Kimjon Posted December 31, 2020 Author Posted December 31, 2020 Okay, Longshot...but does anyone on here know what these 2 wires are for? Im at a bit of a loss? Maybe a clutch switch so you can't start it without clutch in? My clutch lever has no switch on it and it's a factory part off a harley. Maybe a model without this feature? Fucked if I know? Help???? Anyone???? Quote
tortron Posted December 31, 2020 Posted December 31, 2020 yes that goes on a clutch switch (which are identical to a brake lever switch just a mirror image) your lever mount may have a little nub and a threadded hole underneath it. but why would you want a clutch starter lock out, worse than a sidestand switch Quote
Kimjon Posted December 31, 2020 Author Posted December 31, 2020 6 minutes ago, tortron said: yes that goes on a clutch switch (which are identical to a brake lever switch just a mirror image) your lever mount may have a little nub and a threadded hole underneath it. but why would you want a clutch starter lock out, worse than a sidestand switch Excellent, thank you. I can't see anything on my clutch control lever. The brake one is obvious, but nothing here? I'll delete it. Quote
tortron Posted December 31, 2020 Posted December 31, 2020 some markets seem to have them (canada in my experiance with not harleys) so may be just a special lever for them and everyone else just has to not start it in gear Quote
thegreatestben Posted December 31, 2020 Posted December 31, 2020 Yeah I don’t remember having to clutch in on my nz new with that same switchgear. Had to be in neutral though. Quote
Kimjon Posted January 2, 2021 Author Posted January 2, 2021 Yip, thats how I was feeling as I figured out that a lot the wires are spliced and share common power/earths etc. But by testing the resistance (ohms) through each circuit using a multimeter, i got there in the end. Pretty common shit I guess...but for an electrically retarded person like myself, self teaching as I go along, its a lot of condensed learning to fit into my already closed mind. That said, I'm there now. Each wire labeled and each corresponding circuit tested and working via its switch. so I'm now ready to buy expensive tools to strip and crimp the wires and then try installing OEM style connectors, yet another thing I've never done...but will soon have to figure out quick smart If I want it to work. Quote
Kimjon Posted January 3, 2021 Author Posted January 3, 2021 Brought these today. They work amazing!! Only $20 from jaycar, super happy with them. Quote
xsinclairx Posted January 3, 2021 Posted January 3, 2021 Good quality stuff like that makes all the difference! Quote
Kimjon Posted January 4, 2021 Author Posted January 4, 2021 Mail arrived, so my list of excuses is fast running out! Strangely satisfying click sound and accompanying mechanical movements...hypnotic... Quote
Kimjon Posted January 4, 2021 Author Posted January 4, 2021 Okay, neither maths nor English are my strongest attributes. However there are 48 wires that need a connection block, required to make this wiring loom work. There's an additional half dozen that need an eye terminal for things like battery, coils, starter motor, horn etc. So when you buy a "complete kit" that has in excess of 50 wires and that kit only has enough connectors to do 22 wires, it leaves you scratching your head wondering if the difference between American English and the Queens English we use in NZ is really that far apart? FFS this kit has 50+ wires, but only 22 connectors!!! WTF. This is a carburetored engine, no ECU or injectors, sensors to consider, its as basic as it gets. A handful of their shitty connectors would have gone a long way towards finishing this today. So off to jaycar with my crippled arse I go again. Quote
Kimjon Posted January 5, 2021 Author Posted January 5, 2021 Ordered 2 of these kits. Should get it done. Works out much cheaper than paying $30 a fitting at jaycar or repco etc. Quote
Raizer Posted January 5, 2021 Posted January 5, 2021 I've used those plugs on a few scooters, they work well! Just don't over squish the crimps Quote
Kimjon Posted January 5, 2021 Author Posted January 5, 2021 18 minutes ago, Raizer said: I've used those plugs on a few scooters, they work well! Just don't over squish the crimps Awesome, good advice thanks. Its not like I'll take it out in the rain, so I could pretty much twist the wires together and wrap in tape and it'd be fine hahaha Quote
Lord Gruntfuttock Posted January 5, 2021 Posted January 5, 2021 You do have a fuse block yeah...? Quote
rusty360 Posted January 5, 2021 Posted January 5, 2021 1 hour ago, Kimjon said: Ordered 2 of these kits. Should get it done. Works out much cheaper than paying $30 a fitting at jaycar or repco etc. These will seal 100 times better to. Prob smaller footprint to. Quote
vk327 Posted January 5, 2021 Posted January 5, 2021 your gonna need one of the MSEL style crimp tools for those, the jaycar ones dont crimp the wire enough and over crimp the seal, results in wire falls out and seal breaks off Quote
Kimjon Posted January 5, 2021 Author Posted January 5, 2021 4 hours ago, Lord Gruntfuttock said: You do have a fuse block yeah...? Not yet. I'm unsure if my relay box has built in fuses, information is sketchy at best. The wiring diagram doesn't show any additional fuses. I was going to put some in to cover the main parts. More reading I guess on Google?? Quote
Lord Gruntfuttock Posted January 5, 2021 Posted January 5, 2021 Yeah make sure you have some sort of fuse/breaker protection. Don't know if you are running a battery or not but there's a lot of potential for fire there without something to break a fault circuit. Happy to look over your diagram if you can post it up? Won't be till next week though as still on holiday and will have no reception soon... Quote
rusty360 Posted January 5, 2021 Posted January 5, 2021 14 hours ago, Kimjon said: Ordered 2 of these kits. Should get it done. Works out much cheaper than paying $30 a fitting at jaycar or repco etc. From ali? Rs components do a massive range of plugs and sockets if ya don't wana wait, they ship overnight from oz Quote
Kimjon Posted January 6, 2021 Author Posted January 6, 2021 5 hours ago, rusty360 said: From ali? Rs components do a massive range of plugs and sockets if ya don't wana wait, they ship overnight from oz These were on trademe, nz stock, so should have by Friday? Same price as Aliexpress but $10 freight, so about $60 for 2x sets including freight. Repco and jaycar were like $30-$70 per fitting and I need 7 plugs, which adds up stupid fast!! I found a few other shops selling them for around $30, but nothing really cheap. The kits I brought were $25 per kit, and include about 20 random fittings per kit. Considering I'm not working to NASA tolerances, I think these cheap plugs will be fine. I'll just try them and see. Quote
