SiRge Posted May 3, 2018 Posted May 3, 2018 He's a mod on Classic Honda of Australia fb page pretty sure, been wanting to make a Classic Honda of NZ page, but the nz honda av/as/at/aa group is pretty good in the mean time. Quote
igor Posted May 3, 2018 Posted May 3, 2018 Any reason not to use 12" rims if you convert to old Civic hubs? Quote
~Slideways~ Posted May 3, 2018 Author Posted May 3, 2018 36 minutes ago, igor said: IAny reason not to use 12" rims if you convert to old Civic hubs? I found a guy who used old civic hubs which then worked with later model calipers, i think that is why the 13's were needed. 12" tyres must be hard to get tires for these days? Quote
igor Posted May 3, 2018 Posted May 3, 2018 Yes, 12" tyres are becoming hard to find and are almost always more expensive than 13". Quote
Seedy Al Posted May 3, 2018 Posted May 3, 2018 On 03/05/2018 at 10:47, ~Slideways~ said: Haven’t seen that one, do you have a link? Unfortunately not. Those pics were off a blog from 2010. Im sure something is around but can't confirm. There is a white one in japan also on 10s, flared with similar exhaust style. 1 Quote
SiRge Posted May 3, 2018 Posted May 3, 2018 Build 3 - copy the spoon N360. Use a BMW motorbike head http://www.speedhunters.com/2009/06/gallery_gt_gt_spoon_honda_n360_packaging/ Quote
~Slideways~ Posted May 3, 2018 Author Posted May 3, 2018 4 minutes ago, SiRge said: Build 4 - go autisitic Jeez... basically a engine with some semi N360 looking panels around it. Quote
~Slideways~ Posted May 3, 2018 Author Posted May 3, 2018 Does anyone know if a 1979-1983 Civic rotting away around Wellington? Quote
SiRge Posted May 3, 2018 Posted May 3, 2018 @Figgy Did you manage to flick your Civic? Or have any other sources? There's probably a couple floating around if you join that NZ Honda Civic AT/AS/ etc page Quote
~Slideways~ Posted May 4, 2018 Author Posted May 4, 2018 4 minutes ago, SiRge said: @Figgy Did you manage to flick your Civic? Or have any other sources? There's probably a couple floating around if you join that NZ Honda Civic AT/AS/ etc page I had sent a join request for the NZ Honda av/as/at/aa group about a week ago but never got a reply/acceptance thing. Guess they don't like my face or something. Joined a couple of other N360 groups and early Honda stuff but mostly overseas. Quote
~Slideways~ Posted May 4, 2018 Author Posted May 4, 2018 11 minutes ago, SiRge said: @Figgy Did you manage to flick your Civic? Or have any other sources? There's probably a couple floating around if you join that NZ Honda Civic AT/AS/ etc page Looks like his is a 1978, might not be the same hubs. Plus his looks too nice for parts. I need a rotten one to pillage parts to see if I can make the hubs and disk brakes work, found this blog thing saying they do: http://n600sedan.blogspot.co.nz/2014/03/brake-caliper-rotor-conversion-1972.html But driveshafts don't, so would need to work something out there. I wonder if accord or shuttle stuff would work? Quote
SiRge Posted May 4, 2018 Posted May 4, 2018 33 minutes ago, ~Slideways~ said: I had sent a join request for the NZ Honda av/as/at/aa group about a week ago but never got a reply/acceptance thing. Guess they don't like my face or something. Joined a couple of other N360 groups and early Honda stuff but mostly overseas. Done, check you fb Quote
~Slideways~ Posted May 4, 2018 Author Posted May 4, 2018 2 hours ago, SiRge said: Done, check you fb As if by magic haha Quote
igor Posted May 4, 2018 Posted May 4, 2018 3 hours ago, ~Slideways~ said: Does anyone know if a 1979-1983 Civic rotting away around Wellington? Yes I have a parts car but South Otago so a bit far away unless you get desperate. Quote
~Slideways~ Posted May 4, 2018 Author Posted May 4, 2018 40 minutes ago, igor said: Yes I have a parts car but South Otago so a bit far away unless you get desperate. Cool thanks, if I can't find one a bit closer I'll let you know. I'd be looking at hubs, discs, calipers, driveshafts and maybe wheels so probably a bit to send. Quote
Steelies Posted May 4, 2018 Posted May 4, 2018 super rad car. def stick with 12"! also, maybe something like this https://www.trademe.co.nz/motors/motorbikes/motorbikes/other/auction-1583269962.htm?rsqid=904a0f324b0549dc969da59403772c79 Quote
MaxPower Posted May 4, 2018 Posted May 4, 2018 mate with the 360 owns 'go motors' in paengaroa tepuke , hassle him to sell his cause he will let it rust into the ground. Quote
~Slideways~ Posted May 5, 2018 Author Posted May 5, 2018 16 hours ago, MaxPower said: mate with the 360 owns 'go motors' in paengaroa tepuke , hassle him to sell his cause he will let it rust into the ground. Cool, I called them but no answer or voicemail. Will try again though. Thanks Quote
~Slideways~ Posted May 5, 2018 Author Posted May 5, 2018 21 hours ago, Steelies said: super rad car. def stick with 12"! also, maybe something like this https://www.trademe.co.nz/motors/motorbikes/motorbikes/other/auction-1583269962.htm?rsqid=904a0f324b0549dc969da59403772c79 Two stroke! 1 Quote
