oftensideways 478 Posted March 2, 2020 Report Share Posted March 2, 2020 looking awesome mate! I feel your pain on the welder, I have the same.. 1 Quote Link to post Share on other sites
Roman 13,463 Posted March 10, 2020 Report Share Posted March 10, 2020 @kpr It's amazing to see how much can be gained with some NA style tuning adjustments. Wonder if that dual entry design caused heaps of turbulence perhaps. Or maybe tipped trumpets are just that little bit better maybe. Or a little bit of both. Looking forward to seeing what happens at 13psi! 1 Quote Link to post Share on other sites
kpr 6,330 Posted March 10, 2020 Report Share Posted March 10, 2020 Yup highlights pretty well whats left on the table, with the usual short runner intakes that are used on most turbo stuff. Is a bit more complex making it all work nicely though. Not even possible in some cases I'm kinda sold on the idea, that the the bellmouths were too close to the roof of the plenum, on the dual setup. The dual setup had bigger slots into the main plenum, area wise than the original stainless single throttle dual setup. but made less power. It really started to brick wall around the 200kw mark, more boost didn't add power as it should. Hence why i done all this testing at lower power level. The starlet also hated it soon as the plenum roof was stuck in place, even with taper tubes removed and a big open hole in the side. speaking of starlet,, will try the new intake on it when its on the dyno next, see how it performs compared to the open trumpets Also i'm sure a lot of people will be disgusted at how big the runners and plenum are on this thing. 2 Quote Link to post Share on other sites
Roman 13,463 Posted March 10, 2020 Report Share Posted March 10, 2020 Interesting, got an estimate on runner to wall clearance on previous one? Quote Link to post Share on other sites
kpr 6,330 Posted March 10, 2020 Report Share Posted March 10, 2020 From memory around 40mm to the roof, from the face of bellmouth. There was quite a bit of room from the edge of bellmouth to the plenum wall . New one air can basically go straight down the runner rather than all the air having to come over the edge of the bellmouth Quote Link to post Share on other sites
kpr 6,330 Posted March 14, 2020 Report Share Posted March 14, 2020 Any suggestions where to get a decent tube and fin intercooler or just a core? Quote Link to post Share on other sites
Dudley 203 Posted March 14, 2020 Report Share Posted March 14, 2020 Need me to install a electric fan to help you get some gains bro? Quote Link to post Share on other sites
kpr 6,330 Posted March 14, 2020 Report Share Posted March 14, 2020 Them gains when the blades disintegrate Quote Link to post Share on other sites
Dudley 203 Posted March 14, 2020 Report Share Posted March 14, 2020 Yea that’s like when the 2ndreez kick in on ya 12a j port bongo bro Quote Link to post Share on other sites
M.H. 5,735 Posted April 1, 2020 Report Share Posted April 1, 2020 Thats dumb about the bearings, time to go for a dry sump? How does the different wastegate effect the sound? I thought they were just a valve? Quote Link to post Share on other sites
kpr 6,330 Posted April 1, 2020 Report Share Posted April 1, 2020 More i think about it. probably should pull engines down for an inspection every now and then. thats 8 years of near 9000rpm at double factory power, shits probably gonna wear out quicker. not like its had the easy life Just a valve yeah. but different shape valve. turbosmart is a flat valve, Tial is a curved valve. other than that dunno, some kinda wizardry i guess. 1 Quote Link to post Share on other sites
Dudley 203 Posted April 4, 2020 Report Share Posted April 4, 2020 Who would have thought all the cars at your house and Ol gc is the reliable one ha Quote Link to post Share on other sites
kpr 6,330 Posted April 4, 2020 Report Share Posted April 4, 2020 gummon, as i recall the GC lasted 1 day. That BMW though, German engineering at its finest Quote Link to post Share on other sites
Dudley 203 Posted April 4, 2020 Report Share Posted April 4, 2020 1 day pffffffffffffft gummmmmmon Quote Link to post Share on other sites
Yowzer 33,341 Posted April 15, 2020 Report Share Posted April 15, 2020 Sweeet! You're gonna need less rebound on the rear, or re-engineer your ramp so the springs decompress before launching to stop the rear kicking it into rotation 1 Quote Link to post Share on other sites
kpr 6,330 Posted April 15, 2020 Report Share Posted April 15, 2020 More rebound dampening i assume you mean, so the rear drops out slower. I think it is a touch fast yeah. from memory last time i slowed it down, was too much and it sucked. will have to look and see what shims i got in there Quote Link to post Share on other sites
Dudley 203 Posted April 15, 2020 Report Share Posted April 15, 2020 Strap gc to the back and then jump over the bmw? 1 Quote Link to post Share on other sites
Roman 13,463 Posted April 15, 2020 Report Share Posted April 15, 2020 Since you've got a whole heap of wheel and tyre, do you think that while you're in the air, gunning it or backing off the throttle might change your angle a little bit? Like on motorbikes dont they hit the brakes if they want to tip forward more. Although not sure if that only works because its only on back tyre of a bike. In any case, Jumps. Fuck yes. Quote Link to post Share on other sites
Yowzer 33,341 Posted April 15, 2020 Report Share Posted April 15, 2020 6 hours ago, kpr said: More rebound dampening i assume you mean, so the rear drops out slower. Same same You're launching under suspension compression, but once the front ejects off the ramp the rear wants to do the same due to weight transfer (coz front is now weightless) but if more rebound dampening sucks, build a ramp where the suspension can relax before launch so it doesn't kick you out. I dunno if there's a way to solve it suspension-wise, but I love your work so I am keen to see it! 2 Quote Link to post Share on other sites
sheepers 20,297 Posted April 15, 2020 Report Share Posted April 15, 2020 Put a massive wing on the back of it. Test multiple wings and find one that produces downforce. 1 2 1 Quote Link to post Share on other sites
