thegreatestben Posted April 1, 2014 Author Share Posted April 1, 2014 Yeah will do, is a bit tricky doing this on my own also. Need pair of helping hands with decent brain attached. Quote Link to comment Share on other sites More sharing options...
downtrail Posted April 1, 2014 Share Posted April 1, 2014 Lol turn ign on then use a screw driver to short main cable on starter to the exciter to get it cranking or wire a switch to some aligator clips to make easier just unplug injectors tho this is how i do it when setting timing for the first time Quote Link to comment Share on other sites More sharing options...
thegreatestben Posted April 1, 2014 Author Share Posted April 1, 2014 Not a bad idea, though I would probably opt for a slightly more legit version. Should probably make some friends/nah. Quote Link to comment Share on other sites More sharing options...
downtrail Posted April 1, 2014 Share Posted April 1, 2014 Yeah a push button with alligator clips works sweet can stand with timing light and crank comfotably Quote Link to comment Share on other sites More sharing options...
johnnyfive Posted April 1, 2014 Share Posted April 1, 2014 Haven't really read thread thoroughly or thought but, t-belt out a few teeth? Quote Link to comment Share on other sites More sharing options...
thegreatestben Posted April 1, 2014 Author Share Posted April 1, 2014 Checked that, all lines up ace. Has had a genuine belt installed about 10 - 15,000kms before it was pulled from car. Quote Link to comment Share on other sites More sharing options...
thegreatestben Posted April 1, 2014 Author Share Posted April 1, 2014 Simon from link: On that ECU there is no offset adjustment. It is geared to work off a 4 tooth trigger only. I suspect that the pickup in the distributor might be a 24 tooth wheel? Hmmmmm maybe they modified the dizzy on the old engine? Grind off some teeth? Quote Link to comment Share on other sites More sharing options...
vivaspeed Posted April 1, 2014 Share Posted April 1, 2014 I'll sell you a G1 V4 with a 20V programme already in it... Quote Link to comment Share on other sites More sharing options...
downtrail Posted April 2, 2014 Share Posted April 2, 2014 Simon from link: On that ECU there is no offset adjustment. It is geared to work off a 4 tooth trigger only. I suspect that the pickup in the distributor might be a 24 tooth wheel? Hmmmmm maybe they modified the dizzy on the old engine? Grind off some teeth? can ya grab the old dizzy of the dude? so what are they using to sync the rpm input? a 4-1 tooth config or the 2nd trigger input as a reset on a separate wheel with a single tooth? to be honest ive never looked at a 4age dizzy before but i suspect it'll be something like that, Quote Link to comment Share on other sites More sharing options...
thegreatestben Posted April 2, 2014 Author Share Posted April 2, 2014 There's two pick ups in the dizzy, I'm gonna have a go at removing some teeth. Dizzy's are easy enough to come across. Just need to make sure I leave the right ones in the right place. Geoff's gonna give me a burn on that V4 too. Quote Link to comment Share on other sites More sharing options...
Goat Posted April 2, 2014 Share Posted April 2, 2014 Does it go pop at all with some ether? Are the injectors even firing? Had this problem recently with a link. See if it makes a bang with some ether. If it does, then its fuel. If it doesnt. Then it will be ignition and still could be fuel. Try that? Quote Link to comment Share on other sites More sharing options...
thegreatestben Posted April 2, 2014 Author Share Posted April 2, 2014 Definitely got fuel, I can hear the pump running for 2 secs on ignition, it runs when testing with the hand control. You can smell it when cranking and the plugs are wet when I pull them out. I contacted the previous owner, he's got the old engine :) Gonna go have a squiz at the dizzy. If I get the base timing right and it still won't start I'll try ether. Then I'll probably get Geoffs link or got back to stock. Quote Link to comment Share on other sites More sharing options...
kpr Posted April 2, 2014 Share Posted April 2, 2014 sounds like its setup for a bigport 16v dizzy. using only the 4 tooth wheel. (they have a 4 tooth wheel. plus the 24 tooth.) will just fire the coil on each pulse. grinding the teeth may work. if the 4 teeth left are in the correct location. may still end up end up 10 degrees retarded though, if its reading the 24 tooth wheel. as will be trying to fire on each tooth already. slotting /modifying the dizzy for more mechanical adjustment maybe the only way to make it work, once you have ground the teeth Quote Link to comment Share on other sites More sharing options...
thegreatestben Posted April 2, 2014 Author Share Posted April 2, 2014 Just looked at old dizzy at previous owner. Only 4 teeth Quote Link to comment Share on other sites More sharing options...
vivaspeed Posted April 2, 2014 Share Posted April 2, 2014 Cool, on that basis I'm not going fuck around finding my Link and 20V dizzy just yet. Quote Link to comment Share on other sites More sharing options...
thegreatestben Posted April 2, 2014 Author Share Posted April 2, 2014 Hmm so marked my dizzy teeth up, removed unneeded teeth. Throw back together, no spark? Igniter hot, coil warm. Spin dizzy by hand fuel pump starts and injectors fire but no spark. Igniter only had one screw holding it on and wasn't exactly tight. Might have cooked it. Quote Link to comment Share on other sites More sharing options...
jakesae101 Posted April 2, 2014 Share Posted April 2, 2014 i have one here somewhere if you need to borrow one Quote Link to comment Share on other sites More sharing options...
downtrail Posted April 2, 2014 Share Posted April 2, 2014 Hmm so marked my dizzy teeth up, removed unneeded teeth. Throw back together, no spark? Igniter hot, coil warm. Spin dizzy by hand fuel pump starts and injectors fire but no spark. Igniter only had one screw holding it on and wasn't exactly tight. Might have cooked it. No spark directly from coil? Or no spark after cap? Quote Link to comment Share on other sites More sharing options...
kpr Posted April 2, 2014 Share Posted April 2, 2014 would have only cooked 1 channel of the ignitor if it is has. try swap the wires to the other channel, if they are on oc1 & ib1, swap them to oc2 and ib2. oc is to coil ib to ecu Quote Link to comment Share on other sites More sharing options...
thegreatestben Posted April 2, 2014 Author Share Posted April 2, 2014 No spark from coil. Signal from dizzy is getting to ecu as injectors are firing and the fuel pump is being switched on. Can't see how removing teeth on the dizzy has caused this. Was careful to blow out all the filings with air gun after grinding down teeth with die grinder. Igniter was really hot coil just warm. Mitsubishi parts... Quote Link to comment Share on other sites More sharing options...
