12a missing under load
Mk1Daniel
Hey guys have a 12abp starlet I want to get rid of.
I'm having an issue where if I rev it up is misses and when it's driving I can't go full throttle until exactly 4000rpm or more otherwise it misses and pops.
It's got a nikki 4 barrel with mechanical secondaries. I think it's a facet fuel pump. I have no fuel pressure reg so I'm thinking it's got too much fuel pressure. Compressions at 95psi.
Any ideas Rotary guys or generally clever cunts? :)
As it is mech secondaries you prob need to mod the accel pump to get a bigger squirt as they open so much faster than vac sec its common to get a lean stumble.
I've seen various combinations of; grinding the stops down, mod the linkage for a longer stroke, make a spacer between pump and carb body to increase the volume it can hold, drill out the passages in the ali two pronged squirter bit (cant remember correct name atm, will look it up), drill out the jet
Have a look around rx7club.com
May pay to check its operating at least to factory spec first;
https://free-info-pages.com/rx7-carburetor-accelerating-issues.htm
