keltiks attempt at Brumby discussion
keltik
  • Replies 58
Were you actually trying to weld with no gas with solid wire? If so don't.
Press a smaller ID penny washer into a cone using a large center punch, that should fit down the hole a bit to reach the broken bolt. Then a good hot tack weld, with gas. Make sure it's clean with no zinc on the washer anymore.
Then weld a bigger NUT to the washer.
Unwind it.
