Beaver Posted September 23, 2012 Share Posted September 23, 2012 Right, I have one a12 engine which like to get very hot very quickly. Water use is minimal (in the time it takes to get hot which is say 10mins of driving, will happily idle at halfway on the gauge for ever and ever and not use water). Radiator has been flushed (with a hose haha) and returned all matter of brown particles and crud. When reved with the cap off water appears to be moving around suggesting the water pump is working (in one way or another). No change in behavoiur with or without a thermostat (which was opening and closing as expected). Suggestions? Ideas? Can radiators be tested? or not worth the effort? Should I whip the waterpump off and see what it looks like? Is it a possible BHG? Havnt dropped sump/oil but dipstick shows no water, and there is no visible evidence of oil in the water. Quote Link to comment Share on other sites More sharing options...
glen Posted September 23, 2012 Share Posted September 23, 2012 I have heard of water pumps that have had a couple of the blades fall off / corrode away, so the pump would move the water around at an idle and keep cool. But under any load while driving it would just cavitate the water and overheat. Quote Link to comment Share on other sites More sharing options...
sheepers Posted September 23, 2012 Share Posted September 23, 2012 get the radiator flushed properly. like get the tanks taken off and the core flushed out by a radiator re builders. i reckon you will find its about 80% blocked. Quote Link to comment Share on other sites More sharing options...
Beaver Posted September 23, 2012 Author Share Posted September 23, 2012 get the radiator flushed properly. like get the tanks taken off and the core flushed out by a radiator re builders. i reckon you will find its about 80% blocked. mmm yummy. its not in the best shape (fins look fairly shgged in places etc) so will they be able to tell me what its performance is like or should I try get another/better one to start with? Quote Link to comment Share on other sites More sharing options...
Borgweiser Posted September 23, 2012 Share Posted September 23, 2012 Bring it to J A Davison & Co, we can have a hoon on it Quote Link to comment Share on other sites More sharing options...
Beaver Posted September 23, 2012 Author Share Posted September 23, 2012 the car or the rad? car wont make it that far lol Quote Link to comment Share on other sites More sharing options...
Borgweiser Posted September 23, 2012 Share Posted September 23, 2012 far out, that's bad news, tow rope? Quote Link to comment Share on other sites More sharing options...
Beaver Posted September 23, 2012 Author Share Posted September 23, 2012 cbf'd to be honest.... Quote Link to comment Share on other sites More sharing options...
Shaz Posted September 23, 2012 Share Posted September 23, 2012 get the radiator flushed properly. like get the tanks taken off and the core flushed out by a radiator re builders. i reckon you will find its about 80% blocked. mmm yummy. its not in the best shape (fins look fairly shgged in places etc) so will they be able to tell me what its performance is like or should I try get another/better one to start with? Mark at Abel Smith Radiators is a top guy who knows his shit if you require his services and want to pull it out and drop it off to him. We've been using him for 20 years or some crazy amount of time and he hasn't let us down. (04) 3850580 Quote Link to comment Share on other sites More sharing options...
Beaver Posted September 23, 2012 Author Share Posted September 23, 2012 Yeh thats the plan to be honest, rip it out and take it in and see what they say. Quote Link to comment Share on other sites More sharing options...
damz721 Posted September 23, 2012 Share Posted September 23, 2012 exact same thing happening to me in my a12 too o.O Quote Link to comment Share on other sites More sharing options...
Beaver Posted September 23, 2012 Author Share Posted September 23, 2012 What was the outcome/cause? Quote Link to comment Share on other sites More sharing options...
damz721 Posted September 23, 2012 Share Posted September 23, 2012 Well i was travelling to kaikoura and she over heated possibly because of the manner she was being driven 120kms in 4spd. filled her up with cold water and was okay think the top hose was blocked slighty. drives okay now. looking at a new radiator though Quote Link to comment Share on other sites More sharing options...
HighLUX Posted September 24, 2012 Share Posted September 24, 2012 Could try Rustys trick with soda crystals? Cant remember the specifics but someone should be able to give some more info Quote Link to comment Share on other sites More sharing options...
Muncie Posted September 24, 2012 Share Posted September 24, 2012 Check the routing of your hoses i just sorted this issue on my car heater pipe had been looped up meaning the water wasnt circulating in the head put them back how they were supposed to be now problem gone... well apart from the gauge is also stuffed in the dash so external gauge also was needed. hope one of these 2 could help. Quote Link to comment Share on other sites More sharing options...
KKtrips Posted September 24, 2012 Share Posted September 24, 2012 Beave as your mechanic... LOL I suggest you take the radiator out and get it flushed/rodded/recored. Mark @ Abel Smith as per Shaz's advice, he will tell you whats the best course of action - mention my name for a sweet deal if you like. If you leave it with him it won't take more than a couple of days max. Replace the thermostat and fuck it- chuck a water pump at it for piece of mind - water pump and stat with some antifreeze shouldn't set you back more than a hundred. Radiator would be $50ish for a rod and clean. $250 for a recore. Do it all now and will give you piece of mind.. Nothing worse than a persistently overheating car during the summer break when nothing is open. Quote Link to comment Share on other sites More sharing options...
kicker Posted September 24, 2012 Share Posted September 24, 2012 +1 for Abel Smith, took my B16 fuel and rad in there, he fixed the tank up good as new but the rad was too far gone to save, ended up just buying a 2nd hand one to keep me going Quick look on the tard shows this but at least Mark's would be a known quantity http://www.trademe.co.nz/motors/car-par ... 599117.htm Quote Link to comment Share on other sites More sharing options...
Beaver Posted September 24, 2012 Author Share Posted September 24, 2012 Beave as your mechanic... LOL I suggest you take the radiator out and get it flushed/rodded/recored. Mark @ Abel Smith as per Shaz's advice, he will tell you whats the best course of action - mention my name for a sweet deal if you like. If you leave it with him it won't take more than a couple of days max. Replace the thermostat and fuck it- chuck a water pump at it for piece of mind - water pump and stat with some antifreeze shouldn't set you back more than a hundred. Radiator would be $50ish for a rod and clean. $250 for a recore. Do it all now and will give you piece of mind.. Nothing worse than a persistently overheating car during the summer break when nothing is open. lubs. that is the plan. will whip rad out tonight and drop in there tomorrow. BNT for waterpump etc or just smash up repco? Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted September 24, 2012 Share Posted September 24, 2012 Do it all now and will give you piece of mind.. Nothing worse than a persistently overheating car during the summer break when nothing is open. this. Happy motoring Quote Link to comment Share on other sites More sharing options...
KKtrips Posted September 24, 2012 Share Posted September 24, 2012 BNT for waterpump etc or just smash up repco? Ordered you a pump, gasket, thermostat and thermostat gasket at BnT up top of Taranaki St. Price will be about $85+ GST. Talk to Aaron and tell him Chris sent you. Will be in by lunchtime. Quote Link to comment Share on other sites More sharing options...
