Sign in to follow this
bonkas
Oil Pressure Senders
What do you know about oil pressure sender units?
I am having issues with my brand new ones I just purchased, OEM parts, correct part numbers.
I am getting very erratic readings on my guage, just does what it wants. the workshop manual specifies the resistance I should expect at with engine not running and running - I am not getting that at all. The new sender is showing open circuit at 0 PSI but it should be showing somewhere around 250ohms.
I can post the part numbers when I get home if needed but I am 100% sure they are correct.
The guage appears fine as connecting to ground the guage reads 0 and unplugging the sender wire it maxes out.
As per my wanted thread here:
Share this post
Link to post
Are you using a factory guage and sender unit? Or are the sender unit and guage an aftermarket pair? Are you checking at idle? Mitsi's don't do much pressure warm at idle.
 Can't remember Lancers having a pressure guage but it has been a long time since I had one. I'll could probably remove and send you a Starion 4g63 one but the engine has been sitting for 15 years so who knows if it still works.
Share this post
Link to post
@Ranter I would be certainly keen on a starion one as they list the same part for the Lancer EX (4g32) and Starion (4g63).
This is the factory guage, just new engine.. stupidly gave away my old sender unit with old motor...
Share this post
Link to post
Single wire sender? Have you put sealant/tape on the sender thread?
Share this post
Link to post
Yep single wire, nope no sealant or tape, just screwed straight into the thread.
Share this post
Link to post
I have 3 out of box dud sensors it seems, all open circuit. I'm finding it hard to believe that 3 brand new sensors would be bad.
Does anyone have some sensors they can measure?
Share this post
Link to post
Internet reckons it is a pressure switch, is that what you are wanting or a pressure transducer?
Share this post
Link to post
Interesting.. It should be a sender unit for the gauge, not a switch.
This is the direct replacement part number from the vehicle manual... It's also listed as the direct replacement for a Starion which has a pressure gauge.
There is also a Tridon replacement TPS005.
Rockauto also has a listing for the guage sending units and switches on the starion, this is the sending unit (or so it seems): https://www.rockauto.com/en/moreinfo.php?pk=44239&cc=1208203&jsn=411
This also cross references the OEM part number.
Now I am confused if I have the correct part number or all these listings are wrong, or all my senders are DOA...
If anyone can hook me up with the correct part that would be appreciated.
Share this post
Link to post
I have e that stanpart ps192 sender on my Ute (matched to factory pressure gauge) works fine
Edit* I even tested it on the bench and it was a range between I think 30 and 90? (Whatever the mitsi gauge was) I think I mentioned it in my build thread
Share this post
Link to post
Now I remember. There was some issues with people ordering gauge senders and getting pressure switches. On the L200 forum. So may be the same issue with your supplier
Share this post
Link to post
Awesome thanks for the info @tortron I am getting no reading at all from mine, just open circuit when not under pressure.
I guess I will take the plunge on the rockauto sender unit.
I bought my original senders from two different suppliers and used the old and new part number - Still received the same part, I now have 3 units all with the same fault. Well not really a fault if they are switches rather then gauge senders.
Share this post
Link to post
Always thought oil pressure switches were normally closed so the light comes on when there's no pressure. The one on my generator certainly is.
Share this post
Link to post
Exactly what I would have thought also.
@tortron
New sender arrived from Rock Auto - Reads the same as all the other, open circuit....
Will see how it behaves when in the car.
  • Sad 1
Share this post
Link to post
