JR Posted May 30, 2014 Posted May 30, 2014 Hey guys. Some of you will have already seen this wee project in the Cycle car federation thread, I thought I should start its own build log as I was spamming the other thread with my dumb questions. Please feel free to chime in and let me know if you think there is a better way that I could be doing something, any help is much appreciated. So, getting to the interesting stuff.... I want to build a mini version of this Austin Seven Special for my son. Here is what I have done so far. 5 Quote
JR Posted May 30, 2014 Author Posted May 30, 2014 I messed up the Jackshaft, the RPM is not going to be enough for the centrifugal clutch to lock. I think I have a solution, I will elaborate another time.... Its late and its a long story. 4 Quote
JR Posted May 30, 2014 Author Posted May 30, 2014 The plan for the body is to make it out of plywood and fibreglass.... a little something like this: 2 Quote
artyone Posted May 30, 2014 Posted May 30, 2014 http://www.trademe.co.nz/business-farming-industry/industrial/engines-motors/electric/auction-734979581.htm I still feel that it's a good idea and like most things just take it as a way to learn more... I'll shut up now. Quote
JR Posted May 30, 2014 Author Posted May 30, 2014 For everyone wondering why artyone is suggesting electric power, the reason is this. While the wee fella is young I want it to be simple to drive (a go and stop pedal). I can't get a centrifugal clutch with a low enough engagement rpm for my jackshaft to work. A few of ideas were floated, bare in mind he is only 2 so needs to be easy to drive.1) Make it electric while he is young and use the engine as a generator.2) Hook the clutch up to the brake pedal. Bro-tamatic spec.3) hook the clutch up to the accelerator. As you give it gas the clutch releases.At the moment I'm kind of leaning towards option number three just because I'm cheap and it won't cost any extra, should be drivable and because burn gas!Thoughts? Quote
Shakotom Posted May 30, 2014 Posted May 30, 2014 Option number 3 so you can teach little one to do standstills when you put brakes on the front wheels 1 Quote
BlownCorona Posted May 31, 2014 Posted May 31, 2014 Yeah option 3 is my pick too, it would be very easy to set up as well, just install a couple cable adjusters and spend an hour or so fine tuning. I really need to start my build thread, picked up 4x tires today Quote
artyone Posted May 31, 2014 Posted May 31, 2014 Excuse my logic but I can't see number three being as simple in the reality of making it. Not that it isn't possible in some way but I just can't see it. The clutch plates are held in and together by springs (clutch out) so to balance it in the out or apart (clutch in) position a stronger spring will be needed to hold that position. Then the action of pushing the pedal in... to get clutch out means either greater tension or compression of the spring depending on whether push or pull is used... okay, levers can fix that but longer levers mean greater travel. Imagine the handle bar clutch lever held in then tensioned there with a spring from some fixed point and now add a length of tubing to the lever then get the two year old in a chair and find the point where he can push the tube with his foot enough that the clutch will be out. Am I wrong? What I can see is a two year old having to push a lever about 200mm... an 800mm lever. I want to be wrong actually... it'd solve some engineering conundrums I've had for years. Quote
governorsam Posted May 31, 2014 Posted May 31, 2014 Use an electric scooter as a donor. Cheap as with battery's faffed. Weld a sprocket to the rear wheel of the scooter wheel then mount it like a jack shaft. Will give you brakes as well. Quote
BlownCorona Posted June 1, 2014 Posted June 1, 2014 Artyone - the clutch for a cb125 is not at all going to be hard. Not like a big bike. The gas pedal lever can have the pivot point mounted higher than the chassis rail to provide a mechanical advantage and make overcoming the spring tension quite easier. As well as while the kid is only 4ft tall, a second gas pedal may need to be added for him to reach, and the linkage for this could also be set up to provide yet more mechanical advantage Quote
JR Posted June 1, 2014 Author Posted June 1, 2014 I should be able to rig it to have as little pedal resistance as I want. Fliboi is right, the force required to move the clutch is surprisingly little. If I have a spring here that is only just strong enough to hold the clutch in and a weak return spring on the pedal it should work. I still haven't decided what route to take yet. The scooter idea is a good one, I'll look into it. Quote
flyingbrick Posted June 1, 2014 Posted June 1, 2014 How did you get those mount plates to hug the engine so closely? Or is that an illusion Quote
BlownCorona Posted June 1, 2014 Posted June 1, 2014 files? and yeah i think you can sort it out JR, we can sus out a time to meet up some time next week and talk ideas/show me how to do half the bits for my build haha, but id love so see a home made automatic setup. would be so cool 1 Quote
artyone Posted June 1, 2014 Posted June 1, 2014 Okay... then I'm for option three too! It's quite neato really because if anything happens the foot will come off and the accelerator will spring back disengaging the clutch and it'll go into coast... and if it works really well you could almost put on an opposite brake too. Pedal out brake on. Reminds me of when I tried to design a shifter to fit on an old holden three speed that would work like a motorcycle gear change... and am now kinda mulling over for the Suzuki carry sports thingy. Quote
artyone Posted June 1, 2014 Posted June 1, 2014 Oh, flying brick... have you not seen the contour gauges? It's a band with loads of wires mounted perpendicular to the band and as you push it into a shape all the wires fit to whatever you push it into. More commonly known as a profile gauge...or it's just cardboard and scissors when one forgets one has a contour gauge, for me anyways. 1 Quote
JR Posted June 1, 2014 Author Posted June 1, 2014 How did you get those mount plates to hug the engine so closely? Or is that an illusion Was a bit of cardboard for the template and way too much time with a grinder. 1 Quote
flyingbrick Posted June 1, 2014 Posted June 1, 2014 Haha. For me that's the most impressive part so far 1 Quote
governorsam Posted June 1, 2014 Posted June 1, 2014 Have seen a motorcycle front master Cylinder used as a foot brake. Works quite well. 1 Quote
CUL8R Posted June 1, 2014 Posted June 1, 2014 Quite a cool wee project indeed, keep up the good work! Quote
DB8-TypeR Posted June 5, 2014 Posted June 5, 2014 Have you seen the automatic clutches as used in Moto X bikes? A couple guys at work do trail rides and have seen some guys with these clutches that disengage when the RPM is below whatever so when they are stuck in a mud bog the bike doesnt stall. Quote
