Ghostchips last won the day on January 1 2020
Ghostchips had the most liked content!
Gender
Not Telling
Interests
Cars & stuff, like motorbikes, things with engines.
Local Area
Northland
Ghostchips's Achievements
Committed (5/5)
5.1k
If you're close by, go anyway & see who shows up.
I'm pretty sure he died by now. Rule of thumb, if someone goes missing for 6 months, they're not coming back.
Ghostchips 1920-26 ford T bucket (of rust)
Ghostchips replied to Ghostchips's topic in Projects and Build Ups
More video, but of playing around with an exhaust sensor. I still remember her voice after all these years & half expect her to tell me the time soon after the temp'. -
Ghostchips replied to Roman's topic in Tech Talk
There are 6 and 12 volt bulbs listed as 'for scooter' on aliexpress. The ones that have 1 side for dip & both sides for high beam seem reasonable. https://www.aliexpress.com/item/32719482964.html Or.... https://www.aliexpress.com/item/32995409361.html Might be able to get one sooner from the likes of trademe. I looked but only found stop-tail LED. A winter or 2 back i put stop-tail LED bulbs into the headlight buckets of the model T. Worked remarkably well. -
If JB weld or something will hold the dirt out, do it. I once replaced the top of a model A distributor with a popsical stick with wires shoved through little holes. Based that one on stories on the internet. There was a video of someone doing it somewhere but i can't find it now /Ling -
I spent more money than i should have to acquire some plastic plugs. They were far more attractive than the copper & plastic, and less bulky. And they make this really satisfying noise when being unplugged, like stirring macaroni cheese or something. Found i could buy them for 1/4 the price direct from china. Or i could buy them for 400 times the china price at B.n.T. i recall seeing them in a workshop a long time ago and i wasn't even allowed to look at them because they were 'too good for my eyes' or something. I have since figured out the people at that workshop are dicks & need to be corporeally punished. So up yours NZ, i am good enough to see plugs. And if you don't like it, fuck you. https://youtu.be/u3GwSzpvNq0 A terrible video- 69 replies
Rusti'z 1920-26 Ford T bucket (of rust) Discussion
Ghostchips replied to Ghostchips's topic in Project Discussion
OK, i tried to replace as many pictures as i could, sorry about them being mostly massive though. Wow that's an old photo. It made a friend half it's size. -
Most of the old pictures died but i'll see what i can do to replace them. So i learned you can use a pocket knife to carve totara & chewing gum to make a makeshift oil plug, or a frost plug. Just some pictures of some travels.- 69 replies
- 20
Umm... People say strange things? https://youtu.be/VXRBjEnpMwY https://youtu.be/-MEn4SMv-4s -
What if you use the t57 rods & 2 bearings in the same rod to make up width like people do when putting replaceable shells in babbitt fords? I think the trick with the model T was to use 2 MG bearings side by side in the big end.
Journals maybe 33mm long. Bigend maybe 35mm or so, might be able to bore bigger before hitting the rod bolts but don't count on it. Wrist pin 18.5mm-19mm. About 7 inches long.
How hard would it be to re-form a rod to fit? I have a few T conrods i'll likely never use.
Try GOM player, it might be able to find a codec that'll work. Edit: haven't used it in years but the newer version suck, apparently a new team took over & it might install malware now.
