~Slideways~ 2,160 Posted February 21, 2019 Author Report Share Posted February 21, 2019 18 hours ago, ajg193 said: http://japan-parts.eu/toyota/jp/1995/starlet/ep85-agmsk/5_121140_041_/powertrain-chassis/4101_rear-axle-housing-differential#41110 2.277:1, might be a bit tall Might also be a bit wide of a housing too. Car total width is around 1600 mm so flange to flange would probably be around 1400 Supposedly same housing and all as KP starlets, just different ring gear / stud pattern / mounting I came across that same 2.2 ratio, wouldn't work too well for this I don't think but would be useful for something. EDIT: with 175/50/13's (so I can fit Civic brakes) and a 2.277:1 diff it would be geared for 276kph at 11,000rpm... lol. And about 4000rpm for 100kph 2.929:1 would be 216kph at 11000rpm And about 5100rpm for 100kph Quote Link to post Share on other sites
~Slideways~ 2,160 Posted February 21, 2019 Author Report Share Posted February 21, 2019 Browsing Yahoo auctions and came across this little slot car model, how cool does that look. 1 Quote Link to post Share on other sites
ajg193 8,934 Posted February 22, 2019 Report Share Posted February 22, 2019 If you do go with some sort of starlet based diff, 3.1 heads are also available: https://buyee.jp/item/yahoo/auction/x606284693 (just not very common) 1 Quote Link to post Share on other sites
~Slideways~ 2,160 Posted February 22, 2019 Author Report Share Posted February 22, 2019 1 hour ago, ajg193 said: If you do go with some sort of starlet based diff, 3.1 heads are also available: https://buyee.jp/item/yahoo/auction/x606284693 (just not very common) I'm a bit concerned with the smaller C/W and probably smaller axles. It is a light car but I don't want to have to worry about it all the time. T-Series should hopefully be a good compromise. And LSD's are easily available. The AE95 diff guy surfaced again so hopefully have some measurements this weekend. Quote Link to post Share on other sites
ajg193 8,934 Posted February 22, 2019 Report Share Posted February 22, 2019 They seem to cope fine with around 140 hp with lsd, but yeah they're a bit small. Lightweight though. Quote Link to post Share on other sites
~Slideways~ 2,160 Posted February 22, 2019 Author Report Share Posted February 22, 2019 29 minutes ago, ajg193 said: They seem to cope fine with around 140 hp with lsd, but yeah they're a bit small. Lightweight though. It's hard to know, being maybe 250kg lighter than a KP Starlet you'd think it would put less stress on it but on the other hand it's a 190hp/12,000 rpm engine (limited to 11,600 in 6th apparently). 178hp without airdam, but still. The ZX12R has about the same torque as a 4age, while people upgrade the KP diffs with 4age conversions. I had a 4agze in an AE86 years ago and the T-series held up fine (T50 not so much), no LSD though so single spinning inner wheel all the time, so less stress I guess. Quote Link to post Share on other sites
~Slideways~ 2,160 Posted February 23, 2019 Author Report Share Posted February 23, 2019 Dammit, the guy with the 4wd carib diff looks to actually be from the earlier 4wd Tercel which is an S series diff, the wrong ratio and no lsd option. Back to searching for an AE95 then. Quote Link to post Share on other sites
kyteler 59,520 Posted February 26, 2019 Report Share Posted February 26, 2019 Honda Motorcycles logo design from the 60s. 4 Quote Link to post Share on other sites
63Ragtop 32,544 Posted March 1, 2019 Report Share Posted March 1, 2019 Tool kit is cool. You mad bastard! Quote Link to post Share on other sites
~Slideways~ 2,160 Posted March 1, 2019 Author Report Share Posted March 1, 2019 1 hour ago, 63Ragtop said: Tool kit is cool. You mad bastard! Quote Link to post Share on other sites
MaxPower 1,157 Posted March 2, 2019 Report Share Posted March 2, 2019 is there a plan for the original motor? my friend has seized his and is looking for a cheap replacement Quote Link to post Share on other sites
~Slideways~ 2,160 Posted March 2, 2019 Author Report Share Posted March 2, 2019 16 hours ago, MaxPower said: is there a plan for the original motor? my friend has seized his and is looking for a cheap replacement Not sure yet, I was thinking of keeping it and keeping an eye out for another n360 to fix up because I have a problem. Got any photos of his one? 1 Quote Link to post Share on other sites
MaxPower 1,157 Posted March 12, 2019 Report Share Posted March 12, 2019 sorry no photos, its red. he's not keen to part with it at this stage, but I'm sure he will let me know first 1 Quote Link to post Share on other sites
~Slideways~ 2,160 Posted March 14, 2019 Author Report Share Posted March 14, 2019 myKool just pointed out that Zebra Onehunga just got an AE95 Carib with the axle/diff/propshaft I need. But I'm in Wellington. How do I get it? I'd pay someone to remove it but no idea who'd be able to. 1 Quote Link to post Share on other sites
kyteler 59,520 Posted March 14, 2019 Report Share Posted March 14, 2019 3 hours ago, ~Slideways~ said: myKool just pointed out that Zebra Onehunga just got an AE95 Carib with the axle/diff/propshaft I need. But I'm in Wellington. How do I get it? I'd pay someone to remove it but no idea who'd be able to. @sentra might be kind enough. He's definitely pretty enough. Quote Link to post Share on other sites
~Slideways~ 2,160 Posted March 14, 2019 Author Report Share Posted March 14, 2019 33 minutes ago, kyteler said: @sentra might be kind enough. He's definitely pretty enough. Haha that's cool but tortron has offered to go have a look already, which is awesome. 1 Quote Link to post Share on other sites
Adoom 2,313 Posted March 25, 2019 Report Share Posted March 25, 2019 Welds look good. You know the trick of putting a bit of copper behind the weld? It really helps with blow through and doesn't stick to the weld. I just use a bit of flattened copper pipe. Quote Link to post Share on other sites
~Slideways~ 2,160 Posted March 25, 2019 Author Report Share Posted March 25, 2019 36 minutes ago, Adoom said: Welds look good. You know the trick of putting a bit of copper behind the weld? It really helps with blow through and doesn't stick to the weld. I just use a bit of flattened copper pipe. That's a good idea, would have been good in that spot since I could get to the other side. Quote Link to post Share on other sites
SiRge 601 Posted May 17, 2019 Report Share Posted May 17, 2019 Caught up with all the progress. Good work bud 1 Quote Link to post Share on other sites
~Slideways~ 2,160 Posted May 17, 2019 Author Report Share Posted May 17, 2019 2 hours ago, SiRge said: Caught up with all the progress. Good work bud Thanks man. Quote Link to post Share on other sites
