget to unplug the glovebox light from the top, if fitted
This gives ample room to access the half-removed filter
Once removed, this is the front door to its house
The new filter goes in the same way the old one came out, with brute force. You kinda squish each end to fit it in and then it pops out to fill the cavity inside the box
The cover then pops back into place
The old filter wasn't too bad, based on service stickers, it looks like it was replaced a couple of years ago, but it did have a kind of earthy musty smell which I'm glad to get rid of
Refit the glovebox, and all the screws, and you're done.
So far I've been really enjoying the little Leaf. It's a funny little appliance. It can be fast, faster than people expect, but it also likes to be driven around sedately without a care in the world.
The Bose audio is great, nice and clear with some punch from the sub in the boot. Bluetooth works well, as do the steering wheel controls. The media interface is looking a bit dated these days, and I'd love an Android Auto option, but from Googling, it looks like hard work.
The heated steering wheel is LUSH. I've never had it before, thought it was a naff idea, but it's already won me over. Heated seats, not so much. They're VERY good and get real toasty, but I can't get over the feeling you just wet yourself and you are sitting in a "warm" seat. I'll keep trying it, as it's more efficient than running the heater over winter.
Speaking of, I tried the climate timer out before work this morning. Set to 21c, which might be a bit low (it was on 24c but I thought I knew better), but it's quite nice getting into a car that's not cold inside. I didn't need to run the heater this morning because the interior was already up to temp, and the glass didn't fog up as bad. This is another thing I'll play with and see what my best options are.
I bought a Type 2 to Type 1 adaptor so I could take advantage of being able to charge my car at work. Seems to work well, nothing like having a full tank of juice at the end of the day. Our chargers are only Type 2, hence the need to adapt it to the Type 1 Leaf. The adaptor I bought was Projecta branded, and the build quality of it is impressive. It's solid, made of nice sturdy plastics, and works with no fuss. I feel like the cheaper ones, with no branding, probably don't feel as good as this one.
Other than that, I want to change the reduction gear oil shortly, so I'll need to grab some Redline D6 ATF for that, and then I'll just keep zipping around, being a pest and using all my instant torque to win traffic light drags whenever possible.
  • Like 8
The strut tops seem to be a nissan thing ! My missus Note is the same to the point it got pinged for a wof and I had to remove said very rusty nuts and fix it many choice words were said to get them off.
Yeah it seems like a real dumb design, the cowling is almost designed to funnel water right over top of the mounts and then there are no drain holes or anything to let it out. Wouldnt be surprised if a few models around that time had the same issue.
I had heard rumours that WOF inspectors had been instructed to check the strut tops. Will be interesting to see if they remove the covers to check them or not.
After replacing them I slathered them in anti seize and grease to hope to last longer my mechanic said super common issue and is a nightmare as I discovered to do without running the shocks
Thankfully my worst one, pictured above, looks fine after I hit it with the wire brush on the drill. Its a bit pitted and the nut would be fun to remove, but they'd be dicks to say its compromised. I hate to have to damage the Nismo shock to remove it, if it was that bad. Id probably just chop the mount into bits until i can cut the nut off.
You guys should be glad that's the worst of the rust you'll most likely have to deal with on a modern-ish car :badgrin: Here's the underside of my ~10 year old VW
Those lower control arm inner eccentric bolts were seized solid into the bushing sleeve, and the head of the lower shock mounting bolt snapped clean off after applying a lot of force to get it undone. I ended up opting to replace the whole knuckle assembly as it was easier than pissing around with extracting the remainder of the bolt. I'm in the process of wire-wheeling the subframe and coating with rust-kill paint. I've just replaced the upper and lower control arms complete as they are like $30 each from rockauto and not worth the hassle to press out/in new bushes and saves me having to clean them up too. All this after I just wanted to do a wheel alignment. I fucking hate road salt.
  • Confused 1
  • Sad 2
Yeah nah, you guys that have to deal with salted roads can keep that shit, ain't want any of that :lol: Its no wonder modern cars are disposable over there
My 50-year-old Marina looks better than that, let alone any of my newer cars.
  • Haha 1
  • 3 months later...
1 hour ago, tomble said:
My leaf made me an absolute menace. If there's a gap in traffic, you know you'll make it. But not everybody else involved does...
So many traffic light drags, even if no one else knows it.
The shooting a gap thing is actually a bit of a concern when I jump into my ICE cars as I forget none of them can quite zip like the Leaf does.
3 hours ago, thegreatestben said:
Maybe one day we can have a drag race and see how a Leaf goes against the E208
Badly would be my guess :lol: Looks like you'd have a 20kw or so bump in power on a Leaf
Been on a motorbike lately?
