kiwi808 Posted April 9, 2016 Share Posted April 9, 2016 Then build me one. Thanx. 1 Quote Link to comment Share on other sites More sharing options...
Ghostchips Posted July 8, 2016 Author Share Posted July 8, 2016 Ok i need a second opinion. Didn't realize how bad the sloping hinge line looked until i started making this. Should i make this hinge level or just go with the unskilled dirtcar racer look sloping hinge? At the low rate of investment i'm leaning toward unskilled sloped hinge but it'll always look redneck. Why a hood? So i can put it on if it rains or want to hide the fact it's a 4 (as if the sound wasn't a give away) 2 Quote Link to comment Share on other sites More sharing options...
SOHC Posted July 8, 2016 Share Posted July 8, 2016 Would it be hard to change and trim it level? Quote Link to comment Share on other sites More sharing options...
kiwi808 Posted July 8, 2016 Share Posted July 8, 2016 Having a non sloping hinge would actually work better? I would be tempted to do what SOHC suggested and trim and correct it. However I have no idea how much extra work that would require. Are you going to have louvred sides? Quote Link to comment Share on other sites More sharing options...
tortron Posted July 8, 2016 Share Posted July 8, 2016 just put spacers on the rear of the lid to pack it out and defrost your windscreen. THen no one wil notice 2 Quote Link to comment Share on other sites More sharing options...
Ghostchips Posted July 8, 2016 Author Share Posted July 8, 2016 Would it be hard to change and trim it level? Without more materials it would. Can change it easily enough. Having a non sloping hinge would actually work better? I would be tempted to do what SOHC suggested and trim and correct it. However I have no idea how much extra work that would require. Are you going to have louvred sides? It would look better. and i can have removable louvered sides. 1 Quote Link to comment Share on other sites More sharing options...
SOHC Posted July 8, 2016 Share Posted July 8, 2016 How meany more fridges and washing mechains do you need for the parts ? 1 Quote Link to comment Share on other sites More sharing options...
Ghostchips Posted July 8, 2016 Author Share Posted July 8, 2016 How meany more fridges and washing mechains do you need for the parts ? One. Quote Link to comment Share on other sites More sharing options...
kiwi808 Posted July 8, 2016 Share Posted July 8, 2016 How easy is it to make the louvres? Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted July 8, 2016 Share Posted July 8, 2016 YouTube. Easy to do badly but hard to do perfect without correct tooling 1 Quote Link to comment Share on other sites More sharing options...
SOHC Posted July 9, 2016 Share Posted July 9, 2016 I know someone who has a home made lover punch 2 Quote Link to comment Share on other sites More sharing options...
bathcollector Posted July 9, 2016 Share Posted July 9, 2016 Straighten it up Rusti. Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted July 9, 2016 Share Posted July 9, 2016 Find old appliances with louvred bits and use those panels plz. The backs of older ovens and driers is probably a good place to start 2 Quote Link to comment Share on other sites More sharing options...
kiwi808 Posted July 9, 2016 Share Posted July 9, 2016 Find old appliances with louvred bits and use those panels plz. The backs of older ovens and driers is probably a good place to start I like this idea. 1 Quote Link to comment Share on other sites More sharing options...
SOHC Posted July 9, 2016 Share Posted July 9, 2016 A friend of mine has a model a with those air vents witch screw onto the bottom of a door on it, it looks heinous 1 Quote Link to comment Share on other sites More sharing options...
doullama Posted February 18, 2017 Share Posted February 18, 2017 Man this is cool! my old bucket (didn't build it) the builder managed to find a chassis complete with live plates and a declaration for supercharged 350 etc, just built it to the sheet. Had rose joints etc which i'm pretty sure wouldn't fly with lvv. Also being regd as a 23' meant seatbelts, indicators etc were frivolous extras. Didn't have fender exemption but rolled fenderless most of the time, never got stopped, many friendly waves however haha Quote Link to comment Share on other sites More sharing options...
igor Posted September 8, 2017 Share Posted September 8, 2017 Good to see this thing again @rustisize. I have a Holley carb and a manifold somewhere that might be off one of these. Not in real good condition though as I found it out in the paddock. Quote Link to comment Share on other sites More sharing options...
SOHC Posted September 8, 2017 Share Posted September 8, 2017 f the winding haven't failed probabley the condenser has broken down, you might be able to wire one up on the outside of the box? Quote Link to comment Share on other sites More sharing options...
Ghostchips Posted September 8, 2017 Author Share Posted September 8, 2017 2 hours ago, igor said: Good to see this thing again @rustisize. I have a Holley carb and a manifold somewhere that might be off one of these. Not in real good condition though as I found it out in the paddock. Probably better than the one on this one. Drinks a bit of gas. 32 minutes ago, SOHC said: f the winding haven't failed probabley the condenser has broken down, you might be able to wire one up on the outside of the box? Replacing the internal condenser is the easy part. There is probably a way of putting a modern tiny 'on plug' or bike coil inside with a MOSFET set to give it a frequency buzz when active but nothing i'd make would be that hardy. Quote Link to comment Share on other sites More sharing options...
SOHC Posted September 9, 2017 Share Posted September 9, 2017 you could still use the old points on top of the coil and a condenser and small motorcycle coil inside I reckon Quote Link to comment Share on other sites More sharing options...
