Thanks for the link, not bad prices with shipping either, I have the 2 pressure senders so keen to keep all my gauges working.
Pretty sure they are both interchangeable, there were 2 different gaskets in the kit I brought, one with a circular oil feed and the other oval, checking the gaskets on the block and fitting doesn't look like there would be too much hassle, on closer look using an oval gasket on the circular hole may allow oil to bypass the filter?
  • Replies 119
Loving the tunnel vid, just wondering if there is anything fancy with your exhaust system, sounds pretty civilised?
Are you willing to part with any engine bits? I've gone and busted my oil filter casting, if I can't fix it i'll be looking for another.
you just want a regular oil filter housing with the filter pointing straight down next to the sump? I should have one kicking around
Tried a little persuasion by smacking the screwdriver with a hammer? Don't belt the shit out of it, but while applying a twisting torque with one hand to the screwdriver give the screwdriver a bit of a whack. I've had great success freeing things that way in the past. Applies a force in a different direction which can help to loosen it a bit. Worth a try at least perhaps
maybe some of that freeze spray in a can stuff applied directly on just the head of the screw/jet? hot/cold cycle freeze spray and heat from a heat gun of map torch or something?
Great ideas, thanks guys, will have another go at them tomorrow. I had a tweak of the accelerator pump adjustment this evening which made more improvement on the lag between gears, really need to balance them better though.  Excited to get her tuned  :-)
I live down the end of the same street as you (Wainui Street right?) and have an impact wrench that might be helpful, flick me a PM if you want to borrow it man, would be keen for a yarn too
Haha, classic, seen me blasting up and down the road each evening eh? maybe have a yarn this weekend, two heads seem to solve problems alot quicker!
I wish it was so simple, its a small brass screw in a recess about 5mm back, dirty little bugger! maybe solder? going to pick up a can of freeze spray this weekend, give that a go along with a gentle tap
Had a go freeing the other 3 screws, got one with a light tap and broke another  :cry:  at least I now have one on each carb, I now will hope I can balance each carb, if not I'm going to have to outsource this one, find someone to drill it I guess.
Only bonus I guess is it now runs like crap indicating a good balance should see her further on the path  :)
you cant remove the rubber donut? (its called a 'guibo', lol)
you need to clamp it as it expands a bit and locks the bolts so they wont come out - dont forget to lift the vehicle in such a way so the driven wheels are off the ground so you can rotate the drive shaft and remove the bolts :rolleyes:
I have a chain clamp for oil filters thats also great for that job, ahh thusly:
http://www.supercheapauto.co.nz/online-store/products/Plier-Locking-Chain.aspx?pid=168027#Recommendations
Haha, Guibo, I've called it many colourful things but never something so comical.
Thats tool is brilliant! in the past i've used a couple of hose clamps joined together but that was a pain, what i've found is that if I only release one side, ie 3 bolts, its possible to tweak the tips of each bolt back into the donut then evenly drive them home, this is why I took off the TC, I could easly rotate the donut to tap the bolts back in, if that makes any sense!
As the nut is on a shaft that is near flush with the donut, it also made little difference to remove it from that side.
Lifting all the wheels is a pain on a 4wd, I've found I can roll it back and forward enough while underneath to get the driveshaft bolts out, the bonus of ground clearance!
Drove past supercheap this morning and thought stuff it, lets try Azzurro's guibo tamer, for 20 bucks its the best thing ever for getting her free! gentle squeeze to get the right spot and the bolts glide out, thanks for that! Also found a 32mm long socket on the shelf, bugger it! I'm starting to like supercheap more than repco, they seem to be holding more stock of useful tools while repco seem to be moving away from stocking any tools at all.
Ho wow that's exactly like the Suzuki ones, except I have the odd tiny cutting disc/gas axe marks on the axle from doing them so many times.
p.s I also do the same to the bearing
I'm way too paranoid about fatigue/stress raisers on axles I treat them like a bottle of single malt, always good to hear i'm stressing over nothing!
Say you do the same with the bearing, meaning you heat them as well?
No no I mean cutting them off
The step behind the axle is the same size as the inner race, so cant get anything under it (shot outer to pieces all over the workshop once pressing on it)
Cut collar like you did and whack with chisel
Cut outer race
cut cage
cut inner race and whack with chisel
off ye go
Bearing is fucked anyways
I do at least one rear in less than a year
Fronts less than half that
Also... HATE having to take the backing plate off/bleed brakes every time
They never bleed right
That makes more sense!
Yeah i've been lucky up to now, the bearings have come off with little effort, bashing in the vice is the most effort i've had to go through, seems the clearance isn't too tight.
This was the worst I've had, while cleaning out the housing I found heaps of shrapnel, after cleaning it all up wondering if it was diff bits it turned out to be the bearing cage, I somehow seem to catch them just before they totally let go!
Must be about time to re-pack the fronts, it's been a few years!
